  #11
Old 09-25-2012
JimMcGee's Avatar
JimMcGee is on a distinguished road
Re: Catalina 22's and trailer sailing generally
One thing to check before venturing into less protected waters is the condition of the keel pivot bushing.
A surprising number of people cruise these boats. We loved ours, but stepped up to a 30 for the live aboard room.
95 C30 Island Time
If more of us valued food and cheer and song above gold it would be a merrier world.” ― J.R.R. Tolkien
  #12
Old 09-25-2012
Sal Paradise's Avatar
Sal Paradise is on a distinguished road
I have a Cat22 that I tow with a Ford Freestar Minivan with a 4 liter V6 engine. My van handles it easily.
I have trailer launched boats for 20 years. I have my Catalina in a slip because its just such an ordeal to get it set up each time. That said, I plan on taking her on a trailer to Long island Sound and lake george. We spend a week in Newport every year and I would sail her out to Beaver Tail with a good weather window, and appropriate precautions taken. I have heard of guys taking them to Block but they have more nerve than I do. I can't see me taking my boat to Block, I would be nervous. God forbid bad weather came up. But in the harbor on a nice day - yes. One time on the ferry to BI, it was calm and flat at Point Judith, got out in the sound and hit a small storm. Zero visibility and spray coming over the bow of the ferry. This is a boat with tractor trailers in the hold. Got to Block and it was calm and serene.
I think its a pretty stable boat and I trust it in reasonable conditions. 15 knots wind and above with some whitecaps we put a reef in and leave one hatch board in, sail conservatively and she is fine. My boat is old, I have gone over the rigging but when its gets really rough and the lee shrouds are slack and the keel clunks. I worry a bit, just due to the age. But the hull always feels solid and dry and not tender. My point is you will really want to check it completely so you feel confident when she heels over.
  #13
Old 09-25-2012
Barquito's Avatar
Barquito
Barquito is on a distinguished road
My question is, for those who have a cat 22 or similar, how does she sail?
My first boat was a C22. In light winds it sails like any other keel boat. It relys a bit on hull form stability, so, in heavy air it starts sailing more like a dinghy. It is possible to capsize a C22 if you get supprised by a big gust. Normally it will just round-up rather than go over, but, if it does go over you can get significant down flooding from lockers, the main hatch, and the gas locker vents (if a port knockdown). I sold my C22 to a guy who did just that. Got knocked down, and sank the boat. In higher wind or gusty conditions, I would keep the main sheet uncleated, and sheet in hand. You can also take the precaution of putting hatch boards in, latching cockpit lockers, and maybe even stuffing a sock in vents.
Bristol 27
Cirque
  #14
Old 09-25-2012
peterchech is on a distinguished road
Originally Posted by TQA View Post
Yup 2 litre engine. Which is a BIG engine by UK standards but I realise that it barely makes it of the bottom of the scale in the US. It did the job. I was careful to use a rope between car and trailer, keeping the car on the level.
From Hoot Mon
I have a 2.1 litre on my chevy malibu. Did you have a transmission cooler added?
I guess you used a rope/wire to winch it into the water and back, instead of driving it down the ramp as you would with t truck?
I have seen alot of boats being towed by small cars in europe, I guess you make due with what you got sometimes, though it can't be good on a car...
  #15
Old 09-25-2012
Originally Posted by DonScribner View Post
Pete,
We trailer sail every weekend possible. It takes about 35 minutes to step and launch after you get used to doing it and it does give you the power to sail DUW at 70 knots. Ours is a Lancer 25 and is big enough for week long excursions for two. She is a bit heavier than you're suggesting though. Boat, gear and trailer are in the 5500 lbs range so we use our F150 to haul her. If you went with a water ballasted boat, you'd loose about 1000 lbs. If you're serious about this, pick up a copy of The Complete Trailer Sailor by Brian Gilbert. He has lots of great info on trailering and sailoring. In the back, he provides quite a list of boats with sketches, photos, specs, pros and cons on them. It was suggest to me by James L Nelson, friend, sailing guru, swiller of fine brews and cheap beer . . . oh, and noted novelist with many books available at fine bookstores everywhere! Ask for him by name! (Shameless plug for you, Jim) Actually, Jim is a childhood friend, a real character and a good man.
Anyway . . . cheap advice and shameless canvasing aside, good luck with the new boat!
Don,
Biddeford, ME
Just got the book for my kindle app thanks!
  #16
Old 09-25-2012
In light winds it sails like any other keel boat. It relys a bit on hull form stability, so, in heavy air it starts sailing more like a dinghy. - Barquito
I think that is an interesting comment and probably true of the Cat 22 and of many other 2000 lb sailboats. Also a great comment about closing the boat up. It does have a 500 lb keel and it draws 5'. The keel on your boat looks massive though.
I sailed my Cat 22 in 20 knots today with just a reefed main and it was docile and poked along great. Its easy to handle with a reefed main. My wife was freaked out by the whitecaps which were rolling the boat sideways a bit, but it was nothing really. After a while it just got normal. I think 20 knots wind and 2 foot waves are our limit at this time with this boat.
  #17
Old 09-26-2012
gfh's Avatar
gfh gfh is offline
Fortuitous
gfh is on a distinguished road
It's a solid little boat. A lot of things would have to go wrong to sink one. Letting the main out pops it right back up, and the positioning of the main sheet makes it easy to leave it uncleated to ride the gusts accordingly in frisky weather. I've only put the crib boards in on my boat once, and that was in 30 kts (motoring on bare poles).
I would feel much, much safer sailing my boat in 25kts than towing it with a vehicle that's not rated for its weight.
My Boat Log, or "blog" if you will:
  #18
Old 09-26-2012
Nice pic!
Thanks for the info.
You may post attachments
You may edit your posts
Have had enough of what is generally accepted as a good life frustrated in Pa Introduce Yourself 10 11-05-2011 04:19 PM
J/22's everywhere! eMKay General Discussion (sailing related) 6 07-30-2008 09:26 PM
Trailer - Catalina 22 BVPBill Catalina 3 05-27-2007 01:04 PM
Trailer for Catalina 30 w6jtb General Discussion (sailing related) 0 10-27-2001 08:50 AM
Catalina 27 w/trailer RaymondMurphy Boat Review and Purchase Forum 0 05-12-2001 08:06 PM
SEO by vBSEO 3.6.1
