Boom tents- Show 'em here. - SailNet Community
post #1 of 11 Old 10-01-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Winter's coming. Not all of us want to/can afford to haul or shrink-wrap.
I'm building a frame over the cockpit made of flexible electric conduit. A gray poly plastic stuff. I'll tie a covering to the frame. The goal is to make the slope sharp enough that snow will slide off, rather than pile on.
I don't have an aluminum slotted toe rail, so afixing the bases of the frame to the boat will be a minor challenge.
Show me what you got!
Alacrity, 1981 Tartan 33 #168
Ajax_MD is offline
post #2 of 11 Old 10-01-2012
Re: Boom tents- Show 'em here.
Sorry I don't have any pics to share but I use to do the same with my Newport 33. I used 1/2" NMC (plastic) conduit as bows that went side to side and into a 2 x with a hole to receive the end, then 3/4" as a ridge under neath and zip tied/ duct tap at each hoop. The only problem was and I corrected was the rack for and aft. Lines down to cleats helped a lot.
Also did one yr with 3/4 PVC water piping rigid with angle connectors and legs tied to the stanchions. That also worked well.
Peter
justified is offline
post #3 of 11 Old 10-01-2012
I used the electrical conduit also. I just bent it into an arch and tied it to the rail then to the boom or spinn pole to keep it in place. Tarp was already in place so the tubing pushed the tarp outward. Worked great last year....but a verrrry mild winter in Maryland.
I don't have a picture either.
Gary3675 is offline
post #4 of 11 Old 10-01-2012
MikeOReilly's Avatar
I've been using the plastic grey conduit for the arches many years now. I used to build a solid centre ridge spine using wood (2"x2"), and attache the conduit to that. A few years ago I started using 3/8" line as my spine instead. I've found this to be superior in that it allows the whole structure to be solid, yet quite flexible. It bends with the wind, dislodging any accumulated snow, and reducing the pressure on the fabric (cheap plastic tarp).
Why go fast, when you can go slow.
MikeOReilly is offline
post #5 of 11 Old 10-01-2012
chucklesR's Avatar
Custom cover
note it goes over the cap rail - saves the teak work
chucklesR is offline
post #6 of 11 Old 10-01-2012
Question Re: Boom tents- Show 'em here.
Can't you just clamp it to your stanchions somehow? Maybe hose clamp or 'U' bolts to the outside of your stanchions, then drap the cover over?
AirborneSF is offline
post #7 of 11 Old 10-01-2012
Barquito
Barquito's Avatar
I used elec conduit and found it a bit flexy. I put a 90 degree fitting at the peak and a 45 on the sides. The sharper peak kept snow from building on top. The conduit was flexy enough that I had to add a lot of support with rope (between ribs, etc.). Not a very good picture attached.
Valiant 32
Barquito is offline
post #8 of 11 Old 10-01-2012
Send a message via Yahoo to dacap06
You could but I don't think you'd want to. It tends to bend the stanchions.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #9 of 11 Old 10-02-2012 Thread Starter
Chastened
Ajax_MD's Avatar
Great responses guys. I hadn't thought of using a 2X2 (or 2X4) on the decks as the anchor point for the poles, nor had I considered elbows to give a sharper peak vs. just bending the conduit.
What's a good tarp material that isn't too expensive? I want something better than the blue poly tarp.
Ajax_MD is offline
post #10 of 11 Old 10-02-2012
Battered and Bruised
Silvio's Avatar
You might consider looking at trucking tarp suppliers online. Tarps made to cover wood stacks on a flatbed trailer are typical 18 oz. vinyl and hold up to highway speed winds day in and day out and have a lot of tie down points.
Here is just one of may suppliers Lumber Tarps - Heavy Duty Lumber Tarps Low Prices - Atlanta Georgia
SV S.S.R.I
It's my happy pill
Silvio is offline
Sailboat show continues through tomorrow, then transforms into powerboat show - Annap NewsReader News Feeds 0 10-09-2011 12:00 PM
Boom Vang vs Boom furling? Windkiller General Discussion (sailing related) 7 07-26-2011 07:27 PM
New Tartan and C&C Shoppers Boat Show Show Checklist 121Guy Boat Review and Purchase Forum 46 05-16-2009 11:53 PM
[New Video Out] The Boom Jack or Boom Vang Giulietta General Discussion (sailing related) 8 01-23-2008 10:33 PM
broken boom mid-boom sheeting problem? somedaypam Gear & Maintenance 15 10-23-2007 05:22 PM
