Lower shroud tension thoughts - Page 2 - SailNet Community
 4Likes
post #11 of 12 Old 10-24-2012
chucklesR's Avatar
Re: Lower shroud tension thoughts
Loos gauges and pre-tension guidelines are for when you are dock side, not when you are sailing. You set them dockside, then go sailing and check.
As KH said, loose but not floppy, mast in column. Actual tension then doesn't matter unless you are near breaking strength (not likely).
chucklesR is offline
post #12 of 12 Old 10-24-2012 Thread Starter
grandcapri's Avatar
I appreciate everyone's response, I had a new spar put on 6 years ago and the rigger out of Annapolis said the slack lower shroud was fine and that coincides with the responses here.
I'll continue to assess, but you guys clearly have given me some insight.
grandcapri is offline
shroud tension donWolfe Gear & Maintenance 6 08-02-2012 10:49 AM
Single Lower Shroud Rig kwaltersmi General Discussion (sailing related) 10 05-05-2009 11:41 AM
Shroud Tension Update ktucker8 Gear & Maintenance 5 09-03-2006 11:51 AM
Shroud tension ktucker8 Gear & Maintenance 31 08-29-2006 09:25 PM
Shroud Tension john66 Gear & Maintenance 3 09-17-2002 04:56 PM
