Like Tree10Likes
  #1
Old 09-16-2012
RobGallagher's Avatar
HANUMAN
RobGallagher is on a distinguished road
Stiff steering/rudder
1988 C&C 30 MKII
I bought the boat knowing the rudder/steering was stiff. Negotiated this into the price.
It is NOT anything in the steering. Remove the cables from the rudder and the steering is smooth and easy.
I have tried injecting grease into the rudder post via a zerk and it seems to have loosened things up a bit, but not nearly enough.
There does not appear to be any damage to the rudder.
Are there bearings in the post or what? I'm considering dropping the rudder this winter, but don't know if that's the correct way to approach it. Nor do I know what to expect.
Any suggestions?
  #2
Old 09-17-2012
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
Re: Stiff steering/rudder
Just to hazard a guess judging by where you keep your boat (LI Sound) I'd guess you might have some barnacles and/or other growth slowing your rudder post down.
Everybody has one:
  #3
Old 09-17-2012
HANUMAN
Reasonable guess, however;
I purchased the boat in Annapolis. The boat was on the hard and the bottom was clean/painted. Rudder was hard to turn from the survey.
  #4
Old 09-17-2012
HDChopper's Avatar
Needing Apehanger Helm
HDChopper is on a distinguished road
Sounds like someone might of installed new bushings and didnt hone them proplerly ?
Or injected epoxy ( or simular) to an older bushing to tighten it up and is to tight maybe ?
Keep working it back and forth with plenty of grease will help, but grease needs space to work in
There is no right way to do the wrong thing
  #5
Old 09-17-2012
Tempest is on a distinguished road
Am I misunderstanding the problem? If the Rudder moves freely with the cables disconnected, why are you focusing on the rudder? What type of system? Radial, Quadrant? shouldn't you be looking to see if the steering system requires attention?
Tempest
Sabre 34
Morgan, NJ
  #6
Old 09-17-2012
WDS123 is on a distinguished road
If you checked the typical mechanical items - then likely something inside (grit, growth, )
  #7
Old 09-17-2012
HANUMAN
Sorry, I should have been more clear.
I removed the steering cables from the rudder and the helm moved freely. The rudder however, was still hard to push by hand while disconnected from the steering mechanism.
  #8
Old 09-17-2012
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
Tempest is right -- fault isolation indicates the problem is not in the rudder or rudder stock, and instead is somewhere in the linkage. Keep narrowing down the fault based on that.
  #9
Old 09-17-2012
PorFin's Avatar
Señor Member
OK, disregard my last post
  #10
Old 09-17-2012
Captainmeme's Avatar
Captainmeme is on a distinguished road
Are you sure the rudder post is not bent?
HDChopper likes this.
You may post attachments
You may edit your posts
Stiff steering LuckyMon SailNet Website Technical Support 2 05-01-2012 10:20 PM
Stiff Steering chandlerman Gear & Maintenance 11 07-16-2010 09:10 AM
Help Stiff Cinkel Steering Pedestal jskrypek Gear & Maintenance 0 04-26-2010 09:57 PM
very stiff rudder and tiller mkrautha Gear & Maintenance 0 08-10-2009 11:28 PM
Stiff Steering on 2003 Bavaria 44 labestia Boat Review and Purchase Forum 3 02-01-2009 12:03 PM
SEO by vBSEO 3.6.1
