Like Tree9Likes
  #41
Old 10-14-2012
smallboatlover's Avatar
Huck
smallboatlover is on a distinguished road
Re: how do i make it warm
im using candles right now
16' mistral sailboat, And 27' coronado
  #42
Old 10-14-2012
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
SBL .... someone mentioned very early on the ceramic pot upside down on a fuel stove (alcohol or kerosene). This method has been a staple of yachtsmen in Australia (and yes there are bits of Oz that get cold) for ever and a day. Not so good with an LPG stove (too much moisture for one) but with alcohol you will be surprised how effective. Steal one from you parent's () garden.
The other cheap alternative is a kero or oil lamp. We had one on our old boat and it was only this weekend I got round to fitting it to the new girl. As it happens Saturday was a cool evening and rather than fire up the diesel heater we lit the oil lamp. Takes the chill off the air and provided you don't want tropical temps it works a treat. (Second hand oil lamps are probably better than new. The new ones that I've had the misfortune to buy have leaked. Reality is they are made to be ornaments.)
Both alternatives will cost you from zip to just a few bucks.
  #43
Old 10-15-2012
dylanwinter1's Avatar
dylanwinter1 is on a distinguished road
tea lights
first try a plate of five or six - or more - tealight candles
you will be amazed at how much heat they give off
and then the other thing you can do is to cut heat loss
try this
https://www.youtube.com/watch?v=cbYSgDnbeDc
insulating the windows really makes a masive difference
Dylan
  #44
Old 10-15-2012
Minnewaska will become famous soon enough
Originally Posted by CarbonSink62 View Post
The new plan:
Amazon.com: Mr. Heater F232000 MH9BX Buddy 4,000-9,000-BTU Indoor-Safe Portable Radiant Heater: Home & Kitchen
Twice the money ($US75 vs. 35) but has a low O2 sensor and a 'tipped over' shut-off.........
I got one of these a couple of years ago. They come in a variety of BTUs, but mine also has the dual 1lb propane tank holders. I wanted it for the dead of winter, to do some projects in the cabin. With the hull of the boat at 30 degrees, it simply would not dent the interior temperature. I had it running so hard, the tanks were icing up from the rapid gas expansion. Nothing. The boat itself, was essentially a huge heat sink.
Jeanneau 54DS
  #45
Old 10-15-2012
chef2sail's Avatar
chef2sail will become famous soon enough
We use this in the fall to take the chill off the cabin when anchored out. No running it when asleep. Vent the cabin a little. Also don't store or leave 1lb bombs connected or otherwise in the cabin. They go outside or in the propane locker as I have seen the valves stick open and sometimes freeze up
Camping Gear, Camping Equipment, Coleman Camping Tents, Discount Outdoor Camping Supplies | CampingComfortably › Tent Heaters
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #46
Old 10-15-2012
.....Also don't store or leave 1lb bombs connected or otherwise in the cabin. They go outside or in the propane locker as I have seen the valves stick open and sometimes freeze up.....
This is particularly true after using them in a heater, which draws so much fuel that the gas expansion does freeze the valve. This is all the more likely when ambient temps are very low. Do not remove the tanks from the unit until they thaw.
Jeanneau 54DS
  #47
Old 10-15-2012
Brent Swain is on a distinguished road
I've seen some very effective airtight woodstoves built out of old propane bottles.
Brent Swain, Yacht designer, Builder, and author of "Origami Metal Boatbuilding"
  #48
Old 10-15-2012
peterchech is on a distinguished road
How does that work?
  #49
Old 10-15-2012
Jgbrown is on a distinguished road
Basically just using the bottle as the body of the stove, think 20lb propane cylinder. Cut a hole in the top add air intake and door and off you go. Not a bad idea so long as the cylinder is well vented first. A precaution friends used to take was to remove the valve assembly, after letting it sit for a week or two put it on a fire for a while to burn off paint and any propane.
Huck: Home
check out the Kandle Heeter. Eccentric guy, but the multiple pots over a candle or two makes a lot of sense, will trap and release heat very efficiently.
The link there shows how to make it pretty easily I think.
I'll be making a ducted version of the heat stick, drawing hot air from the cabin top and circulating it at foot level, but that only works when you've already got heat in the cabin.
  #50
Old 10-17-2012
Originally Posted by Captainmeme View Post
Slightly off topic but necessary info:
"Women tend to be more expensive.
A good Lab will dive into frigid water to fetch a stick, haven't met a girl yet who will do that for me. "
A good test is to lock both the woman and the dog in the car trunk for a few hours. When you open the trunk note which one is happy to see you. Keep that one.
If you are going to burn stuff in the cabin to keep warm get either a carny bird or a CO monitor. You don't want to wake up stiff.
You prefer the company of a companion dense enough to jump into cold water to fetch a stick, over someone with a brain bigger than a golf ball?
Interesting!
You prefer the company of a partner dense enough to be happy to see you after you have locked her in a trunk for two days?
Intellectually challenging!
You prefer have your intellectual conversations with an animal who cant dispute what you are saying?
That's cheatin!
Does your dog ever cook you breakfast, brew a cuppa coffee for you when you come in from the cold, take the helm while you do a sail change, help you reef, wash your clothes, stand watch while you get a bit of sleep, help you get the anchor up on a stormy night, and help you shop?
Wow , smart dog!
Does your dog ever release your frustrations when you get feelin passionate in your bunk?
Now that's creepy!
You may post attachments
You may edit your posts
Thanks for the warm welcome, bentwire General Discussion (sailing related) 14 05-31-2012 02:01 AM
How to keep warm sailing in ice Jon Amtrup SailNet FAQ's 3 10-10-2011 01:41 PM
VHF Suddenly needs to warm up?? L124C Electronics 5 04-25-2011 11:21 AM
Fl to vi or somewhere warm just not really a destination svnailedit Crew Wanted 2 02-27-2010 04:42 PM
Staying Warm and Dry at Sea YachtRacerMan Gear & Maintenance 63 03-11-2008 03:33 PM
SEO by vBSEO 3.6.1
