I think right now you are being a bit of an alarmist.
Then I'm not communicating very clearly, or perhaps you mean the computer model graphic is alarming, which is how I feel and why I posted it. I have not made a forecast, nor indicated that I believe it will happen. Since all the other tropical storms went out to sea I expect this one to follow the pattern. However, upon returning from getting my sailboat out I was shocked to see the graphic I posted at the start of this thread. I wanted others to be aware of the possibility. That is a graphic I never want to see, but I would expect it in Sept. if it was coming, not almost Nov.
I have a paid premium subscription to accuweather. I feel that I should have been made aware that there was a
possibility of such a large storm forming and coming my way. It's not like a "partly cloudy" forecast, it's a potential serious storm that even if it comes close, or jump feeds a nor'easter, I want to know. I've been burned numerous times with the type of weathermen who only tell you what model they decide to use, and then we get clobbered by something that was on their screen but they decided we didn't need to know about.
Your long quote from weather underground is a good example of "weather speak". I detest it. Einstein said something like "if you can't explain it to a 7 year old, you don't understand it yourself". Of course, he only dealt in easy to understand subjects.
The graphic I posted is from the ECMFW which has been shown to be more accurate than the GFS. Our weather services generally follow the GFS blindly, often to the hurt of final users. If you think "weather underground" is giving insights beyond NWS, then you might be interested in comparing this NWS forecast (derived from the GFS) to the one you posted:
TROPICAL STORM SANDY DISCUSSION NUMBER 5
NWS NATIONAL HURRICANE CENTER MIAMI FL AL182012
1100 AM EDT TUE OCT 23 2012
THE CLOUD PATTERN OF THE STORM IS GRADUALLY BECOMING BETTER
ORGANIZED...WITH A LARGE CURVED BAND FEATURE EVIDENT OVER THE
EASTERN AND SOUTHERN PORTIONS OF THE CIRCULATION. USING A BLEND OF
SFMR AND FLIGHT-LEVEL WIND DATA FROM THE HURRICANE HUNTERS...THE
CURRENT INTENSITY IS SET TO 45 KT. THE UPPER-LEVEL OUTFLOW IS WELL
DEFINED OVER THE EASTERN PART OF THE CYCLONE BUT IS RESTRICTED TO
THE NORTHWEST. GIVEN THE ENVIRONMENT OF LOW SHEAR AND HIGH OCEANIC
HEAT CONTENT...SANDY IS LIKELY TO STRENGTHEN INTO A HURRICANE IN 12
TO 24 HOURS...AND THE OFFICIAL FORECAST IS CLOSE TO THE
STATISTICAL-DYNAMICAL LGEM GUIDANCE. THE INTERACTION OF THE
CIRCULATION OF SANDY WITH THE MOUNTAINOUS TERRAIN OF EASTERN CUBA
SHOULD CAUSE SOME WEAKENING. AFTERWARDS...THE DYNAMICAL GUIDANCE
SHOWS THE VERTICAL SHEAR INCREASING TO NEAR 30 KT WHICH SHOULD
LIMIT RE-INTENSIFICATION. AROUND DAY 5...THE GFS OUTPUT SUGGESTS
THAT SANDY WILL BE DERIVING ENERGY FROM BAROCLINIC SOURCES...AND
THE NHC FORECAST SHOWS THE SYSTEM AS POST-TROPICAL BY THAT TIME.
FIXES FROM THE AIRCRAFT SHOW A NORTH-NORTHEASTWARD MOTION...OR ABOUT
020/4. AS THE MID-LEVEL RIDGE TO THE NORTH OF SANDY GRADUALLY
WEAKENS...THE TROPICAL CYCLONE SHOULD MOVE NORTH-NORTHEASTWARD TO
NORTHWARD WITH SOME INCREASE IN FORWARD SPEED. IN AROUND 2-3
DAYS...THE TRACK COULD BEND A LITTLE TO THE LEFT DUE TO THE
INFLUENCE OF AN UPPER-LEVEL TROUGH JUST TO THE WEST OF SANDY. THIS
IS SHOWN MOST PROMINENTLY IN THE 0600 UTC GFS RUN...WHICH HAS
SHIFTED WESTWARD FROM ITS PREVIOUS SOLUTION. THE OFFICIAL TRACK
FORECAST IS NUDGED WESTWARD FROM THE PREVIOUS ONE IN THE 48 TO 72
HOUR TIME FRAME. THIS IS VERY CLOSE TO THE LATEST DYNAMICAL TRACK
MODEL CONSENSUS...AND ALSO SIMILAR TO THE FSU SUPERENSEMBLE
PREDICTION.
FORECAST POSITIONS AND MAX WINDS
INIT 23/1500Z 13.8N 77.8W 45 KT 50 MPH
12H 24/0000Z 14.9N 77.6W 55 KT 65 MPH
24H 24/1200Z 16.9N 77.2W 65 KT 75 MPH
36H 25/0000Z 18.9N 77.0W 70 KT 80 MPH
48H 25/1200Z 21.4N 76.8W 60 KT 70 MPH...ON NORTH COAST OF CUBA
72H 26/1200Z 25.6N 76.5W 60 KT 70 MPH
96H 27/1200Z 28.5N 74.5W 60 KT 70 MPH
120H 28/1200Z 31.0N 70.5W 60 KT 70 MPH...POST-TROPICAL
Me again, I hope it does go out to sea, but I make different decisions when expecting clear weather than I do if a huge storm is lurking nearby. I like to know about the lurkers, thought you might to.
