Best Boat Snack - Page 5 - SailNet Community
 39Likes
post #41 of 58 Old 10-08-2012
Re: Best Boat Snack
McVities Milk Choc Hobnobs - 8.8oz (249g)
MarkSF is offline
post #42 of 58 Old 10-08-2012
Re: Best Boat Snack
Chris,
The hot water you wash dishes in does not kill bacteria. Nor does most dish soap. All you are doing is de-greasing and sloughing off the bacteria that may have landed on the dishes. Hot water and soap may aide he sloughing process, but does not kill the bacteria unless you are using an antibacterial soap. Which is going to create all sorts of problems down the road.
I always thought like you about mayonaise as does the Army, until a friend who spent a year cruising in the Bahamas explained that if you keep the bacteria out of the mayo it will never go bad, even if kept at room temperature. So she took a table spoon, wiped it with alcohol and then use it and only it to take the mayo out of the jar, quickly closed the jar and then spread the mayo on the bread. I thought this impossible, then remembered that when in Italy, they sold mayo in a tube, like toothpaste and never refrigerated it. So must work.
ccriders is offline
post #43 of 58 Old 10-08-2012
Barquito
Barquito's Avatar
Re: Best Boat Snack
Chris,
Plus a little common sense will go a long way. If there is stuff growing on it, or it doesn't smell right don't eat it. People have been eating eggs, for example, without getting sick for a lot longer than we have had refrigeration.
Valiant 32
Barquito is offline
post #44 of 58 Old 10-08-2012
Senior Slacker
SlowButSteady's Avatar
Re: Best Boat Snack
Dry smoked salmon (not salmon jerky, just dry to the touch)
Aged gouda (aged until it's almost crumbly)
REAL sourdough baguette (if you don't have to really chew, it ain't really bread)
Wash it all down with Peet's coffee (in the morning), or Liberty Ale (in the afternoon)
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #45 of 58 Old 10-08-2012
You really are funny!!
chrisncate's Avatar
Re: Best Boat Snack
Originally Posted by ccriders View Post
Chris,
The soapy hot water wash has got to be more effective than the cold water wash though (or god forbid the "wash the tops of the plates only" wash), no?
Regarding the mayo, it must be the oil that helps preserve it. I'd like to see that mayo in a tube, that's pretty cool!
chrisncate is offline
post #46 of 58 Old 10-08-2012
Re: Best Boat Snack
Originally Posted by DRFerron View Post
Deviled eggs (using one of those deviled egg containers works best of course, and they can be made ahead of time. I make two batches: the standard recipe and one that's different. My eggs with a bit of sun dried tomato, capers and a thin ribbon of prosciutto on top is always a hit.)
A good, soft buttery Brie and good crackers
Guacamole and chips (I take all the ingredients and prepare on board)
We make the Deviled Eggs but slice the white part crossways instead of lengthwise and use the original foam egg container as the transport/serving dish. Works great and no dishes to clean up.
Seaduction is offline
post #47 of 58 Old 10-08-2012
chef2sail's Avatar
Re: Best Boat Snack
We make the Deviled Eggs but slice the white part crossways instead of lengthwise and use the original foam egg container as the transport/serving dish. - Seaduction
Not a great idea. 98 % of egg shells have salomonella when they are collected. You are banking on that they have washed and sterilzed the outer shell. This is similar to the salmonella outbreak related to cantalopes...its whats on the skin getting everyone sick as they get the bacteria on the cutting board when the skin it and cutt up the flesh and then do not raise the temp over 165 degrees,
As far as mayo, right now there is a 12 page discussion on another Sailboat forum.
Mayo in a jar is far different from mayo in a tube. The bacteria which gets introduced is not just from utelsils, but is also in the air. It needs a medium to grow, usually of protein. Since no air will be introduced into the tube...thats fairly safe, but a jar inheretly has open space filled with air. Thats why most things need to be refrigerated after opening, but are ok stored on the self. Some of the "atmosphere" in these jards ( if its not a vacu,) may be a modified atmosphere.
Almost all of the bacteria which make you sick, salamonella, e coli, listeria, shigella etc, are not noticeable in food and have nothing to do with the slimy ness or mold on food, and they have nothing to do with the spoilage of food which was referred to above.
