Question for those who sail cutters - Page 3 - SailNet Community
 16Likes
post #21 of 27 Old 10-14-2012
Re: Question for those who sail cutters
On the Tartan I saw at our local brokerage (and a similarly rigged Bene 40 in our marina) the forwardmost sail was/appeared to be a roller furled Asail - in which case there may not be a 'stay' there at all. Upwind work would be handled by the inner sail, when you peel off the wind you roll out the 'screacher' and carry on.
Tartan markets that arrangement as their "Cruise Control Rig"... A good arrangement in theory, but IMHO it primarily is a marketing deal, and their target market is those who never want to have to set foot out of the cockpit, and for whom "ease of sailing" tops the list...
A far better arrangement, seems to me, is simply to have the provision to fly a Code 0 from a free-flying furler whenever you want to do so. But of course, that entails a bit of actual "work - hoisting it, running the sheets, and so on... Many folks today would prefer to live with the considerable tradeoffs/downsides Rich H mentions, problems with headstay tension, the airflow over the self-tacker disturbed by the furled reacher, and so on...
One thing I really don't like about the permanent stowage of that type of sail on a furler, is the absence of a UV cover... You're not gonna put a UV cover on a light air reaching sail, and those sails are built to a rather limited wind range to begin with, the last thing you want to do is further weaken their construction and material by constant exposure to UV...
Seems like to prolong the life of the sail, you'd have to be routinely removing it from the furler, anyway... Stowing a reacher on a free-flying furler winds up being less "work", in the end...
But, the folks in the Marketing Department don't see it that way, so... (grin)
JonEisberg is offline
post #22 of 27 Old 10-15-2012 Thread Starter
JulieMor's Avatar
I've cruised and raced on sloops. That's all I know first hand. While I'm learning a lot about other rigs, I'm finding myself thinking the sloop just seems a lot less complicated and can get where you want to go just as safely as any other rig.
I realize having several sails hanging, ready to be furled or unfurled when needed, can make things easier but there seems to be a lot more in maintaining and even handling them.
I started sailing by hanking on whatever foresail we were flying. And stowing them, etc. And yes, they were good old dacron. But that was 30+ years ago. Today I'm thinking ease of handling and simplicity.
But right now I have to mow the lawn, rake the leaves, clean out the gutters, trim the bushes, put the flowers to bed for winter, paint a bedroom, clean the kitchen, do the laundry...
JulieMor is offline
post #23 of 27 Old 10-15-2012
casey1999's Avatar
Originally Posted by wingNwing View Post
Ours is a true cutter and we do what jrd does, fly the staysail to keep the jib from hanging up on the stay in a tack. We modified the inner forestay to be able to remove it and stow it against the lifelines when we're puttering about in the Chesapeake and doing lots of tacking; then we're just a sloop. What we love about the cutter is its flexibility - when the winds are heavier we roll up the jib and balance so sweetly with double-reefed main and staysail only.
wingNwing,
On your inner forestay, what counter-balances on the aft end? Do you have running back stays?
casey1999 is offline
post #24 of 27 Old 10-15-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Who would send a 4 year old child onto the foredeck?
JulieMor likes this.
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #25 of 27 Old 10-15-2012
Casey on my 37c I have running backs but not really necessary unless it's 25 plus knots of wind. Only then do they limit stay sag. Heavy mast section limits the need on my boat.
ctl411 is offline
post #26 of 27 Old 10-15-2012
formerly posting as eryka
wingNwing's Avatar
Originally Posted by casey1999 View Post
wingNwing,
Casey, We don't have a running backstay, we just have baby stays (a.k.a. intermediates) back & forward to handle the staysail loads in all directions. We have a split backstay, so turning that into a running backstay would be finicky. Our mast is so stout that we wouldn't be able to put in any mast bend in any case, it would just crumple. And in the final analysis, a 20,000+ lb boat that's only 33 feet long, that's built for the charter trade in the trade winds, isn't a racer anyway.
We're never the fastest boat, but who cares? Wherever we are, we're already home.
chef2sail, JulieMor and Bob142 like this.
Cinderella, CSY 33, Photo by Joe McCary
Regret for the things we did can be tempered by time; it is regret for the things we did not do that is inconsolable. - Sidney J. Harris
Shameless self-promotion - my blog for the Annapolis Capital newspaper:
still has some glitches to be worked out. Until then, I'm posting at:
and
! And a new project:
wingNwing is offline
post #27 of 27 Old 10-15-2012
fallard's Avatar
We have a sloop with a baby stay and running backstays which we only used on our 1700 mile delivery trip from Florida to New England. The baby stay was rigged for the offshore segments and turned the boat into a cutter.
We didn't have much of a problem tacking, but we didn't tack all that often, either, so the cutter rig is probably easy enough to handle on a long passage.
On the other hand, I've got several months' experience sailing cutter-rigged Island Packets in New England and the Virgin Islands. The Island Packets were not impressive for short-tacking. About a quarter of the time, the genoa would hang up in the slot. There were a couple of times when I turned the motor on to pass through the wind, which had as much to do with the modified full keel configuration. There is probably a learning curve for tacking a cutter rig, but it shouldn't be that big a deal.
That said, the cutter rig can be more comfortable (and stiffer) when the wind picks up, so it is all a matter of boat design compromise. I would disagree with an earlier blogger that the aerodynamics of a cutter rig are much different that that for a sloop. You need to manage the slot between sails in either case. In a tradewinds area, I would find the cutter to be worth consideration. In lighter air, I'll stick with a sloop rig.
wingNwing likes this.
fallard is offline
Prop/Shaft Cutters? T37Chef Gear & Maintenance 5 03-20-2010 06:54 PM
Bristol Channel Cutters welch Boat Review and Purchase Forum 8 05-14-2004 07:24 PM
45 CC cutters are the most popular cruising boats...huh? JohnDrake Boat Review and Purchase Forum 27 11-29-2003 08:37 AM
JeffH - Question on cutters el General Discussion (sailing related) 6 09-05-2003 06:50 PM
Sailing Cutters Stede Boat Review and Purchase Forum 6 06-10-2003 07:34 PM
