Like Tree717Likes
  #1941
Old 02-27-2013
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Re: HMS Bounty in trouble...
Any wood boat that gets beat around a bit will open up. That's a given. A boat that is "tight" after being caulked is no indication of the hull's integrity, only that it does not leak much immediately. Rotted, oil-soaked, worm-eaten wood will not hold caulking for long. If the garboard is moving a lot because the whole hull is "soft", it will open up first, letting in a lot of water. Keels, made of oak are the first thing to get eaten by Toredo Worms. It just sounds like there was not enough pump capacity for the amount of leakage. Perhaps if they had a team of 50 sailors to man manual pumps around the clock, they may have avoided sinking but with a small crew, once the pumps went out, they were done.
casey1999 and ShoalFinder like this.
  #1942
Old 02-27-2013
casey1999 is on a distinguished road
Originally Posted by Hartley18 View Post
Hang on there a sec.. stick to the facts:
To my mind he makes a good point. The many, many, pictures out there of the Bounty "sinking" show the decks awash but the vessel otherwise completely intact. If the frames or fasteners were in any way rotten or otherwise "faulty", having tons of water sloshing around inside the hull would have split the ship apart. This simply did not happen.
With no working bilge pumps, the end result is simply a matter of time...
I just did some rough calcs and they way I figure Bounty with just the floataion of the wood alone could float well over 100,000 lbs. I think they had 80,000 lbs lead and then engines, pump, and other equipment would add quite a bit more, but with some trapped air pockets it would be normal for the ship to float for quite a while before she sank, even if her hull was split open below water.
smurphny likes this.
  #1943
Old 02-27-2013
ShoalFinder is on a distinguished road
Something I haven't heard mentioned, apologies if I missed it: Who comes out of the yard expecting the pumps not to be clogged, or to clog almost instantly thereafter? If any work at all was one in the engine room then you can expect trash, rags, butts, dirt, paint chips, stripped wire insulation, metal drillings, etc to be all over the place. All that crap will end up at the low point, where the bilge pump suction line will surely eat it.
In my experience, the first few days out of the yard can be the worst. That's the whole point of a shakedown cruise before you head off into the wild blue yonder. Even if the yard does everything right, there's just no way to dial things in until they are running under operational conditions. You always have to make adjustments, tweaks, and sometimes discover real, very serious, problems.
Of course, I have no idea what was worked on. All of these problems could have simply not been addressed at all and weren't part of the repair package.
casey1999 likes this.
  #1944
Old 02-28-2013
smurphny's Avatar
I was surprised that they lost track of her so quickly because she was certainly floating in those last photos. It might be helpful if the CG tried to place transponders on hazards like this whenever possible. Maybe they had no opportunity to do so but the pictures seemed to be in fairly benign conditions. I would not like to run into that at night.
https://s3-eu-west-1.amazonaws.com/c...14-530x330.jpg
  #1945
Old 02-28-2013
chef2sail's Avatar
chef2sail will become famous soon enough
She sank in 12,000 ft
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #1946
Old 02-28-2013
smurphny's Avatar
Thanks Chef. I didn't know anyone had actually confirmed that she went down.
  #1947
Old 03-03-2013
jameswilson29's Avatar
Senior Smart Aleck
jameswilson29 is on a distinguished road
Damning article in the Richmond Times Dispatch on this sorry tragedy, apparently due to superstition:
Did superstition and the lure of a new role drive the Bounty to the bottom of the sea? - Richmond Times-Dispatch: News, Crime And Politics For The Richmond Metro Area
  #1948
Old 03-03-2013
Minnewaska will become famous soon enough
I knew it. She went down because there were bananas and red-heads aboard.
chef2sail likes this.
Jeanneau 54DS
  #1949
Old 03-03-2013
Retired Naval Architect
Roger Long is on a distinguished road
Originally Posted by jameswilson29 View Post
Damning article ...
C__p article. The scale of the storm was well enough known days before for Dan Moreland in Nova Scotia to delay his departure. Nothing new here for anyone who followed the events.
The crew didn't know much about the storm as they were busy with the ship according to testimony. If there was any rush on Wallbridge's part, it was because he knew that, as soon as he mentioned the storm, the crew would start finding out more details about it and have time to think about their individual decisions. If he had that meeting on Thursday, and waited till Friday to leave, he probably would not have had the crew to take the vessel to sea. That is what is damning. No superstition here, just criminal negligent hubris.
  #1950
Old 03-03-2013
PCP PCP is offline
What is suggested is that Wallbridge was superstitious regarding Friday and that could have influenced his choice of weather and information limiting the days he could sail off. He was running in a tight schedule and needed to sail away to not miss commitments.
It is said that he never had set sail on Friday, following a long tradition regarding bad luck. Of course, if that is true or not and if it had played a part on this accident, it is impossible to know:
quote:"Why did a captain with decades of experience choose to rush to sea shorthanded and with a largely inexperienced crew at dusk on Oct. 25, after a long day of sailing and tours, as the powerful storm churned northward and gained strength?
A possible answer to “Why?” barely got mentioned during the proceedings...
Only Doug Faunt, 65, a quick-witted, veteran sailor who testified wearing a T-shirt carrying the date of the Bounty’s demise, offered a glimpse into the simple question of “Why?”: Walbridge’s obeisance to an ancient superstition.
