Steaming light - SailNet Community
 13Likes
post #1 of 39 Old 09-26-2012 Thread Starter
Question Steaming light
Hello again, I have another ? 4 U. If you are running at night and your sails are down, do you need the steaming light? If you are not sailing, wouldn't you be the same as a power boat? I'm asking cause I am getting alot of different answers. Thanks.
AirborneSF is offline
post #2 of 39 Old 09-26-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Steaming light
If your are under power (not sail) you are a power boat and must show a steaming light.
If you are under power and sail, you are still a power boat.
Only under sail alone can you dowse the steaming light.
I have forgotten what lights are needed when you are drifting (no sail, no power).
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #3 of 39 Old 09-26-2012
Seattle Sailor
Re: Steaming light
The requirements for lights are the same as for a similar sized power boat if you are not sailing. If sailing at night, you won't need the steaming light, however.
PDean
CS 34
Seattle, WA
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." - William Arthur Ward
padean is offline
post #4 of 39 Old 09-26-2012
Brewgyver's Avatar
Re: Steaming light
You may get different anwers, but there's only one correct anser: When under power, a Sailboat is a"power-driven vessel" and abide by all the right of way rules for such.
USCG Navigation Rules Onlin
Rule 3 - General Definitions
For the purpose of these Rules and this Chapter, except where the context otherwise requires:
(a) The word "vessel" includes every description of watercraft, including non-displacement craft, [WIG craft], and seaplanes, used or capable of being used as a means of transportation on water.
(b) The term "power-driven vessel" means any vessel propelled by machinery.
(c) The term "sailing vessel" means any vessel under sail provided that propelling machinery, if fitted, is not being used.
jackdale likes this.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #5 of 39 Old 09-26-2012
Brewgyver's Avatar
Re: Steaming light
Originally Posted by CarbonSink62 View Post
(snippage)
Short answer is if you're not anchored, and not disabled (Vessel not under command), you are considered to be Under Way, and the lighting requirements are only changed by whether you're under power or not.
s/v My Sweet Girl!
Atomic 4
post #6 of 39 Old 09-26-2012
Re: Steaming light
Okay, this is a test:
Sails are down, you are drifting with the wind and current, the autopilot is engaged, the engine is running, the transmission is in neutral, it is nighttime, youre having dinner in the cockpit with cockpit lights on. What navigation lights do you show?
ccriders is offline
post #7 of 39 Old 09-26-2012
Re: Steaming light
Steaming and navigation/running lights, if the engine is running you are a powerboat, just like the guy in the Skipjack drift fishing nearby.
"Just call me TB"
capttb is offline
post #8 of 39 Old 09-26-2012
Re: Steaming light
If you have the time: Navigation Rules Online
HDChopper likes this.
Seaduction is offline
post #9 of 39 Old 09-26-2012
My theory on this is, I don't so much care at night if other vessels can tell whether I'm under power or sail... I just want them to see me. So whether sailing or motoring, at night I use every exterior light I've got. It's funny how deck mounted running lights can blend nicely into the shore lights in the background, but the masthead steaming light stands out like a beacon against a dark sky, appearing above the background lights. I'm aware it's not technically correct, but sometimes common sense is called for over the books - especially in reduced visibility, light yourself up as much as you can. Only negative I can see is another vessel not knowing that you, under sail, have right of way... but I don't care about that at night. I'd rather just give myself the extra visibility, and have us both alter course instead of marking myself as the stand on vessel.
HDChopper and bandaidmd like this.
Stearmandriver is offline
post #10 of 39 Old 09-26-2012
Re: Steaming light
Us OTHER vessels really care because we can't tell what you are with all those lights on, shrimp trawler maybe ?
"Just call me TB"
capttb is offline
Combo anchor & steaming light jarcher Gear & Maintenance 27 01-29-2017 03:06 PM
Tri-color Steaming masthead light as only nav light? Perithead Gear & Maintenance 110 09-18-2011 12:53 PM
steaming light, running light, wiring yzlian Pacific Seacraft 4 03-24-2011 09:44 AM
Steaming light wchevron Gear & Maintenance 13 05-17-2009 10:49 AM
Steaming light zz4gta Gear & Maintenance 3 04-30-2008 11:45 AM
