Re-powering question??? - SailNet Community
 1Likes
post #1 of 11 Old 10-19-2012 Thread Starter
Chefuno
Re powering question...Can any one suggest a budget minded replacement motor to replace an old Volvo Penta MB10A in 1974 Grampian 30. New diesels seem to be out my price range. Rebuilt is an option so are new or rebuilt gasoline engine. The motor that's in the boat will probably run, I just don't want to rely on a 37 year old motor. Thanks in advance.
chefuno is offline
post #2 of 11 Old 10-19-2012
tommays's Avatar
Re: Re-powering question???
In gasoline you only have and Atomic 4 which i own and like BUT i cant see going form diesel to gas as making much sense ?
In diesel we have had a BETA in my friends boat for over 10 years as he was one of the early USA users and it is a very nice unit
The ONLY issue i have really seen with older units is if there Saltwater cooled at some point the block reaches a fatal level of rust and Volvo parts do have a gold plated price
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 11 Old 10-19-2012
chef2sail's Avatar
Replacing engines with other models will entail some tweaking. Probably differing props, angles , mounts, tyrannies etc. not just an easy swap. I am not a fan of volvox because of parts and availability.
How many hours on current engine. It may pay to have it removed and major rebuilt than repower. Diesels get 10,000 hrs easily if taken care of. Our 3GMF Yanmar has 3000 hrs and is 30 years old and purrs along fine.
Dave
HDChopper likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #4 of 11 Old 10-19-2012
caberg's Avatar
I'd get the current motor evaluated by a mechanic before tossing it out. My Yanmar 1GM is 31 years old and it runs strong.
caberg is offline
post #5 of 11 Old 10-19-2012
overbored's Avatar
the cost and hassle to repower would be much more then the overhaul of the penta. the engine has lasted 37 years so far and if it was rebuilt it should last another 37. I doubt there is anything wrong with the engine if it runs. takes a lot to kill that engine. it is the accessories like alternator and injection, exhaust elbow that will cause most problems. changing to gasoline would not make since and there would be an added cost of the safety blowers and equipment. it will also lower the resale value
"GOLD RUSH" PRINDLE 16
overbored is offline
post #6 of 11 Old 10-19-2012 Thread Starter
Chefuno
Lets assume that the motor is fine for now. I understand that Volvo no longer supports this MB10A (gasoline) engine. Are parts available for a rebuild?? Kits??aftermarket??
chefuno is offline
post #7 of 11 Old 10-19-2012
Senior Moment Member
SloopJonB's Avatar
Replacing engines with other models will entail some tweaking. Probably differing tyrannies Dave
Now THERE is a wonderfully Freudian typo. A different engine will definitely be tyrannical in different ways.
SloopJonB is offline
post #8 of 11 Old 10-19-2012
caberg's Avatar
Ah, it's a gas engine.
Anyway, I'm sure parts are available even if that particular model is not still made. Just google your particular model number and I'm sure some info will come up.
Not sure what your needs are, but some people on a tight budget pull the inboard and hang an outboard off the back. Not ideal, but it'll get you in and out of the dock or mooring if that's all you need to do.
caberg is offline
post #9 of 11 Old 10-19-2012
Although there are those in the sailing community that would probably look down their noses on this approach, there's some real wisdom in that statement.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #10 of 11 Old 10-19-2012
caberg's Avatar
Of course!
I have to admit that I'd hate to lose my inboard and go with an outboard, but if it meant getting on the water vs. not getting the water, then it's a pretty simple decision.
caberg is offline
Re Powering a Cal 39 DavePed Cal 6 06-16-2014 06:49 PM
Powering PoE Wi-Fi Device labatt Gear & Maintenance 5 10-21-2008 10:56 PM
Re-Powering Advice kptmorgan04 Gear & Maintenance 46 01-29-2008 08:10 PM
Thinking of re-powering?..... RickLaPaz Gear & Maintenance 7 07-12-2007 11:03 PM
I am re powering which engine obiec Gear & Maintenance 7 08-08-2003 09:43 AM
