Help me decide - Mooring bitt or cleat? - Page 3 - SailNet Community
post #21 of 28 Old 10-03-2012
tommays's Avatar
Re: Help me decide - Mooring bitt or cleat?
The BIT is vastly better IF your on a mooring as most of the cleats i see are really done for docking
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #22 of 28 Old 10-04-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
At the risk of starting a battle (and hearing the war cry of "WASABI!" from 2 threads over) I'll say that in navy training I heard these fixtures called 'bollards'.
The easily remembered mneumonic?
"Bitts are like tits, they come in pairs."
(Am I banned now?)
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #23 of 28 Old 10-04-2012
casey1999's Avatar
(Am I banned now?)
First mention of "Bollard" from Wikipedia:
"The Sailor's Word-Book of 1867 defines a bollard in a more specific context as "a thick piece of wood on the head of a whale-boat, round which the harpooner gives the line a turn, in order to veer it steadily, and check the animal's velocity"."
casey1999 is offline
post #24 of 28 Old 10-04-2012
Load Bearing Member
Dock
And Wikipedia says that a bitt is the same thing as a bollard; then goes on to define a lot of things as 'bollards' that are clearly not bitts. (i.e. lighted traffic posts).
Zen Again
post #25 of 28 Old 10-04-2012
Bitt or Cleat? aren't those the two guys running for president down there?
urbanhermit is offline
post #26 of 28 Old 10-04-2012
Originally Posted by marcberoz View Post
Brent,
I don't know what you mean by this. Can you explain it or post a picture?
Thanks
Marc
A super strong stainless eye bolt or a stainless eye welded to a plate, thru bolted thru a backup plate inside the hull with lots of bolts.
Brent Swain is offline
post #27 of 28 Old 10-04-2012
casey1999's Avatar
I think of bollards like this:
http://www.greenboatstuff.com/dacobrbomo11.html
And bits like this:
Davey & Company Bronze Mooring Bitt
The bit has more of a pin on it that can bite ("bit") you and a bollard is more round.
post #28 of 28 Old 10-04-2012
Junior Senior
heinzir's Avatar
Location: Lake Minnetonka (near Minneapolis, Minnesota)
Bitts/bollards are very good for dock lines and for towing but for attaching a permanent home mooring your best bet, IMHO, is to use the bow eye. Your boat is small enough to be trailerable and no doubt has a strong eye on the bow for the trailer winch line. Just make sure the eye is well backed up (as you would a cleat, bitt, or bollard.) The advantages of using the bow eye instead of a fitting on deck are that there will be absolutely no chafe of the mooring line, and the lower attachment point effectively increases the "scope" of the mooring.
I have two pendants attached to my 23' cutter's home mooring. One is 3/4" diameter and connects to the bow eye with a 1/2" dia stainless locking caribiner. This is the primary mooring line. A slightly longer 5/8" line attaches to the bow cleat and serves as both a backup and a pick-up line. It holds the boat securely while I tidy everything up before leaving in the dinghy. I attach the primary line to the bow eye from the dinghy.
This has worked well for me for over 30 years with this boat. Note that this is how I have set up my home mooring; it would not necessarily work with a transient mooring.
Henry
Chiquita - 1974 Macgregor Venture of Newport 23
heinzir is offline
Trying to decide ImASonOfaSailor Cruising & Liveaboard Forum 3 02-09-2015 02:30 PM
Help me decide on a name bmacfarquhar General Discussion (sailing related) 45 10-08-2012 02:43 PM
Mooring loops too big for cleat ColinJ Gear & Maintenance 2 07-18-2011 09:06 PM
Changing a V-Cleat to a C-Cleat? funjohnson Sailboat Design and Construction 11 08-21-2008 10:14 AM
Trying to decide between. . . . . . . mcl2 Boat Review and Purchase Forum 2 07-11-2002 05:55 PM
