Propeller Drag - Challenging my intuition - Page 5 - SailNet Community
 3Likes
post #41 of 47 Old 09-14-2012
Re: Propeller Drag - Challenging my intuition
Modern Navy ships (gas turbine) with dual shafts do this all the time. During normal cruising, either the port or starboard shaft is being driven by a single engine (each shaft is coupled to two engines). The offline shaft spins freely with no engines on line. This plant alignment is called "Trail Shaft" and it is very efficient.
Obviously there are differences here, but the point is that trailing a propeller still uses less fuel than having two shafts online.
How fast the trailing screw turns will be a result of the vessel's speed, obviously. But the Navy does not lock the shaft. As the trailing screw turns, drag is reduced. If you aren't going fast enough to turn the trailing screw then drag really isn't a concern in the first place.
Now, whether or not you should lock your shaft is a question of how your gearbox is made. Your manufacturer can answer that question. But as to drag, the trailing screw free wheeling is better than being locked in place.
*This information is public.
https://www.oocea.com/CorporateInformation.aspx
Automated Propulsion Control for Optimum Thrust and Fuel Efficiency
HDChopper likes this.
ShoalFinder is offline
post #42 of 47 Old 09-14-2012
Wish I never found SN!
SimonV's Avatar
swap your prop for a kiwi prop and this discussion is mute. Main I love your work.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Gold Coast
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #43 of 47 Old 09-14-2012
Senior Moment Member
SloopJonB's Avatar
Originally Posted by JordanH View Post
Of course the argument is that I have a slim chance of having that blade lock vertically.
Next time your out of the water, rotate your prop to vertical, go on board and mark your shaft or coupling and then you have it for future reference.
SloopJonB is offline
post #44 of 47 Old 09-14-2012 Thread Starter
JordanH's Avatar
Yup, that's the plan as per post #27.
Will need to couple it with the idea above for an inspection hatch since I can't actually see it without ripping out the cockpit floor.
JordanH is offline
post #45 of 47 Old 09-14-2012 Thread Starter
JordanH's Avatar
Hey Simon, I had to look that one up. Another great idea.
I'll have to see if that is even usable with my boat. The prop must spin through a cut-out between the keel and rudder so often other prop types aren't feasible.
JordanH is offline
post #46 of 47 Old 09-15-2012
RocketScience's Avatar
Re: spinning prop on Volvo penta
Originally Posted by Denhan View Post
I have recently read in the volva penta manual that with a reversing transmission the propeller should not be left to spin without the engine running. The transmission is similar to a car auto trans and has a oil cooler that operates the same as the engine heat exchanger. With engine not running no cooling and transmission overheats and damage occurs. Now to find a shaft brake.
This may depend on which "manual" you're talking about.
If you're talking about the 28 +- horsepower Volvo engines of recent history (popular sized engines in the 32'-36' boat range), models MD11, 2003, and the later model D1-30 (which I have), all say that the control lever should/shall be in neutral while under sail:
MD11 Owner's Manual (Pg. 19)
2003 Owner's Manual (Pg. 6)
D1-30 Owner's Manual (Pg. 7)
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
post #47 of 47 Old 09-15-2012
Yanmar and SailDrive
We ran into a weird situation last week with a new Yanmar and Saildrive on a new 42 foot sailboat. WHile sailing the maxprop continued to rotate even after placing the transmission in reverse or in forward gear. Turned out the zinc was lose and that might have inhibited the blades from properly feathering. More importantly I was surprised that placing the shifter into reverse did not stop the rotation. Upon communicating with the commissioning yard, they decided the problem related to the shifter not being able to change the state of the transmission unless the electronics to the engine were activated. They told me there is an electronic link between the shifter and the transmission and the only way to place the transmission in gear was to either leave it in reverse when I turned off the engine or to nearly simultaneously move the shifter as we shut down the engine. I do not know if this explanation is accurate and until the prop fouls again, I won't be able to test this hypothesis.
msogin is offline
Challenging ASA ratings? jephotog Learning to Sail 29 10-02-2012 12:37 PM
Propeller drag test under sail. RatHatDiver Gear & Maintenance 21 03-13-2012 05:50 PM
High seas: Rough conditions make for a challenging start to race (Stamford Advocate) NewsReader News Feeds 0 09-02-2006 07:17 AM
High seas: Rough conditions make for a challenging start to race (Norwalk Advocate) NewsReader News Feeds 0 09-02-2006 06:15 AM
Dinghies and Drag Dan Dickison Gear and Maintenance Articles 0 04-09-2001 09:00 PM
