how do i make it warm - Page 2 - SailNet Community
 18Likes
post #11 of 64 Old 10-10-2012
emoney's Avatar
Re: how do i make it warm
Heating on a boat is one thing a person shouldn't cut corners on, budget or no budget. Just remember, that dying doesn't cost anything either, so before you go burning something below, make sure it was designed to be there (i.e. it's vented properly). Outside of that, dress in layers.
emoney is offline
post #12 of 64 Old 10-10-2012
Chastened
Ajax_MD's Avatar
Dude I understand the budget limitations, really I do. However, cobbling something together that uses an open flame, burning who-knows-what for fuel, in a sealed cabin is a recipe for disaster. You'll either gas yourself to death or burn the boat down to the waterline.
You're up against some hard limitations:
1. You'll eat up batteries fast, using them to power any kind of heater.
2. You have no means of charging the batteries anyway.
3. You have no money.
4. You have no supplies.
This leaves you with needing some kind of SAFE, flame heat, and needing donations.
Using a stove for heat works poorly because the heat is concentrated at a single point for cooking, and not circulated around the boat.
I recommend you check here:
Freecycle.org
Someone may have something you can use.
If you can get a small gift of cash, I recommend these:
Origo Heat Pal
Coleman Black Cat Heater
The Black Cat is great because it's flameless and the exhaust is catalyzed so you won't gas yourself. Just make sure you have an adequate flow of air into the cabin so that the oxygen level doesn't get too low. I doubt your cabin seals that tightly anyway.
The best option would be to get to a dock that has 110v ac power and use an oil-filled electric radiator heater. They cost about $40.00.
jameswilson29 likes this.
Alacrity, 1981 Tartan 33 #168
Ajax_MD is online now
post #13 of 64 Old 10-10-2012
I would want something that can be run while sailing, so you could go down below to warm up periodically and therefore extend your sailing season a bit.
I am unsure how the alcohol heater can have 5000 btu's but the propane only 3000... and which would be safer...
So the black cat doesn't release CO and CO2? You can't gas yourself with it? How is this possible?
peterchech is offline
post #14 of 64 Old 10-10-2012
Skipper Jer's Avatar
Slightly off topic but necessary info:
"Women tend to be more expensive.
A good Lab will dive into frigid water to fetch a stick, haven't met a girl yet who will do that for me. "
A good test is to lock both the woman and the dog in the car trunk for a few hours. When you open the trunk note which one is happy to see you. Keep that one.
If you are going to burn stuff in the cabin to keep warm get either a carny bird or a CO monitor. You don't want to wake up stiff.
Skipper Jer is online now
post #15 of 64 Old 10-10-2012
Chastened
Ajax_MD's Avatar
As I said, it's a catalytic heater. It uses a sort of catalytic converter to convert CO into CO2, and the CO2 is kept at safe levels by ensuring an adequate oxygen supply. The effect is similar to what happens in modern car exhaust systems. I'm not saying it's harmless and to abandon caution. I'm saying it's safer than a lot of other options.
Link:
GearReview.com - Coleman Black Cat Heater
post #16 of 64 Old 10-10-2012
Blue Horizons
Harborless's Avatar
Well if you want to be cheap and stay warm just go find loads of plastic and wrap your boat. It creates a greenhouse effect.
Of course, once the sun goes down..
Harborless is offline
post #17 of 64 Old 10-10-2012
tommays's Avatar
FIRST OFF To have have HEAT and NO Carbon monoxide (CO) Detector is just INSANE and STUPID
As it just got cold here i am expecting the first death by CO any day now in the paper as we get them every season on land and water
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #18 of 64 Old 10-10-2012
I know there is a guy who sails his modified 22' boat from the northern UK to greenland, iceland, and the arctic almost every year. He has no heater in the boat, but has insulated it with the pink foam stuff and that is enough to keep him warm in the arctic. Very small, heavily modified boat, but still the insulation has to help... not $0 though haha...
Introduction to the junk-rigged Corribee Mingming
post #19 of 64 Old 10-10-2012
The catalytic process produces water vapor, could there be a moisture issue there?
I had a leaky propane bottle in my boat one time, I was able to smell it and discard it but these things do happen. Would a CO monitor, kept low in the cabin, be able to detect leaking propane gas before it builds to a dangerous level?
post #20 of 64 Old 10-10-2012
Fires are problematic and "cheap" rules out fuels in general.
And forget any kind of alcohol heater, the amount of water vapor they product will be truly memorable.
I'd really suggest layering up in some warm clothes from the thrift store. A good wool watch cap (or two) and insulated boots, moisture-wicking long johns, and you've got the safest cheapest solution.
hellosailor is offline
Thanks for the warm welcome, bentwire General Discussion (sailing related) 27 10-08-2013 04:36 AM
How to keep warm sailing in ice Jon Amtrup SailNet FAQ 3 10-10-2011 01:41 PM
VHF Suddenly needs to warm up?? L124C Electronics 5 04-25-2011 11:21 AM
Fl to vi or somewhere warm just not really a destination svnailedit Crew Wanted/Available 2 02-27-2010 04:42 PM
Staying Warm and Dry at Sea YachtRacerMan Gear & Maintenance 63 03-11-2008 03:33 PM
