Reduction in anchor scope with chain use - Page 3 - SailNet Community
 5Likes
post #21 of 21 Old 10-17-2012
Re: Reduction in anchor scope with chain use
Originally Posted by klem View Post
Line effectively provides no catenary so the angle of pull on the anchor is determined by the scope. In calm weather, chain provides catenary and the angle of pull on the anchor will be parallel to the bottom. However, in conditions that actually test the holding power of the anchor, the chain will be stretched out straight and the angle of pull will be determined by the scope, there is effectively no catenary in these conditions. Therefore, the holding power of the anchor is determined by the scope and is independent of what the rode is made out of unless you have ridiculously heavy chain (I am thinking of captaaron and his 5/8" chain on a <30' boat).
Keeping the loads down means providing some shock absorption in the system. Line is a good shock absorber because it is relatively stretchy. In calmer conditions, chain is an okay shock absorber because it has catenary. In stronger conditions, the chain is effectively a steel rod and it has virtually no shock absorption meaning that the loads are higher on the anchor. When you are in conditions bad enough to be testing the anchor's holding power, line will yield lower loads on the anchor.
In conditions that test your anchor, you do not need any less scope with chain than line. Since chain is a terrible shock absorber, you really need a good snubber in bad conditions. Chain still has other benefits such as chafe resistance, easier setting, etc so we shouldn't go out and ditch all of our chain but this rule of thumb is totally bogus.
On windy conditions I use two mooring lines connected to the chain by shackles. The lines have big rubber shock absorbers, the kind that have the line passed several times around. That system provides a good shock absortion especially with waves, making also the live aboard more comfortable on those conditions.
Anchor Rode and Scope for Marker Buoy jetdrvr393 Gear & Maintenance 3 05-13-2012 02:00 PM
G5 5/16 HT Anchor Chain interlude44 General Discussion (sailing related) 4 12-21-2009 08:10 AM
Anchor Chain TxLnghrn Gear & Maintenance 9 12-24-2008 05:03 PM
Anchor chain geoffr98 Gear & Maintenance 4 07-29-2007 04:09 PM
anchor chain SteveCox Gear & Maintenance 11 07-22-2006 07:39 PM
