- Quick Menu
138Likes
09-25-2012
Re: Is sleeping OK?
If someone is going to solo sail any long distance, that person has to sleep at some point, which likely is a violation of the COLREGs. But that mean Matt Rutherford's recently completed solo, non-stop sail around the Americas was illegal. What Joshua Slocum did was foolhardy, and all the solo round-the-world races illadvised. People solo sail across great distances and God bless them for their courage and for demonstrating that it can be done.
As far as lights/signals for solo sailors catching up on needed rest, what about displaying the signals for a vessel not under command? A vessel not under command goes to the top of the pecking order. A solo sailor asleep could be considered an "exceptional circumstance" as found in the definition of a vessel not under command. Might be hard to rig a sound signal to go off every two minutes in reduced visability, but the lights (two all around red) and signs (two balls aligned vertically) should be easy enough.
S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
09-25-2012
KNOT KNOWN
Re: Is sleeping OK?
Here we go again. maybe the balls could be pink?
" Some are boat wise and some are other wise"
09-25-2012
Re: Is sleeping OK?
Originally Posted by johnnyquest37
As far as lights/signals for solo sailors catching up on needed rest, what about displaying the signals for a vessel not under command? A vessel not under command goes to the top of the pecking order. A solo sailor asleep could be considered an "exceptional circumstance" as found in the definition of a vessel not under command. Might be hard to rig a sound signal to go off every two minutes in reduced visability, but the lights (two all around white) and signs (two balls aligned vertically) should be easy enough.
Sleeping is not NUC.
Is sleeping OK?
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
09-25-2012
Re: Is sleeping OK?
I'm on your side Capt.aaron.
S/V Wind Orchid
Annapolis, MD
09-25-2012
KNOT KNOWN
Re: Is sleeping OK?
Thank you, and I jest. Jack and I have beat the day shape to death, but Not under command is a good signal to display and should be written to the colregs.
09-25-2012
Re: Is sleeping OK?
And until it is written in, it is not legitimate.
A vessel claiming not-under-command status must (1) find itself in exceptional circumstances, and (2) thereby be unable to maneuver as would ordinarily be required by the Rules. The following are examples of conditions that could result in not-under-command status:
Vessel with anchor down but not holding
Vessel riding on anchor chains
Vessel with inoperative steering gear
Sailing vessel becalmed or in irons
Exceptionally bad weather (relative to vessel claiming status)
Vessels claiming not-under-command status are considered to be underway. That is, they re not considered to be at anchor, made fast to the shore, or aground.
http://navruleshandbook.com/Rule3.html
So drop your anchor in 10,000 feet of water.
09-25-2012
KNOT KNOWN
Re: Is sleeping OK?
One day it may be, one day.....Hey If my anchors is down and not holding! That's it, drop a little anchor and display the nuc shapes, it won't be holding because it can't reach! Oh what a relief we've finally come to an agreement!!
09-25-2012
Owned by Velcro
Re: Is sleeping OK?
Originally Posted by Capt. Gary Randall
How difficult can it be to have someone along to stand a watch.
If I had to take someone along I would quit sailing. The whole point is to be alone out there and have MY peace and quiet. I don't want some snotty nose rule book waver on my boat or anyone else for that matter when I am under way. Fine at the dock or on a day sail, but not when I am going from A to B ..then I choose to be alone.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
09-25-2012
KNOT KNOWN
Re: Is sleeping OK?
I have this other single handling buddy that does delivery's with me, we are a pair. After 16 hours I'll yell down. " HEY A$$ hole, it's your watch!"
" What ever" he'll say and down I go for 12 hours and I'll hear " Hey dip sh!t
it's your turn" " what ever" I'll say. we'll have a first conversation about the voyage at the bar in Columbia like it was 2 different voyages and neither of us was with the other .
09-25-2012
Re: Is sleeping OK?
Originally Posted by jackdale
0600-1200, 1200-1800, 1800-2300, 2300-0300, 0300-0600.
Sorry - that was rather cryptic. I use it with large crews as well. There is a 48 hour cycle.
This summer we had 6 (later 5 - other story)
OK, Jack, that's at least the second time in this thread you mentioned the "6 (later 5)" crew. How about sharing that story? If you're worried about hijacking the thread (arguably a bit late for that), please start another, and link to it in THIS thread.
The worst watch is 0300 - 0600 which is why it is so short.
Interesting system, and makes sense on the face of it. I know those wee hours are the worst. Once fell asleep around 0330 on ambush patrol, but that's also another story.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
| Thread Tools |
Search this Thread |
You may post attachments
You may edit your posts
