Trying not to destroy engine controls - Page 2 - SailNet Community
 3Likes
post #11 of 15 Old 10-19-2012
Re: Trying not to destroy engine controls
Heheh. Trying to "peopleproof" controls is always a good trick. I knew a fairly expensive system where they moved the critical power switch "under the desk" so it couldn't be hit accidentally. Unless, of course, you had large legs and moved one just the right way, hitting the switch no one could see. Ooops.
What's the line from Ghostbusters? Don't pull that switch? :-)
Of course after you step on the ignition key and snap it off, you find out how easily any flat object can turn so many of them. I suppose that counts as a GOOD design, considering how hard it is to find a locksmith at sea.
hellosailor is offline
post #12 of 15 Old 10-19-2012
I don't understand the design of having controls by your feet. Along with the OP's issue, they are just simply harder to use when docking.
It may be too expensive, but I would seriously consider relocating it. If your controls can be mounted elsewhere, it may be as simple as relocating the cable or getting a new cable. If you need different control for mounting near the binnacle, there are many used controls available on ebay. Maybe more than you want to get into.
Jeanneau 54DS
Minnewaska is offline
post #13 of 15 Old 10-19-2012
Our (single lever) control is 'down by my foot' - I quite like it. I can shift and throttle with a foot, leaving both hands free for the wheel unlike binnacle mounted levers that generally have you reaching through the spokes of the wheel, possibly during a critical moment in the docking/turning process.
Faster is offline
post #14 of 15 Old 10-19-2012
To each his own, more power to you.
I dock standing aside my helm wheel, so I can reach the wheel and throttle without that problem.
Jeanneau 54DS
post #15 of 15 Old 10-19-2012
.. the fact that my cockpit is probably 1/3 the beam of yours at the helm will be a factor here, I reckon.....
Faster is offline
How to destroy a diesel in one easy step... MedSailor Diesel 43 09-28-2012 07:53 AM
Cal 34 engine controls pmt200 Cal 3 10-05-2010 11:34 PM
Engine Controls mikers Gear & Maintenance 5 05-19-2009 11:12 PM
Sealing engine controls against filled cockpit ? SvenG Gear & Maintenance 5 10-24-2008 12:55 AM
Dual station, single-lever engine controls Valiente Gear & Maintenance 5 07-17-2006 12:31 AM
