Trying not to destroy engine controls - SailNet Community
 3Likes
post #1 of 15 Old 10-18-2012 Thread Starter
Barquito
Barquito's Avatar
I have what is probably typical in a small auxiliary sailboat boat: The engine controls are on the cockpit foot-well wall. I am worried about smashing my choke lever, or starter button while we are heeling over, and I am putting my feet on the low side for support. Anybody else have problems with stepping on their controls when heeled?
Valiant 32
Barquito is offline
post #2 of 15 Old 10-18-2012
captflood's Avatar
Re: Trying not to destroy engine controls
GREETINGS EARTHLING cover it with a perspex door or a bit of wood AS ALWAYS GO SAFE
captflood is offline
post #3 of 15 Old 10-18-2012
If you can step on it, you will step on it. Or someone will step on it for you.
Get a nice piece of 1/4" plexi or something similar cheap from the local plastics guy's scrap bin. Cut it about two inches larger (so it overlaps one inch on all four sides) than the "well", secure with a sturdy hinge or piano hinge. Finding a good hinge will be the hardest part. Add a velcro dot on the bottom to keep it "stuck down" when it is closed, maybe another dot above it to hold it open as well.
Polish with suitable polish every once in a while to keep it from getting grungy.
HDChopper likes this.
hellosailor is offline
post #4 of 15 Old 10-18-2012
Send a message via Yahoo to dacap06
My thought was similar. The problem with hinges is that there may not be room to swing it as a door. I advocate cutting some slots in wood or starboard to make a frame and then cutting that plexi to slide down into the slots. Glue the wood to the footwell walls to form the vertical sides of a frame. The top is open, and the footwell would form the bottom A top down view of the setup would be like this:
Code:
_________________________________________________________________________________________________________
      |                  |          |__|                                     |                  |
      |                  |            |______________                        |                  |
      |                  |            |_______________                       |                  |
      |                  |              Throttle +Shifter                    |                  |
      |         | <----------------------Slide Plexi here --------------------------->|         |
      |         |                        Into Vertical Slots                          |         |
Whew! Doing ASCII art in the era of HTML is harder than it looks!
Regards,
Tom
Barquito likes this.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #5 of 15 Old 10-18-2012
Or some 1/4 ss rod stock, made up into two guard bars over the main body of it.
post #6 of 15 Old 10-18-2012
tommays's Avatar
Due to the big azz hole and NOT wanting a 12' choke cable i lived with Seafevers original location and as its all the WAY forward its done fine the last two years
The biggest item is the snap on sumbrella cover which protects it during the 99% of its life from UV when its on the mooring
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #7 of 15 Old 10-18-2012 Thread Starter
Barquito
Barquito's Avatar
I think maybe putting the starter button and choke into a recessed area would make sense.
Valiant 32
Barquito is offline
post #8 of 15 Old 10-19-2012
Senior Moment Member
SloopJonB's Avatar
Put a stainless tube guard over it - a stock single handrail might work. Measure the width of it and hit your local marine consignment shop for one the right size.
SloopJonB is offline
post #9 of 15 Old 10-19-2012
Stepping on (and snapping off) the key is the worst thing that can (has) happened!!
This is our current setup.. nicely done but having a custom cover made to replace the opaque one was pricey!
Faster is online now
post #10 of 15 Old 10-19-2012 Thread Starter
Barquito
Barquito's Avatar
"Luckily", there is no key. My ignition switch is in the cabin.
Ahh. That sounds like a good idea! Plus, it will give me something to grab next time I am knocked down to port.
Valiant 32
Barquito is offline
How to destroy a diesel in one easy step... MedSailor Diesel 43 09-28-2012 06:53 AM
Cal 34 engine controls pmt200 Cal 3 10-05-2010 10:34 PM
Engine Controls mikers Gear & Maintenance 5 05-19-2009 10:12 PM
Sealing engine controls against filled cockpit ? SvenG Gear & Maintenance 5 10-23-2008 11:55 PM
Dual station, single-lever engine controls Valiente Gear & Maintenance 5 07-16-2006 11:31 PM
