10-23-2012
Re: Nicro-Fico Traveler Car
I had the same problem on the same car. Not sure what actually did the trick, but they did loosen. Eventually. After I tried over the course of a few days, and went slightly insane. My process (patent pending)....
PB Blaster (multiple soaks)
Manual impact driver
Heat (with pb blaster)
Cold (CVS wart-off freezer!!!)(with PB blaster)
After all that, nothing seemed to work..I came back a day or so later, and gave the screws a last try (using a regular screwdriver , but with a square section shank to which I clamped adjustable wrench to provide torque)...AND THEY LOOSENED!
One tip - use the biggest screwdriver blade that will fit in the head of the screw. Any smaller, it just tears up the stainless steel. I had to hammer the tip of the impact driver to get it solidly in.
My theory, FWIW, is that the heating/cooling (especially the cooling, as I poured boiling water on the car while cooling the screw!!) allowed the PB Blaster to penetrate the threads, and then it took a while to do its work. Good Luck!!
