Help me decide - Mooring bitt or cleat? - Page 2 - SailNet Community
post #11 of 28 Old 10-01-2012
casey1999's Avatar
Re: Help me decide - Mooring bitt or cleat?
Here is a pic of my mooring bit. I really like its versatility for anchoring, docking, sea anchor, and emergency towing. I have a large 12"x12" piece of G10 backing plate under it and 4 large bronze bolts holding it down- all very stong.
casey1999 is offline
post #12 of 28 Old 10-01-2012 Thread Starter
Casey, Thanks for the photo. Any advantage of having the rod go fore-aft rather than port-starboard?
marcberoz is offline
post #13 of 28 Old 10-01-2012
casey1999's Avatar
I thought about what way it should go before mounting. I think it looks better going port-starboard, but in that direction there is more of a chance of hitting the bar with your foot (and maybe tripping) when doing work at the bow, especially in rough conditions. It makes no differance when tying lines, although I have found since installing, it may be easier to tie off the lines with the bar mounted fore-aft as mine is. The mooring bit does take up space, and I probably could have used the next size down, but I'd rather have too big than too small.
post #14 of 28 Old 10-01-2012
Something to think about is the number of bolts on the cleat and size of the backing plate. They are usually undesized for the possible loads. I's go for a 4-bolt cleat and make a stainless steel backing plate about the size of a sheet of paper, or what fits. The loading problem will occur if you have to get a tow and need to use the cleat for the tow line.
Walt Elliott
Kingston WA
Puget Sound
Cal-29
Waltthesalt is offline
post #15 of 28 Old 10-01-2012 Thread Starter
Yea. I agree with you. There's too much riding on a cleat or bitt to skimp on installation. I'll be using the largest backing plate I can.
Marc
post #16 of 28 Old 10-02-2012
Mooring bits are usually far stronger than cleats, and can take more line before becoming filled up. I prefer bits.
On a small boat, a super strong eye in the top of the stem, with a good backup plate inside, will eliminate chafe,when on a mooring.
Brent Swain is offline
post #17 of 28 Old 10-02-2012
Owned by Velcro
Ferretchaser's Avatar
I have just read in another thread how dangerous cleats are so I would sugest to go with a bit.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #18 of 28 Old 10-02-2012
casey1999's Avatar
Matt also used a West Maine (316 stainless steel) mooring bit on his Contessa 26 and had nothing but good things to say about it:
Solo Around the America's Under Sail | An audacious attempt at sailing the Northwest Passage and circumnavigating entirety of both continents, to benefit Chesapeake Region Accessible Boating
post #19 of 28 Old 10-02-2012 Thread Starter
On a small boat, a super strong eye in the top of the stem, ...
Brent,
I don't know what you mean by this. Can you explain it or post a picture?
Thanks
Marc
post #20 of 28 Old 10-03-2012
Huck
smallboatlover's Avatar
I plan on getting rid of both my cleats next year for a mooring bit. I like them more and right now my ckeats have no chockes so the bow if the boat acts as the chock its bad. So i plan to make the area were the cleats are for chocks
16' mistral sailboat, And 27' coronado
smallboatlover is offline
Trying to decide ImASonOfaSailor Cruising & Liveaboard Forum 3 02-09-2015 02:30 PM
Help me decide on a name bmacfarquhar General Discussion (sailing related) 45 10-08-2012 02:43 PM
Mooring loops too big for cleat ColinJ Gear & Maintenance 2 07-18-2011 09:06 PM
Changing a V-Cleat to a C-Cleat? funjohnson Sailboat Design and Construction 11 08-21-2008 10:14 AM
Trying to decide between. . . . . . . mcl2 Boat Review and Purchase Forum 2 07-11-2002 05:55 PM
