Xantrex Freedom HF 1800 Help Please - SailNet Community
post #1 of 4 Old 10-19-2012 Thread Starter
Sailboat Reboot
svzephyr44's Avatar
Send a message via Skype™ to svzephyr44
I have a Xantrex Freedom HF 1800. I recently acquired a transformer that is changing the 220VAC European shore power to 110VAC. Actual measurement on the 110VAC side is more like 127VAC. Of course it is still 50 cycle rather than 60 cycle. The transformer is rated for 4,000 Watts - more than the 30 Amp shore 110VAC.
My problem is that the unit senses the shore power (the yellow light flashes) but will not switch over to start charging the batteries. I have found no useful information on the Xantrex site.
Any ideas?
CAPT Roger J. Jones USN (ret.)
Sailboat Reboot
411 Walnut Street, #9700, Green Cove Springs, FL 32043-3443
Reboot's Agent's Email:
Web Site:
Blogging:
Twitter @Sailboat_Reboot
svzephyr44 is offline
post #2 of 4 Old 10-19-2012
Bali Hai
mgraham49's Avatar
Send a message via Skype™ to mgraham49
If you reach the point that you need professional advice, I have used Tekris Power in New Jersey (I am in Texas) for rebuilding and diagnosing problems. I worked with Chris there and he would literally let me take iPhone pictures of the control panel for my xantrex 2000 and message them to him while we were on the phone to diagnose. Really great people. I finally got tired of the old one and bought a new 3000 from them.
mgraham49 is offline
post #3 of 4 Old 10-21-2012
Ask Xantrex if it will work on 50hz. The manual states it will only switch over if the power is within specification and it states 60hz as the input a.c. specification.
KBuckley is offline
post #4 of 4 Old 10-21-2012
Re: Xantrex Freedom HF 1800 Help Please
If you could get the transformer (which is probably an autotransformer) to put out like 105v that would be better if you want to plug in things like motors and transformers which are designed for 125VAC max at 60 cycles. You have to drop the voltage (to be precise after subtracting the resistive voltage loss in the coils from your calculation but you can ignore that) by the same amount that you lower the frequency. So a 125VAC 60 cycle refrigerator would work safely at 104VAC on 50 cycles. The same applies to transformers and any other inductive load.
For a transformer or motor that normally draws 3 amps, you should lower the voltage until it does not draw more than 3 amps when hooking it up to 50 cycles.
Having 127VAC which is slightly above the limit and then having 50 cycles instead of 60 cycles could be a problem.
steel is offline
Xantrex sucks - What replaces an Xantrex Echo-Charger? jarcher Gear & Maintenance 20 07-24-2012 10:03 PM
Xantrex/Heart Freedom 25 -- How to connect Water Heater Bene505 Electrical Systems 64 10-25-2010 12:19 PM
xantrex freedom marine 1500 inverter/charger issues ncstatesailor Gear & Maintenance 1 04-09-2010 07:57 PM
I need a Xantrex Freedom remote panel, Link or Standard, Used or ugly OK TommyboySD Gear & Maintenance 0 04-22-2009 07:33 PM
Jrc 1800 Cp PCSSailor Gear & Maintenance 0 01-31-2009 04:08 PM
