Does anyone else do this while refitting? - SailNet Community
 4Likes
post #1 of 24 Old 10-01-2012 Thread Starter
Whenever my never ending refit gets me down. Which is usually whenever I get in a fight with the person who lives on the other settee over who got the sawdust/fiberglass or paint chips in the other's bed/clothes..
I browse yachtworld and look at other boats. 90% of the time I see boats with more worn out parts, or spot a dozen things I'd have to fix and console myself that at least I'm not fixing that boat.
If that fails I'll open the cabinets and look at my sink drain, which I'm very proud of right now.
Took me 6 tries to get my sink drain just right, but now it's RIGHT. Maybe not on par with building a boat from scratch, but probably fairly close.
Whoever thought a 1 1/2" sink drain 9" above a 1 1/4" throughhull was a good idea should be keelhauled.
Jgbrown is offline
post #2 of 24 Old 10-01-2012
bigdogandy's Avatar
Dock
Re: Does anyone else do this while refitting?
I do the same thing, jg....it is amazing how satisfying it is to look at other boats on Yachtworld in the same general category and price range as mine and see that they have as many or more opportunities for improvement as my boat does. Just have to avoid bumping the price range scale too high and looking at temptations that are beyond my reach.......
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #3 of 24 Old 10-01-2012
chucklesR's Avatar
gosh, no - I'd never look at another boat just because I'm frustrated with the one I have.
That would be cheating with my eyes.
RobGallagher likes this.
chucklesR is offline
post #4 of 24 Old 10-01-2012
Greenflash35's Avatar
Yes looking at production boats, makes all of our hard work really show.
GreenFlash35
Greenflash35 is offline
post #5 of 24 Old 10-01-2012
Barquito
Barquito's Avatar
Yachtworld is poison in our house. We removed all the deck hardware and toe rail and repainted the deck this winter-spring-summer. We still haven't gotten everything put back together from b/f painting. If I show my wife a picture of some nice boat on YW, and say, "gee wouldn't this be nice...", I am likely to get a shoe upside the cranium.
Valiant 32
Barquito is offline
post #6 of 24 Old 10-01-2012
Courtney the Dancer
jrd22's Avatar
Whatever it takes to get you through a refit is fair (I also get great satisfaction looking at how I ingeniously solved our sink drain problem). If it takes looking at disasters on YW, or walking down the dock daily to look at the sad, abandoned, and "at least ours isn't that bad" example, just do it. It's a bit of a one day at a time type of experience where you learn to dig deep and pull up reserves that you never knew you had to get through it:-))
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #7 of 24 Old 10-01-2012 Thread Starter
Indeed it is:-) What was your sink drain problem? Mine was "solved" by the previous owner by using home depot grade drain hose complete with glued on ends and a short plastic washer in the end and by wrapping the seacock pipe in electrical tape to make up for it's lack of diameter. My sink drain is below waterline.
Went to double clamp it and got a rude surprise.
Tried everything from 100$ in bronze fittings from west marine(right idea, wouldn't leave a good angle for drain hose, or in the end actually fit under there.) to trying to locate a sink with a 1 1/4" drain or to use a extender that would shrink the size at the top of hoze instead of the bottom.
in the end I replaced the drain part of the sink with a 1 1/4" abs fitting, and the hose keeps the sea out even without hose clamps(left it for 8 hrs to check while I was fussing with other stuff in the same area).
Double clamped with opposite facing non perforated clamps now of course :-)
Jgbrown is offline
post #8 of 24 Old 10-01-2012
Courtney the Dancer
jrd22's Avatar
It was minor really, just a question of finding flexible connectors that would connect two different sized pipes. Double sink and a custom made stainless drain pipe/manifold trying to connect to standard sink drains. It took some research and trying several things before I stumbled across something that worked perfectly.
John
SV Laurie Anne
jrd22 is offline
post #9 of 24 Old 10-01-2012
You really are funny!!
chrisncate's Avatar
Every time I ran into that kind of issue, I'd pause for a moment, then justify why I had rip it all out and replace it completely from top to bottom.
In bronze of course....
chrisncate is offline
post #10 of 24 Old 10-01-2012 Thread Starter
Did that. Didn't fit. Tore it out again. ABS fittings at the top made for the neatest job short of tearing out the counter and making it taller.
Jgbrown is offline
Refitting for the Spring peterchech Gear & Maintenance 38 02-19-2012 09:25 PM
Refitting Interiors zboss Boat Review and Purchase Forum 30 08-18-2010 09:31 AM
Countertop refitting gedaggett Gear & Maintenance 6 10-12-2009 10:40 AM
refitting sail 24ccbob Introduce Yourself 3 09-27-2009 12:01 PM
Refitting a 52'' ketch lazlo-n-synn Boat Review and Purchase Forum 0 04-03-2001 01:09 PM
