water in boat - SailNet Community
Blogs
Old 03-12-2004
jrwright is on a distinguished road
water in boat
I am looking at first boat. It is 25 ft and has been tied to a fresh water dock for 9mths. It looks good but when I remove the floor There is water around the bildge pump in mid of the boat. the water is two little for the pump.
the boat is 1984 and has not sailed in about a year. is this a problem- it does not seem to be.
Thanks
Old 03-29-2004
sailnaway is on a distinguished road
water in boat
Sounds like that water may be wat the pump will not pickup. The boat may have a little water coming in around the shaft stuffing box and so you will always see a little but it should be an inch or less more is a sign that a little to much water is coming in. Haul the boat out befour you buy it and check the bottom. Ask the owner if the boat has any bottom damage watch the owners eyes and if the shift back and forth allot and his voice changes beware. Your normal bilge pump even if it has a check valve to stop backflow will leave a little water.Lift the float switch fith your fingers until the pump comes on then after a few seconds release it and you will see the water come back out the base of the pump.
Old 03-31-2004
Irwin32 is on a distinguished road
water in boat
Most boats get some water in their bilge which is why we put pumps there. If the boat has been sitting for a long time it will get water in the bilge from many sources. Some of these sources may be rain water tht can work its way into a bilge in countless ways. If the water you describe is all that has gathered in 9 months I would feel good about this boat - at least in this matter.
boat purchase, taxes, residence -- help for NW sailer? winslow59 Boat Review and Purchase Forum 15 01-14-2007 11:20 PM
what about water balast ? AbelCasillas1 Boat Review and Purchase Forum 10 08-15-2004 07:07 AM
water in boat jrwright Boat Review and Purchase Forum 3 03-13-2004 03:42 PM
looking for bare boat in warm water shipley Chartering 4 06-19-2002 01:05 PM
purchase boat checklist sailthechesapke General Discussion (sailing related) 6 08-27-2001 03:50 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
