-   -   Lower shroud tension thoughts (http://www.sailnet.com/forums/general-discussion-sailing-related/93417-lower-shroud-tension-thoughts.html)
grandcapri 10-23-2012 08:30 PM
I realize this is an opinion forum, but if your going to give an ass remark, I'd appreciate you passing on responding.
Does anyone have a simple measure of lower shroud tension?, simple put, when sailing with a load, my leeward lower shroud is slack but the spar is straight.
I believe the "if it ain't broke, don't mess with it" concept, however, a slack lower shroud seems to be suggestion instability.
Professional and informative responses appreciated.
Thank you.
knothead 10-23-2012 08:47 PM
Re: Lower shroud tension thoughts
Thank you.
It's pretty normal for your looward shrouds to slacken. My rule of thumb is to set them to where they are not tensioned, but also not loose, (As in flopping around), when sailing a reach in about 15 knots.
If the mast is still in column and your shrouds aren't floppy. You're fine.
That said, there are a lot of different rigs and some of them require a lot more attention to detail.
Sal Paradise 10-23-2012 08:47 PM
I have the same thing. My upper shroud stays fairly taut but the lowers get real loose. I talked to a friend who is a licensed captain with offshore experience and he tells me its normal.
Faster 10-23-2012 08:51 PM
Gotta say, Grand, that's a bit of an odd choice for your avatar! ;):confused::)
You should know that your first response is from our resident professional rigger - you won't get better advice.
sww914 10-23-2012 08:58 PM
There you have it, advice from a pro. I was about to say the same thing but my opinion carries less weight even with me.
SchockT 10-23-2012 10:14 PM
And it is consistent with what my rigger friends have told me too! "slack but not floppy".
paulk 10-23-2012 10:24 PM
Isn't your mast supposed to be straight and centered on both tacks? If that's the case, who cares how tight or loose the lowers are? They're doing their job when they need to do it.
rgscpat 10-23-2012 10:24 PM
Some boats, especially one-design racing boats, have tuning guides written for them by sailmakers or experienced owners, which give suggested shroud tension settings in pounds or tuning gauge numbers. Some of these boats are even designed to use different tension settings for different wind and sea conditions. Specific advice would depend upon the kind of boat, rig design, number and position of shrouds, and so on. Riggers have to deal with a huge variety of rig designs. But it's pretty easy to set the shroud tension on a Freedom!
Barquito 10-24-2012 09:55 AM
Would there, then, be a concern for shock loading when suddenly loading the other shrouds?
Sublime 10-24-2012 10:20 AM
Borrow or purchase a loos gauge and check the tension.
