Steaming light - Page 3 - SailNet Community
 13Likes
post #21 of 39 Old 09-26-2012
Needing Apehanger Helm
HDChopper's Avatar
Re: Steaming light
How about spreader lights faceing down on at night for more visiblity , would that be considered "steaming light"? ( seems it would be hard to tell the differance between a masthead light and a spreader light both are up high).
Im all for doing things correctly ( the whole point of learning) but trying to as safe as possible (makeing shure your seen) seems to be as important .
As being Captn of vessel all safety responsibility rest on his shoulders..just seems prudent to me & no I am not a Capt yet I ask because Im learning...
Sorry if this is OT...
There is no right way to do the wrong thing
HDChopper is offline
post #22 of 39 Old 09-26-2012
No, that was my point... I DON'T believe otherwise. I fully intend to behave in accordance with the lights I'm showing, and act as a powerboat when it comes time to give way. Inconvenient for me, but a small trade off for the extra visibility, is how I see it.
Stearmandriver is offline
post #23 of 39 Old 09-26-2012
Thanks Jackdale, you're correct. I didn't word my explanation very well. The 2 whites total 360 degree visibility is what I meant but didn't say very well.
post #24 of 39 Old 09-26-2012
jackdale's Avatar
Re: Steaming light
Originally Posted by sailingfool View Post
This is very bad practice. You're setting the circumstance where a powerboat to starboard will believe you are the giveway vessel, while you believe otherwise. should a collision occur, you will be largely at fault, maybe 100%. Maybe you don't care about at fault but a damaged or sunk boat, or injured friends, is inconvenient.
Improper lighting can get you into trouble.
Collision – Small Vessels – Improper lighting – Liability
Thatcher v. Schell, 2005 BCSC 1121,
This case involved a collision on Okanagan Lake between a 26' sailboat operating under power and a 19' motorboat. The collision occurred at dusk. Both vessels were destroyed and the occupants of each were injured. The owner of the sailboat alleged that the collision was caused by the negligence of the other vessel in proceeding at an excessive speed and failing to maintain a proper lookout. The owner of the motorboat argued that the collision was caused by the negligence of the sailboat in failing to have the proper running lights and in turning to port immediately before the collision instead of to starboard as required by the collision regulations. It was uncontested that the driver of the motorboat did not see the sailboat until immediately before the collision and took no steps to avoid the collision. After reviewing all of the evidence the Judge found as a fact that the sailboat was not properly lit and that this was the cause of the collision. The owner/operator of the sailboat was therefore held to be completely at fault.
Full text - CanLII - 2005 BCSC 1121 (CanLII)
jackdale is offline
post #25 of 39 Old 09-26-2012
Re: Steaming light
Being seen is only half the purpose of the navigation lights. The other half is
to let the other vessel know how they must deal with you. ( give way, or stand on ) and what they should be able to " expect" of you..
showing deck lights, without a steaming light...if you are underpower, is inappropriate..and more likely to result in a problem..
chef2sail and HDChopper like this.
tempest is offline
post #26 of 39 Old 09-26-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Steaming light
Originally Posted by jackdale View Post
I actually sought legal opinion, professional opinion and called the USCG. All agreed.
I think it was posted to CF, but I think I kept the emails.
Sorry Jack, I didn't see your post before I sent mine. We are in agreement.
Cheers
Andrew B
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #27 of 39 Old 09-26-2012
ASA and PSIA Instructor
Re: Steaming light
Originally Posted by Stearmandriver View Post
No, that was my point... I DON'T believe otherwise. I fully intend to behave in accordance with the lights I'm showing, and act as a powerboat when it comes time to give way...
Nope, still leaves your bad practice, a bad practice. If you are on starboard and a port tack sailboat believes you a giveway vessel (i.e. a powerboat) and you think otherwise...well you've heard the rest of the dialog.
Being a giveway versus a standon vessel present mutually exclusive obligations, and expectations from the other parties.
PS - Andrea Doria sunk due to confusion about which vessel was standon...
sailingfool is offline
post #28 of 39 Old 09-26-2012
Dirt Free
boatpoker's Avatar
Re: Steaming light
Sailingfool, thank you for your continuing use of the terms "Stand on" and Give way" as opposed to the more commonly used and arrogant (and often mis-used) term "Right of way".
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #29 of 39 Old 09-26-2012
Re: Steaming light
Jackdale, reading that decision only makes me more concerned about a court agreeing with the argrument that I wasn't under power because I was in neutral at the time of collision.
I think most of us are just advocating the use of the correct lighting to reduce confusion as intended. When I see a boat with the wrong lights I assume the operator didn't know what was appropriate so just "turned them all on".
"Just call me TB"
capttb is offline
post #30 of 39 Old 09-26-2012
Re: Steaming light
Nasty
I would not do that myself. I would have my sails up and be hove-to, sailing lights on (sidelights and sternlight or tricolour).
You are underway , but you are not undersail (not sailing vessel), not propelled by machinery (not power-driven), not NUC or RAM.
I think that the courts may have decide.
I agree. The lack of control would be foolish in most circumstances. I added all that stuff to camoflage the the answer, which I once got wrong on a test. When I went through a Navy Recreational Services boating course I was incorrectly informed on this point. Thirty years later I got dunned for the answer on a, can us guess, Navy Recreational Services boating test.
ccriders is offline
Combo anchor & steaming light jarcher Gear & Maintenance 27 01-29-2017 03:06 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
Steaming light wchevron Gear & Maintenance 13 05-17-2009 10:49 AM
Steaming light zz4gta Gear & Maintenance 3 04-30-2008 11:45 AM
