Best Anti Seize for aluminum saildrive zinc - SailNet Community
post #1 of 3 Old 10-03-2012 Thread Starter
Senior Moment
doubleeboy's Avatar
Hi All,
I will hauling out soon for maintenance and want to at that time change the zinc on top of Yanmar Saildrive. I want to use an anti seize that does not contain copper. Does anyone have a product suggestion available in USA for use with aluminum in a salt water environment?
Thank you for your help.
Michael
doubleeboy is offline
post #2 of 3 Old 10-03-2012
tommays's Avatar
Re: Best Anti Seize for aluminum saildrive zinc
Items like Perfect Seal Sealing Compound do a good job of keeping out the water in a neat way
Mercury 2-4-C grease also does good job in saltwater without galvanic issues
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 3 Old 10-03-2012
The quintessential anti seize compound is:
SAF-T-EZE Moly Grade Anti-Seize, Moly 50, Blue Moly and Dry Moly
it's conductive (good) and chemically inert so corrosion is not a factor.
Dick
Flybyknight is offline
Volvo Saildrive Zinc is loose Lidgard29 Gear & Maintenance 4 05-02-2010 10:04 PM
extra sacrificial zinc for saildrive ArgleBargle Gear & Maintenance 2 03-09-2010 05:33 PM
Saildrive Zinc Usage pics - appropriate or excessive in 8.5 mos? ArgleBargle Gear & Maintenance 3 06-01-2009 07:46 AM
Anit Seize for zinc on top of Yanmar Saildrive doubleeboy Gear & Maintenance 0 04-22-2009 12:30 PM
location of pencil zinc on Yanmar saildrive SD50 levenezia Gear & Maintenance 2 04-18-2009 10:07 PM
