Steaming light - Page 4 - SailNet Community
 13Likes
post #31 of 39 Old 09-26-2012
Senior Slacker
SlowButSteady's Avatar
Re: Steaming light
I once asked a friend with a 1600 ton Masters License about what constitutes "under power", and he said that "if the machinery is turning" (i.e., the motor is on, in gear or not) a vessel is "under power". I suppose that wouldn't include a genset, since it can't turn the prop.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #32 of 39 Old 09-26-2012
Re: Steaming light
Originally Posted by boatpoker View Post
Sailingfool, thank you for your continuing use of the terms "Stand on" and Give way" as opposed to the more commonly used and arrogant (and often mis-used) term "Right of way".
It would be interesting to do a survey of recreational boaters, sail and power, to see if they understand the terms "Stand on" and "Give way". The response might truly be scarry.
rikhall likes this.
ccriders is offline
post #33 of 39 Old 09-26-2012
This is just silly. I've already explained that your scenario is meaningless because it wouldn't happen... if I light myself as a powerboat, I'll certainly know I did that, and certainly behave as a powerboat. Yeah, I'm going to light myself as a powerboat and then quibble over stand-on / give-way status as though I were a sailboat... how does that even make any sense? Let's face it... a LOT more collisions happen because the boats simply did not see each other, than happen because of confusion over status. Even if you're convinced you're stand-on, are you really going to press it all the way to a collision with another vessel that you're aware of? First and foremost, in a small boat on a dark night, you want to be SEEN.
Standards, best practices etc are good things. They keep a lot of people safe in a lot of circumstances. But there's a point where you have to be able to think for yourself. In my aviation career, I've seen a couple people follow that rulebook right into the ground. This lighting scenario is obviously not that drastic, but it's kind of the same idea - if the circumstances are such that deviating from the rules in a conservative way is actually safer, and you are properly aware of what you're doing (realizing how others will perceive you in a right of way scenario), then it's sometimes the smarter option. It's all about JUDGEMENT. On a visibility-compromised night, choosing not to use an available highly visible light is, to me, poor judgment.
Agree or disagree, doesn't matter... at least hopefully you'll see me if we ever meet at night. And who knows, maybe I'll end up having to give way to you even though, if I turned off the steaming light, I'd be the stand-on. Maybe then you'd stop complaining. ;-)
HDChopper likes this.
Stearmandriver is offline
post #34 of 39 Old 09-26-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Steaming light
Slow .... he may well have said that but I'm still of the opinion from reading the regs that unless the propulsion machinery is engaged the vessel is not under power.
(b) The term “power-driven vessel” means any vessel propelled by machinery.
(c) The term “sailing vessel” means any vessel under sail provided that propelling machinery, if fitted, is not being used.
(e) A vessel proceeding under sail when also being propelled by machinery shall exhibit forward where it can best be seen a conical shape, apex downwards.
Ok so I am no maritime lawyer however a vessel with power plant operating though gearbox not engaged surely cannot be said to be being propelled by machinery.
Tempest and jackdale like this.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #35 of 39 Old 09-26-2012
Re: Steaming light
So I'd be exercising poor judgement by sailing at night without my steaming light, anchor light and deck lights ? Interesting viewpoint, landing lights on always also ?
"Just call me TB"
capttb is online now
post #36 of 39 Old 09-26-2012
tdw
tdw's Avatar
Re: Steaming light
Of course if you choose to have your steaming light illuminated then you are , propeller engaged or not, a power boat. There can be no quibble about that, surely.
I guess the question would be answered by the racing fraternity. Pretty much every top flight racing boat these days has their engine running 24 hours a day in order to keep power going to the canting keel mechanism and their plethora of electronic equipment.
― Terry Pratchett.
tdw is offline
post #37 of 39 Old 09-27-2012
Anchor light could be problematic, producing the appearance that you aren't moving. Deck lights, yeah if I had them they'd be on unless they affected my night vision. Landing lights always on? Below 18 (the equivalent of nearshore sailing, where there's more general aviation traffic), yeah you betcha. That IS an industry standard.
post #38 of 39 Old 09-27-2012
old guy :)
rikhall's Avatar
Re: Steaming light
Originally Posted by ccriders View Post
Okay, this is a test:
Sails are down, you are drifting with the wind and current, the autopilot is engaged, the engine is running, the transmission is in neutral, it is nighttime, youre having dinner in the cockpit with cockpit lights on. What navigation lights do you show?
Red or white wine?
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #39 of 39 Old 09-27-2012
Re: Steaming light
Red for me, white for the mate. And put a couple of cubes in hers.
ccriders is offline
Combo anchor & steaming light jarcher Gear & Maintenance 27 01-29-2017 03:06 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
Steaming light wchevron Gear & Maintenance 13 05-17-2009 10:49 AM
Steaming light zz4gta Gear & Maintenance 3 04-30-2008 11:45 AM
