  #1
Old 09-13-2012
CharliePapa is on a distinguished road
Dinghy protective cover
Hello
I want to install a cover to prevent the sun from degrading the Hypalon fabric of the dinghy. Any suggestions ? I guess something light ,beige or at least pale coloring and thin I would say Sunbrella would be overkill. Any recommendation ?
Thank you
  #2
Old 09-13-2012
gershel is on a distinguished road
Re: Dinghy protective cover
I think sunbrella might be the least expensive fabric that will last.
  #3
Old 09-13-2012
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
The current issue of Good Old Boat has an article on just this topic -- it's worth a look.
As for material choice, Sunbrella may seem to be overkill but then again you don't want this to be a recurring off-season crafts project do you?
  #4
Old 09-13-2012
rdw rdw is offline
rdw is on a distinguished road
Are you talking a cover for it while not in use or chaps to cover when in use. Sailrite has video to make chaps which I successfully followed. The chaps seem to be the way to go. They were not real easy to make but if I can do it you probably can. I used sunbrella and vinyl as directed by Sailrite. I added boat blanket to areas that might rub on something else at times, example rub strip. I also added a few net pockets that have worked well.
  #5
Old 09-13-2012
Minnewaska will become famous soon enough
I ordered one fom an online vender, several years ago. I is sunbrella knockoff, which many have acknowledged is the same stuff. I've been happy with it. Sorry, can't recall vendor. I just took a chance at the time.
Jeanneau 54DS
  #6
Old 09-13-2012
chef2sail's Avatar
chef2sail will become famous soon enough
Minnie probably Taylor.
My wife modified one of the Taylor models to fit our Walker Bay Odessey to cover it while in the davits. I bought an oversized one with elastic sew in to cover the entire dinghy. She cut slits to make room for the lifting triangles when attached. She also attached loops with straps to be brought under the dinghy to the other side to pull it taunt across the bottom. We put an inflated beach ball in the middle under the over to provide slope o the rain doesn't pool.
I have a procedure before pulling it up with the davits while in the water. I pull the cover over the bow first while sitting in it. Then I attach the lifting triangles through the slits and pull the cover over the other 3/4of the dinghy before I step out of it. Finally after it is lifted the ret of the cover goes on and the web straps underneath are tightened. It s almost fully protected.
The straps are put around the package to tie it tight o the davits and back rails so it dosent move even one inch.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #7
Old 09-13-2012
Thank you for your inputs
I was under the impression that Sunbrella was too thick.but with your suggestions it is the way to go. The cover will not be for when not in use or storage. The pontoons are white so a blanket on it will prevent damages from the sun
The sun is so good in the Bahamas...
Thank you all
CharliePapa
  #8
Old 09-13-2012
JonEisberg will become famous soon enough
Thank you all
CharliePapa
As usual, I'd recommend Stamoid...
Are you going to be making this cover yourself? Making dinghy chaps using Sunbrella, with some of the cut-outs required, could be an incredible PITA, working with a material like Stamoid that doesn't require hemming will save you a LOT of work...
Also, Sunbrella will have more of a tendency to "capture" and hold salt, which when dried and crystalized, will serve as a mild abrasive against the Hypalon... Dried salt crystals will not tend to adhere as much to the much slicker surface of Stamoid ...
More durable/abrasion resistant, less likely to tear, easier to keep clean, IMHO... And, when folded/rolled up for stowage, will result in a less bulky package, as well...
  #9
Old 09-13-2012
MarkSF is on a distinguished road
Hello
Thank you
I just bought one of these Taylor Made covers :
Taylor Made Dinghy Cover 8'5" to 9'4" Length 55" Max Beam*-*Taylor Made*70134 - Taylor Made Dinghy Covers - Taylor Made Inflatable Boats & Dinghies Covers - Boat Covers - Boatersland Marine
Seems to be well made. Straps go right around the dinghy so it's fairly secure.
Bristol 31.1
  #10
Old 09-13-2012
chef2sail's Avatar
Mark,
That's what we have modified by my wife to be able to work while the dinghy is in the davits.
Dave
Parkville, Maryland
Our blog-
You may post attachments
You may edit your posts
Dodger windows - cover or not cover? Gene T Gear & Maintenance 17 10-12-2010 03:50 PM
Seeking protective cover in Baltimore IdRatherBeSailing Chesapeake Bay 2 07-28-2010 11:58 AM
Affordable Dinghy Cover cruisingdream Gear & Maintenance 0 06-28-2010 10:18 PM
C-270 Main Sail zippered cover w/ lazy jacks, "Lazy Bag", "Quick Cover" Installation randy22556 Gear & Maintenance 0 02-27-2007 05:02 PM
SEO by vBSEO 3.6.1