Walbridge, 63, never left port on Fridays, Faunt told..: The old superstition, spawned by the discomfort of setting sail on the day of Christ’s crucifixion — Good Friday — could have played a fatal role for the Bounty...
Long bypassed by modern sailors as an illogical remnant of the past, the superstition apparently was part of Walbridge’s makeup, part of the way of life aboard an 18th-century square-rigger. No matter that this Bounty was a Hollywood creation built in 1960....
The Thursday evening departure was a crucial factor, though. By Friday, the ship was far at sea with Sandy building to a huge presence. The Bounty pressed on, and by Saturday, it was clear the ship could not sail around the massive storm to the east. Instead, Walbridge ordered a desperate course adjustment that took the ship on a southwest tack, trying to reach the shelter of Cape Hatteras.
Had Walbridge waited until Friday to sail or waited until Saturday, assuming he was adamant about not setting sail on Friday, the power, breadth and imminent danger of the storm would have been far more obvious
...So Bounty set sail Thursday evening..."
Also some light is shed about why he wanted to arrive to St. Petersburg, Fla, on a schedule:
quote"Walbridge was doing more than avoiding a Friday send-off....
Bounty’s possible salvation lay in coming under the control of a nonprofit organization that could provide tax advantages and use the ship for fundraising by taking on paying passengers and other commercial enterprises.
But it needed costly upgrading to meet Coast Guard standards to take on that new mission, and it needed to find an organization that wanted the aging ship....
The ship was scheduled to spend the winter at port in Galveston, Texas, but before that, it would spend a few days at the St. Petersburg, Fla., pier where it had been a familiar sight for years. The pier was about to be renovated, and Walbridge wanted a last visit there before heading to Texas.
As Bounty set sail from New London, plans were coming together, also, for using the ship as the focal point of a nonprofit based in Birmingham, Ala., dedicated to raising funds for and awareness of people with Down syndrome.
The Ashley DeRamus Foundation, along with Walbridge, was planning to give individuals with Down syndrome the chance to crew on a tall ship. It would be an educational opportunity for them to learn to sail and to develop independence, self-esteem and responsibility.
The foundation and Walbridge arranged to stage a special celebration in Tampa, Fla., once the ship arrived from New England. Families of Down syndrome adults and children planned to meet the ship; several individuals with Down syndrome would make the final leg of the trip to Galveston as volunteer crew members along with DeRamus.
It was all going to be filmed, narrated and become part of the foundation’s marketing pitch.
Christian was buoyant. “Claudene had been told by the captain that she would be part of the winter crew, and she was just totally excited about that,” Kannegiesser said. “She was going to be part of the public relations and marketing effort that would bring closer together the foundation and the Bounty.”...
The day for the Tampa celebration was set Nov. 9. The trip from New London to Tampa by way of Key West is about 1,600 nautical miles. If the Bounty averaged 5 knots, it would take 13.3 full days of sailing to reach the Tampa-St. Petersburg area.
That meant that if the Bounty got in a full day of sailing on Friday, Oct. 26, and nonstop sailing night and day for the next 12.3 days, it would reach Tampa Bay about midnight Nov. 6. Had the Bounty waited for Sandy to pass, gone far enough east to avoid it, or not set sail until Saturday, reaching Tampa on time would have been virtually impossible.
So the rushed start the night of Oct. 25 was crucial: It avoided having to set sail on superstitious Friday; it gave the Bounty a sliver of a chance of avoiding Sandy and a cushion of a day or so. But there could be no breakdown, no prolonged stopover, no significant change in course.
“We don’t want there to be any impression that Nov. 9 was a fixed date that couldn’t be changed,” Kannegiesser said. “It was clear that if there was a problem, we could accommodate that.”
What was clear from the hearings in Portsmouth, though, was that Walbridge, if anything, was a man of his word, someone who could be counted on to make good on a plan. He ruled the ship, where it went and when. Was meeting the Florida timetable something he saw as a sign of dependability, as crucial to the vessel’s future of gaining a new owner?"
All this makes a twisted kind of sense. Not logical, but logic seems not to be strong on that ship and crew. it also explains why Claudine, even with doubts gambled to make the voyage. What was at stake to her was not only the voyage but a kind of permanent job in a thing that he really loved.
It seemed he had not had much luck in his live on the past and end up in not having luck in is end, being one of the two that died.
Varietas delectat
You may post attachments
You may edit your posts
Rhodes Bounty ll white rabbit Introduce Yourself 1 10-12-2012 03:33 AM
New Member - Hardin 45 ( 44 voyager bounty ) Bianchi Introduce Yourself 9 01-29-2011 09:33 PM
HELP!! , Need move a boat NC to WA (Rhodes Bounty II, 40'10 x 28' x 10'3" x 5'9") sailandoar General Discussion (sailing related) 1 08-23-2006 01:11 PM
Bounty Windjammer Spectacle (Boothbay Register) NewsReader News Feeds 0 06-23-2006 03:15 PM
April 28, 1789, Aboard the HMS Bounty: NewsReader Mass Bay Sailors 0 04-28-2006 01:15 PM
SEO by vBSEO 3.6.1
