The sailing Gourmet and the legend of the egg banjo - SailNet Community
 5Likes
post #1 of 24 Old 10-18-2012 Thread Starter
dylanwinter1's Avatar
I just thought that you ought to know....
the next time you eat a fried egg sandwich
there is a story
and if you can engineer it correctly it can offer great pleasure to both the consumer and the spectator
so I made a short film
the galley box also puts in an appearance
dylanwinter1 is offline
post #2 of 24 Old 10-18-2012
First String
Re: The sailing Gourmet and the legend of the egg banjo
Thats well done. HAHAHAHA
ltgoshen is offline
post #3 of 24 Old 10-18-2012
chef2sail's Avatar
Funny
Beware of the T Fal pans as the coating will come off in your food should you break the surface with any sharp utensil or scrubbing pad. In addition the are lightwieght aluminum.
I prefer the new age materials for pans Caphalon/ Analon/ Circulon as they need no spray and are way more durable as well as the mans heat evenly, Stainless steel is a far better and even conductor and you dont have to worry about leaching of aluminium when using acid foods.
Dave
SloopJonB likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #4 of 24 Old 10-18-2012
Tartan 27' owner
CalebD's Avatar
Mmmm! Runny egg yolk!
Funny bit Dylan!
Everybody has one:
CalebD is offline
post #5 of 24 Old 10-18-2012
JulieMor's Avatar
I was on a jobsite working out of an office trailer. One of the guys also working in the trailer often talked about having an egg sandwich in the morning. We started work at 6AM and he was up much earlier than his wife and so made the egg sandwich himself.
One morning he comes in and says, "My wife got up this morning before me and made me my egg sandwich. I was really pleased and thanked her a ton. Then I took a bite and out squirts the hot egg yolk all over the place!"
As I watched the video, I was waiting for that but didn't expect the egg banjo!
BTW: The guy at work didn't react calmly that morning and that was the last time his wife got up to make him breakfast.
JulieMor is offline
post #6 of 24 Old 10-18-2012 Thread Starter
Funny
Dave
I must have ingested acres of tefal over the years
is it toxic
although I have to say the pans seem better than they used to be
the one cal stuff is wonderful for the boat
Dylan
post #7 of 24 Old 10-18-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
is it toxic
Dylan
We didn't want to upset you but there are those of us who have noticed an increase in general winterish battiness that one surmises could be down to that ingestion of Tefal. I of course had it down to you being English.
Oh yes, and get rid of that aerosol can of spray oil. A refillable spray bottle is cheaper, more friendly and you get to choose your olive oil.
JulieMor .... you mean that fellow preferred hard yoke ? Now that is weird.
btw folks .... do go and check out Dylan's Nene vids. Lovely to see the Slug and the Beast two part harmony once again.
http://www.keepturningleft.co.uk/vid...ening-sailing/
There are a few of them.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #8 of 24 Old 10-18-2012 Thread Starter
not aerosol
just a squirty
so I shall replace the oil when it runs out
as for being barking.....
I am fine.... it is the rest of humanity that needs sorting out
incidentally
this is Ransom on sailors
“After all there are those who think that all men are mad who who go to sea when they could stay ashore, and that the maddest are those who, for pleasure, sail in boats of five tonnes and under, content with sitting headroom in the cabin and crawling headroom elsewhere. This is an arguable matter, with Dr Johnson on onse side and all small boat sailors on the other.
“”No man will be a sailor who has contrivance enough to get himself into jail; for being in a ship is being in a jail, with the chance of being drowned.” _ Johnson
But even the small boat sailors will agree that those of them who of choice sail single-handed are seldom ordinary men. They are of noticeably different texture, men of oak, not pliable. Their faith is is in themselves not in others. Their views are always their own. They do not search for precedents but make them. They are, in the best sense of the word, originals. There are no doubters among them. Whatever they do is best done the way they do it, and though all the world is of a different opniion, the World is wrong for they are right.”
