Motor??? - SailNet Community
 3Likes
post #1 of 13 Old 09-22-2012 Thread Starter
Motor???
Woo Hooooo ...
I thought I'd found a boat. A Capri14.2 but before I could get back, it was sold . But that is ok, ive found another!! which leads to my question. I will be looking at a MacGregor 22 that seems to be in good shape, but they want to sell me an outboard with it. What it the max weight and HP that should be used on this boat?
gnusailor is offline
post #2 of 13 Old 09-22-2012
Owned by Velcro
Ferretchaser's Avatar
Re: Motor???
I would stick a 15 HP egg beater on it with e start, that way it can charge your batts as well
Ferretchaser is offline
post #3 of 13 Old 09-22-2012
Re: Motor???
Isn't 15 HP on a 22 footer a bit of overkill? I would say 6 HP max.
Flybyknight likes this.
Catalina 34
chuck53 is offline
post #4 of 13 Old 09-22-2012
Quirky
Sublime's Avatar
Re: Motor???
That's too much.
5-6 hp should be fine. 10 would be a lot. You have to think about what kind of torque the engine mount can handle. Mine maxes out with a 10 hp and it's 26' and 5,000lb displacement. Currently I have a 5 hp on it that's worked. I'd switch to 10 hp if I was in any kind of current.
This post is made from recycled electrons
A ship in harbor is safe, but that's not why ships are built.
My girls:
1974 Alcort Minifish-Minifish
2001 Drascombe Lugger-Penelope
2004 Hunter 260-Miss Muffet
Sublime is offline
post #5 of 13 Old 09-22-2012
Owned by Velcro
Re: Motor???
Let the wind pipe up a bit and you are going to struggle getting up against it if needs be with a 6 also I rather have a 15 trundle along then a 6 running in high revs, and as far as I know they don't do a 6 with e start and alternator.
That was my line of thought when I sugested a 15 e start
post #6 of 13 Old 09-23-2012 Thread Starter
Thanks for the info. I don't know what it is she has, but needed to know if I should say no if it was too big.
post #7 of 13 Old 09-23-2012 Thread Starter
I'm excited... my first boat (maybe):-D ... and almost enough posts to and a pm... life is good:-)
jameswilson29 and HDChopper like this.
post #8 of 13 Old 09-23-2012
Re: Motor???
Some years ago, my brother had a 22 Santana, fixed keel. He did just fine with a 3 HP. 6 HP is more than enough.
Catalina 34
chuck53 is offline
post #9 of 13 Old 09-23-2012
overbored's Avatar
Re: Motor???
Originally Posted by gnusailor View Post
Woo Hooooo ...
the Mac 22 was originally spec'd for a max 10 HP. the Honda 9.9 has both charging and elec start. I believe the 8HP does also, get the extra long shaft model, 25" shaft. only thing your motor will be worth more then the boat.
MacGregor 22 sales brochure
"GOLD RUSH" PRINDLE 16
overbored is online now
post #10 of 13 Old 09-23-2012
Remember you're a womble
PaulinVictoria's Avatar
Re: Motor???
A 10hp 2-stroke probably though, which would likely weigh considerably less than a 10hp four, all of which are also going to be twins. It's not the HP you really need to worry about, it's the weight on the transom.
My 24', 4000lbs (loaded) boat does just fine with an old 7.5hp Honda in all kinds of winds and current. I don't have it hooked up for charging either, every now and then I just bring the battery home and charge it here.
On a 22', 6hp would be plenty, a 4hp would probably be fine too, a 15hp beast is probably going to mean the transom takes full advantage of the foam flotation most of the time
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
what Motor is this? bratzcpa Gear & Maintenance 4 08-31-2012 03:01 PM
Looking for old D.C. Motor. Please Help! KingLoon Gear & Maintenance 10 07-29-2012 11:12 AM
to motor or not smallboatlover General Discussion (sailing related) 17 08-19-2011 10:54 PM
What motor is this? cpd304 Gear & Maintenance 2 03-03-2011 08:12 PM
getting a motor for 14'' sklamar General Discussion (sailing related) 1 07-24-2002 03:56 PM
