Winter storage - SailNet Community
post #1 of 6 Old 10-23-2012 Thread Starter
Winter storage
I need to store my S2 7.0 outside this winter, (Wisconsin). Is it acceptable to use the mast, laid on the deck, to suppport a tarp? I will have it supported in three places and the tarp will drape over the mast, the life lines and down to the trailer. The angle of the tarp is steep enough that snow should not accumulate. From what I have read, I must have one of the very few remaining 7.0's in existence and I am doing all I can to preserve it. Thanks for the help, I am sure I will be back with lots more questions. Carl
Carl W is offline
post #2 of 6 Old 10-23-2012
timangiel's Avatar
Re: Winter storage
It should be ok. How do you like your S2?, I have an 8.0B
timangiel is offline
post #3 of 6 Old 10-24-2012
Re: Winter storage
IF the angle is actually steep enough to shed rain/snow, then it will be fine. The problem usually is that the angle between the mast and the lifelines isn't steep enough, rain or snow builds up, and the stanchions either rip through the tarp, or the weight of accumulated water rips the stanchion off the deck.
So again, IF the angle is steep enough, or IF the tarp is pulled very tight (and tied down every which way so that it won't loosen through the months of blustery winter weather), then it will be fine.
NateCP16 is offline
post #4 of 6 Old 10-24-2012
Barquito
Barquito's Avatar
Re: Winter storage
I would take the lifeline stanchions off. They will either rip thru the tarp or bend. Construct arches out of plastic electrical conduit. That will keep the tarp from sagging. Make sure the mast is well supported on both ends. Also support the spreaders. The disadvantage of having the mast on the boat, is that it is actually very hard to work on the mast that high in the air. It is much easier to have the mast on saw horses for work. In my case, next time I winter with the stick down it will not be on the boat.
Valiant 32
Barquito is offline
post #5 of 6 Old 10-24-2012
Load Bearing Member
CarbonSink62's Avatar
Dock
Re: Winter storage
I did this with my Capri 18 for several winters with no problems. I know the loads are much smaller.
The biggest issue I had was that I could not get the steep angle I wanted because the spreaders would stick out and I was worried they would get damaged. I got the angle as steep as I could and then used some old fence pickets as rafters to support the weight of the snow until I could go out and get the snow off with a broom. I did this after every real snowfall.
I had planned to remove the spreaders this year, but I sold the boat last spring and moved up.
Ken
Zen Again
1978 Bristol 29.9 #122
Testing a mother's love since 1962
CarbonSink62 is offline
post #6 of 6 Old 10-24-2012
old guy :)
rikhall's Avatar
Re: Winter storage
This is what I do for my Irwin Citation 34. The stanchions do not come off (easily) and so the uprights are over the stanchions.
Rik
Irwin Citation 34
Mystery
rikhall is offline
I just don't get it. Winter Storage DrB General Discussion (sailing related) 31 02-16-2011 06:23 AM
Winter storage brak Chesapeake Bay 22 12-07-2010 11:39 AM
water storage vs. land storage during winter apkaplan General Discussion (sailing related) 1 10-24-2007 05:50 PM
Winter Storage Joy Smith Gear and Maintenance Articles 0 10-22-2003 09:00 PM
Winter Storage RPerreca General Discussion (sailing related) 7 06-15-2001 06:34 AM
