What I learned at the Annapolis Boat Show - Page 10 - SailNet Community
 46Likes
post #91 of 96 Old 10-16-2012
Re: What I learned at the Annapolis Boat Show
Originally Posted by ronbo1
I was disappointed that Island Packet's new Blue Jacket wasn't available yeti. Though the economy is still sluggish IP may be positioned for the recovery.
Ronbo
Originally Posted by JonEisberg
Well, you could have just had a look at the Tartan 4000 instead, the 2 boats are strikingly similar... Aside from the addition of a Hoyt jib boom, and shaft propulsion in lieu of a saildrive, there's very little apparent distinction between the two...
Jon, Similar? What do you mean? it seems to me that the only thing in what they are similar is the Length and the draft.
The hulls are completely different, Blue jacket is a lot less beamier, it is even narrow for a modern 40ft. It has less 20cm of beam than the Tartan and that is a lot in a 40ft.
The Blue Jacket is also 1300kg lighter and the is a huge difference in a 40ft sailboat.
The BlueJacket has a substantially superior B/D ratio (0.369 to 0.326).
In fact the boats will have a very distinct behavior in the water, being the Bluejacket a faster and better upwind boat, with a more comfortable sea motion. The Tartan will be more stable downwind and will sail with less heel.
All very good points, Paolo - you're right, of course, there are significant differences between the two...
What strikes me, however, is the visual similarities to the boats, and how closely they resemble one another to my eye...
The portlights in the deckhouse, for example - virtually identical... 2 smaller forward, 3 slightly larger, one smaller aft... The cockpits, with the twin canted pedestals, and fold-down transom steps, very much alike... The rigs are quite similar, I can't think of any other American builder currently offering that rig, with the Park Avenue boom, German mainsheet setup, etc... Those are all things that were heretofore somewhat proprietary or unique to Tartan (again, at least among American builders), and now "imported" by Jackett to IP...
I agree that this looks like a very sweet boat, I'll be looking forward to seeing it, for sure... I've always loved Jackett's interiors, I think his use of angles really works, and certainly makes them more interesting visually. I don't get the twin aft staterooms on a performance-oriented boat, however, I much prefer the Tartan 4000 layout in that regard. And I'm really perplexed why the drawings show only 2 cockpit primary winches, what are you supposed to do with the mainsheet when you're flying the reacher?
Minor details, I know... What's most interesting about this boat, perhaps, is what it represents about the new direction IP is taking, and whether there really is a market share out there to be captured? In my observation, IP owners in general are not looking for performance, and to those more concerned with such, Island Packet is most definitely not the first "brand" that comes to mind... (grin)
JonEisberg is offline
post #92 of 96 Old 10-16-2012
Tartan 27' owner
CalebD's Avatar
Tartan was encapsulating the chainplates in FRP on the 27' back in the 1960's. I suppose it seemed like a good idea at the time, the thinking being that: "Moisture will never get in there." The current owners of these old boats know better. Moisture found a way in there and it turns out that stainless steel (no matter what alloy) will crevice corrode and even rust when surrounded by moisture without the presence of air. The SS bolts used to anchor the chainplates could rust badly and any wood used in the knee wall fabrication will turn back into soil.
I think that this is an inherently short sighted and bad design. How difficult would it be to have the chainplates mounted outside the knee wall with the bolts showing in the cabin?
SloopJonB likes this.
Everybody has one:
CalebD is offline
post #93 of 96 Old 10-16-2012
... And I'm really perplexed why the drawings show only 2 cockpit primary winches, what are you supposed to do with the mainsheet when you're flying the reacher?
I agree with you. I guess the two boats are aesthetically very conservative and are aimed to US clients that are supposed to be more conservative than Europeans or at least is what jackett thinks. well that is changing and I don't know if that is true anymore.
I don't like the old conservative look in any of the boats. It is not easy to manage to have a classic look in a modern boat. You have to know how to mix traditional elements with modern ones. In my opinion they have not succeed. This one looks a bit better than the Tartan that looks really funny with that big transom in classic disguise.
I have posted about the BlueJacket in the interesting boats thread and said the same thing you said about the winches. Sure, they have a kind of self tacking head sail but for the Geenaker or Spinaker they would need another pair of winches. I guess they sell it like that standard and if you want to have a geenaker (that evidently the clients of that type of boat will want) they will sell you two more as an option. That way the boat is apparently less expensive
post #94 of 96 Old 10-16-2012
You mean, like most builders do?
Well, than would not be a IP anymore They do things differently.
post #95 of 96 Old 10-16-2012
Originally Posted by Resolute_ZS View Post
While I agree with all your other points (I deleted them to save room), I have to disagree with this one. Bamboo is actually considered a hardwood in most flooring. Depending on the lay of the grain and methods of flooring, it can be harder than golden teak but not as hard as Brazilian. Still, I'd say it's no slouch when it comes to hardness.......
Perhaps there are different grades of bamboo. I concluded that because I have bamboo floors in our home and completely regret it. They aren't just scratched, they are actually dented by everything placed upon them. Since my boat takes much more abuse than my home, I don't think they would fair well. The big advantage of bamboo is it regrows extremely fast, so its considered sustainable.
Jeanneau 54DS
Minnewaska is offline
post #96 of 96 Old 10-17-2012
Crazy Woman Boat Driver
Melrna's Avatar
Location: Heading south down the US east coast to the Bahamas
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
Aluminium are you sure? It is not a good material for tanks. Why aluminium in an heavy boat and not stainlesssteel or even plastic?
What do you mean by no access do you mean you cannot inspect or clean them? That is hard to believe. Diesel tanks have to be inspected and cleaned regularly.
It is exactly what I mean. I could not find any access plates, Nada.
Melissa Renee
Moondance
Catalina 445, Hull #90
Melrna is offline
Annapolis Boat Show ? ImASonOfaSailor General Discussion (sailing related) 17 09-11-2011 08:35 PM
Annapolis boat show 10/14-10/17 davidpm General Discussion (sailing related) 4 10-01-2010 10:03 AM
What did you buy at the Annapolis Boat show Melrna General Discussion (sailing related) 40 10-18-2008 08:43 PM
Annapolis Boat Show...BAM? camaraderie General Discussion (sailing related) 3 08-29-2007 11:33 AM
Annapolis Boat Show jmunson2 General Discussion (sailing related) 30 10-17-2006 09:07 AM
