How much gas or diesel did you use this season - SailNet Community
 5Likes
post #1 of 36 Old 09-09-2012 Thread Starter
Huck
smallboatlover's Avatar
i was just wondering how much people spent or how many gallons you used this year. did you motor more then sail or sail more then motor? i know i sail way more then i motor. also i used about 6-9 gallons so far since halfway through the summer when i got my boat.
16' mistral sailboat, And 27' coronado
smallboatlover is offline
post #2 of 36 Old 09-09-2012
Learning the HARD way...
eherlihy's Avatar
Re: How much gas or diesel did you use this season
15 Gallons of Diesel - since May 28.
eherlihy is offline
post #3 of 36 Old 09-09-2012
32 Gallons of diesel from 10-2011 to 6-2012.
104 hrs motoring
.3 gallons per hour w/rpms near 2000
Yanmar 4jh4
b40Ibis is offline
post #4 of 36 Old 09-09-2012
3 gallons. South and west winds are perfect at my slip for sailing in. I will use up more fuel when the north winds start pushing down.
lapworth is offline
post #5 of 36 Old 09-09-2012
Zanshin's Avatar
~100 Gallons from Dec 2011 through May 2012; includes a trip from Annapolis to the caribbean and living aboard full-time while bouncing around the leewards and windwards.
With no wind-generator or solar aboard and anchoring out all the time, most of the fuel was used to run the genset in order to charge the batteries and the fuel needed to get into and out of anchorages daily.
Zanshin is offline
post #6 of 36 Old 09-09-2012
I bought 9 gal regular gas last year, for (3) 3 gal portable tanks, and had about 1 left in each tank in the spring and added 6 gal.
About 1 gal left in two tanks and one not used yet, so with about two months of nice sailing weather left I may get by with only using 6 gal this year.
I have never had problems with bad gasoline even though it all contains ethanol.
1970 Havsfidra 20 by Fisksatra
On the Delaware River at Fox Grove Marina Essington PA
Ulladh is offline
post #7 of 36 Old 09-09-2012
snake charmer, cat herder
zeehag's Avatar
my season begins when yours stops...i used 4 gallons diesel, zero gas, and i live on board and full time cruise--now in mexico.....banderas bay.
those 4 gallons were not from going anywhere but fro the repairing of my what i haves....
formosa 41, cruising tropics
zeehag is offline
post #8 of 36 Old 09-09-2012
SERIOUS SAILOR
JoeDiver's Avatar
So far I've filled my 3 gal gas tank twice.
The first tank was burned up over a couple weeks because the motor was new and I needed to put 10 hours on it for break in.
The second tank was used from May through late July.
The current tank is 3/4 full.
I add Stabil to each tank when I fill it.
1982 Catalina 25 #2897
FK/SR/Traditional
Eagle Mountain Lake, Texas
JoeDiver is offline
post #9 of 36 Old 09-09-2012
addict's Avatar
Send a message via MSN to addict
Since January 125 liters. Lots of motoring lots of sailing and a fair bit for heat too. All my trips to the gulf islands this year saw lots of motoring. The sailing across the straits was great tho
addict is offline
post #10 of 36 Old 09-09-2012
Remember you're a womble
PaulinVictoria's Avatar
Dunno, maybe 15 litres over the past year.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is online now
How late in the season before I must winterize the diesel inboard? jameswilson29 Diesel 9 11-23-2011 07:57 PM
Season to Season bottom paint tommays Gear & Maintenance 1 03-10-2009 03:08 PM
Single Season vs Multi Season Ablative Bottom Paint sailingcal21 Gear & Maintenance 2 05-01-2008 08:29 PM
Why Change Fuel Filters at end of season and at beginning of season? theArchitect Gear & Maintenance 1 11-24-2007 07:37 PM
Diesel Fuel Tank Woes...or Bonehead mistake of the season rperret Gear & Maintenance 9 10-07-2007 09:32 PM