Many people claim they have never gottten sick from eggs, mayo no refrigerated after opening, peanut butter and they have been leaving it out. Thats has absolutely nothing to do with future bacterial incidents. You can speed down a stretch of road 99 times and never get caught, but the 100th time if a cop is there..you get the ticket. I would rather err on the side of safety and not make the one time you did get sick when you were 1200 miles off the East Coast, 10 days from land or a hospital. Why risk it. bacteria grows best in high proteinitems. It needs moisture, oxygen ( except botulism), time, temperature, the correct acidity ( commercial mayo has an increased acidity to help as a barrier). Food borne illness also affects nore easily the old, the very young, and those with compromised immunities far greater. What may give me the runs may kill someone one antibiotics or with diabetes.
Heat kills most bacteria thats why there are minimum internal cooking temperatures ( related to time) for most meats ( ie polutry 165 degrees for 10 seconds) reheats 165 degrees etc, however it must be noted it is not always the bacterial which can cause you to get sick. In some foodborne illnesses you can kill the bacteria with the proper temperature, but it has already produced a toxin ( poison) which then gets you sick. Food handling is a very important part of cruising and long distance sailing. Leftover must be treated very carefully and cooled quickly so as nokt to promote bacteria growth. The militray throws out almost all excess food from meals for this reason ( early in my career when I trained chefs who had been in the military I had to break them of this habit as it was wastefull). I understood why they did it though as they didnt want to risk gettibng a whole diviosn of fighting soilders sick because of not handling food correctly so they couldnt fight.
In terms of killing bacteia on dishes there are oinly two methods. Temeprature - commercial restaurants and your home dishwasher rinse temperatire must be over 180 degrees F. ( BTW soap works best between 130 and 150 degrees) and Chemicals_ tghis would be a solution of sanitizer to use after washing and rinseing dishes. The sanitizer must be in a correct concentration to work ( most are iodine or quantranery solutuions). If it is too strong it can be a poison. Then the dishes must be air dried.
MedSailor and chrisncate like this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #48 of 58 Old 10-08-2012
Closet Powerboater
MedSailor's Avatar
Re: Best Boat Snack
The Chef is right.
Luckily for me I grew up mostly in Australia where they don't have huge fridges that house EVERYTHING so I already have some experience with keeping condiments, eggs, mayo, and jams out of the fridge. On the boat, I prepare food just like at home. I don't try and skimp on the water or use salt water instead, I just do like I do at home. Oh wait, for the last 10 years the boat galley (with very tiny fridge) was my home!
Just in case we do it all wrong though I keep some Cipro on the boat. It'll usually kill all the baddies that Chef mentioned, except for Botulism, but that's a whole different story.
MedSailor
MedSailor is offline
post #49 of 58 Old 10-08-2012
Re: Best Boat Snack
Not washing the bottom of plates only contaminates the tops of plates they are stacked upon.
I have looked everywhere for Italian mayo, but alas, cannot find it here.
ccriders is offline
post #50 of 58 Old 10-08-2012
Re: Best Boat Snack
#1agree with the soft brie and crackers.
#2 If looking for minimal fuss, buy a bag of extra large/jumbo frozen shrimp. Bring bag with jar of cocktail sauce, in small cooler. Just before happy hour, run shrimp under cold water about 5 minutes to thaw the rest of the way... and serve. Always a big hit.
#3 this is what I bring when I have the ability to re-heat:
2 pounds kielbasa
one bottle of beer
18 oz BBQ sauce (your favorite kind)
1/2 cup brown sugar
1/4 cup dijon mustard
Combine beer, BBQ sauce, brown sugar, mustard in large skillet over medium heat. Bring to boil, stirring occasionally. Reduce to low, and add kielbasa, which you have cut into about 1/2 inch slices. Simmer one hour until the kielbasa is browned and glazed, stirring occasionally. Cool and refrigerate.
I make this the day before. bring it in a tupperware, and reheat just before happy hour until hot... either on stove, or in micro. Serve with toothpicks. Always the first appetizer that is gone! (maybe its the beer??)
Enjoy!
bobnpaula is offline
WANTED: BASIC BOAT BBQ. CHARCOAL IS OKAY, BEATUP IS OKAY, ANY BOAT BBQ - $25 seattle stephenronning Gear & Maintenance 2 03-30-2009 09:21 AM
Coast Guard finds missing boat, still searching for other boat - FayObserver.com NewsReader News Feeds 0 05-11-2007 11:15 PM
Coast Guard finds missing boat, still searching for other boat - Access North Georgia NewsReader News Feeds 0 05-11-2007 10:15 PM
Coast Guard Finds Missing Boat, Still Searching For Other Boat - WSOCtv.com NewsReader News Feeds 0 05-11-2007 04:15 PM
Coast Guard finds missing boat, still searching for other boat - Myrtle Beach Sun News NewsReader News Feeds 0 05-11-2007 08:15 AM
