Frameless steel construction - Page 5 - SailNet Community
 14Likes
post #41 of 44 Old 09-25-2012
KNOT KNOWN
Capt.aaron's Avatar
Re: Frameless steel construction
There are some fairly big ovens out there - hot rodders get complete frames coated but that's a long way from a steel 35 footer.
It's tough stuff but not indestructible - I don't what you'd do if it was breached but it would start to rust under the coating. You can't spot repair it like paint.
I think the epoxy paint industry is safe for a while longer.
I see, thanks. I've alway's kind of wonderd. I work on 50 year old steel tug and have a paint brush in my hand every day for sometime, spot painting rust.
" Some are boat wise and some are other wise"
Capt.aaron is offline
post #42 of 44 Old 09-25-2012
I have to say I'm a big fan of Brent's boats. If you don't know his designs, it's really worth getting his book or checking out the DVD before you form an opinion. As far as powder coating goes, why not just sandblast and then immediately flame-spray the whole boat with zinc? A friend did this when building his and there has been ZERO corrosion in 20 years of hard use. Another possibility is to build it out of aluminium and not paint it above the waterline.
Capt.aaron likes this.
Vindö 50
copacabana is online now
post #43 of 44 Old 09-25-2012
chucklesR's Avatar
Good Luck.
chucklesR is offline
post #44 of 44 Old 09-25-2012
Originally Posted by chucklesR View Post
Good Luck.
Vindö 50
Best gloop for fixing in a frameless window? PaulinVictoria Gear & Maintenance 27 06-02-2011 01:57 AM
Steel Hull Construction sailing320 Sailboat Design and Construction 71 09-24-2008 11:43 AM
Trantra construction, steel & glass sailboy21 Sailboat Design and Construction 8 01-23-2008 03:03 PM
Hull Construction Bernie K Boat Review and Purchase Forum 16 05-26-2006 09:56 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
