Doyle "StackPack", Quantum version or other? - SailNet Community
 2Likes
post #1 of 24 Old 10-21-2012 Thread Starter
I would like to get some feedback on who makes the best mainsail handling package.
I have read negative comments on the Doyle system. I spoke to a fellow at Quantum that says their system is superior.
Anyone have any experience with either of these systems or another one that I may not be aware of?
Thank you in advance for your comment(s),
Nauti Jo
NautiJo is offline
post #2 of 24 Old 10-21-2012
jackdale's Avatar
Re: Doyle "StackPack", Quantum version or other?
I do not like stack packs in general. Just use stowable lazy jacks and a real sail cover.
jackdale is offline
post #3 of 24 Old 10-21-2012
bigdogandy's Avatar
Dock
What kind of boat do you have and what kind of sailing do you do?
I don't have lazy jacks or a stack-pack type system on my boat and I single hand all the time with (mostly) no problems. I am contemplating getting lazy jacks, though. I had a friend that put a stack pack on her boat and it sdeemed to me it was more work than it was worth.
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #4 of 24 Old 10-21-2012
I have a Doyle stackpack and it works absolutely great. May be different if you are crossing an ocean but for what I do (daysail, weekends) it is perfect. Rather than messing with a cover, I zip it open and am ready to go.
MastUndSchotbruch is offline
post #5 of 24 Old 10-21-2012
flyingwelshman's Avatar
I'm thinking of adding a stack pack - I currently do not have a lazy jack system.
What is it about stack packs that you don't like?
1989 Hunter 30'
Southern Georgian Bay
Visualize the vastness of the oceans; the infinity of the heavens; the fickleness of the wind; the artistry of the craft and the frailty of the sailor. The oneness that may be achieved through the harmony of these things may lead one to enlightenment. - Flying Welshman
flyingwelshman is offline
post #6 of 24 Old 10-21-2012
Courtney the Dancer
jrd22's Avatar
We have a stack pack type cover and love it. We had stowable lazy jacks and a regular cover but for short sails it was a hassle so we would leave it on and just roll out the headsail (I know, lazy, but that's reality). Now I use the main all the time because it's so easy. I also like the fact that when cruising for several weeks we cover the main every time we drop the hook instead of leaving the cover off because we'll be sailing again the next day. I can't recommend which brand to get, I see a lot of Doyles out there. I let a local canvas guy convince me he could build a good stack pack but it didn't turn out very well. It works OK but there's a lot wrong with it too. I wouldn't have one for ocean crossings (stowable lazy jacks are the way to go) but for anything else I think they're great.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #7 of 24 Old 10-21-2012
jackdale's Avatar
The boat I am using for instruction frequently has a Quantum stack pack.
It has two lines on each side to adjust once the sail is up: one line to adjust the forward part of the pack and another to ease the lazy jacks. So much for doing everything for the cockpit.
When reefing the stack pack prevents me from seeing if the luff tack line is at the gooseneck and whether or not the leech line is taut.
The lazyjacks lines make raising the sail a PITA as you have to monitor the battens so that they do not get caught.
The seams have ripped on the stack pack.
The zipper has broken.
The line that is used on the zipper has failed.
The last 3 I attribute to UV damage which cannot be helped.
It is incredibility inconvenient.
BTW - covering the sail when at anchor is not a good idea. If I want to use my sail, I want it now. In addition there is little UV damage at night.
I have also used Doyle stack packs - did not like them either.
Another BTW - when was the last time you had a salesman recommend another company's product.
I like a balanced boat; the first sail to go up the main. It is also the last to come down.
The sail cover comes off the dock and goes back on at the dock. The main halyard goes on at the dock and comes off when back at the dock. That is prudent seamanship.
saillife and Argyle38 like this.
jackdale is offline
post #8 of 24 Old 10-21-2012
I have a Dutchman system with a standard sail cover and love it for me. However. the Doyle system works and is definetely the easiest out there. That or variations of what they started. If you are a day sailor that does some short trips it is a great system that saves time at the beginning and end of the day. If you are a racer you don't want lazy jacks, Dutchman, or Doyle, you want to take those expensive sails off and care for them.
tomandchris is offline
post #9 of 24 Old 10-21-2012
Dock
I have a stack pack now, had a Dutchman on my prior boat. Neither is perfect or effortless, but both are pretty convenient. I much prefer a system of that kind that I can easily singlehanded than trying to deal with a sail falling all over the cockpit. I usually do need to go to the mast to get the main down all the way, but it is pretty helpful.
tweitz is offline
post #10 of 24 Old 10-22-2012
chef2sail's Avatar
We havea Quantum full batten main, Strong Track system by Tides and EZjacks( not Lazy Jacks). No modifying cover, no extra holes in the sail . EZJacks are unde and pulled back t he mast when you raise the sail and can be deployed in less than 1 minute FROM the COCKPIt before dropping the sail. I o a fir amount of singlehanding on our C&C 35MKIII and its an easy and Safe way to owner the main.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
VIDEO: Coast Guard Academy Welcomes "Blue Goose" and "Stormy Petrel" - Patch.com NewsReader News Feeds 0 07-28-2012 07:50 AM
Nautical version of "Finding Waldo" fullkeel7 General Discussion (sailing related) 5 06-03-2009 04:53 PM
Headsail choices - the "UPS" by Doyle Zanshin Gear & Maintenance 1 01-04-2008 01:55 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