Arthur Ranson
post #9 of 24 Old 10-18-2012
chef2sail's Avatar
I must have ingested acres of tefal over the years-dylanwintyer1
Calling Mr Dylan Winter-- you must have misremembered ( Clements) your name
The connection between aluminum in the brain and Alzheimer's Disease is so convincing that various studies are under way to explore whether aluminum in the brain can be removed, and if so, to determine if this would be beneficial for Alzheimer's patients. One fascinating study also reported in The Lancet, showed that by administering desferrioxamine, a chemical known to remove aluminum and other metals from the body, the progression of dementia associated with Alzheimer's disease was significantly slowed.
Be careful using aluminum pans
Heres the directions for using a T Fal Pan.
So, How to Take Care of Your Non Stick Pan?
Firstly Don't Cook on a high Heat
Blasting your pan with the highest heat setting can warp the pan itself and cause the teflon coating to crack and reduce performance when cooking. It will also burn your food, so keep the temperature low to mid and have perfectly cooked food that is not burnt. This will also reduce the amount of food residue that you have to clean off afterwards.
The Thermospot in my Tefal pan tells me when I have the correct temperature to cook with by turning a solid red colour, and this is usually around no 5-6 (out of 9) on my electric hob. A moderate temperature is sufficient because the pan distributes the heat evenly and prevents burning and staining.
Plastic Utensils & Storage
It may sound obvious, but don't use metal utensils when cooking in your non stick pan, and definitely don't cut anything with a knife in the pan. Once you scratch the surface it's the beginning of the end. I have a selection of plastic heat proof utensils, including tongs, and this way I am sure that I cannot scratch the pan.
I have a pot hanger on my kitchen wall and my non stick frying pan has it's own hook. If I do need to hang something else with it, I ensure they sit back to back so that another pan cannot scratch the surface. If you are short on space and have no other choice than to stack your pans, place a piece of kitchen towel, napkin or bubble wrap between each pan.
Cleaning
The absolute worst thing you could do to your new non stick frying pan is wash it in the sink with an abrasive sponge or scourer. You will scrub off, little by little, the protective coating of your pan and ruin it forever, and if you have a hot spot indicator in the centre of the pan it will no longer work. Luke warm soapy water and a nylon sponge should be sufficient. If you just wipe out the pan with a kitchen towel, residue may be left behind and that will cook the next time you use the pan and may cause staining.
After using the pan I like to boil the kettle, fill the pan with boiling water and then simmer on the hob (on a medium heat) for a few minutes. Rinse in the sink (if necessary using a soft cloth for stubborn residue) and then immediately dry with a soft cloth or kitchen towel. This seams to get rid of any oil or residue and keep the non stick surface scratch free.
Avoid the dishwasher. The detergents used can often be too hard and wear off the non stick coating on some pans, and if there are any scratches in the pan they will start to rust. Cleaning by hand is always best
Parkville, Maryland
Our blog-
post #10 of 24 Old 10-18-2012
tdw
tdw's Avatar
not aerosol
just a squirty
incidentally
Arthur Ranson
Just a squirty ? Good man, my sincerest apologies for the character assassination.
As for barking ... it is my personal opinion that complete sanity is somewhat overated. An acceptable level of eccentricity is called for.
re underlined bit of AR .... splendidly put. After all what would that silly old duffer Johnson know ?
― Terry Pratchett.
tdw is offline
The Gourmet (cough) Sailor tdw Provisioning 26 10-18-2012 01:25 AM
Vale WA sailing legend Rolly Tasker NewsReader News Feeds 0 06-23-2012 03:00 AM
Vale WA sailing legend Rolly Tasker NewsReader News Feeds 0 06-22-2012 03:00 PM
Does anyone know of any gourmet meats that do not need refrigeration lenl1540 General Discussion (sailing related) 34 12-03-2009 03:36 PM
New challenge for sailing legend (BBC News) NewsReader News Feeds 0 09-22-2006 06:15 AM
