Disadvantages of a Loose Footed Main? - SailNet Community
post #1 of 6 Old 10-31-2012 Thread Starter
Aspiring to be a Mexican
sww914's Avatar
I have a 39" Vagabond Landfall, cutter rigged full keel cruiser. My main sail is in rough shape and I have another one, nice & crispy. The replacement has 3 reef points and it fits perfectly but the foot has a bolt rope that my boom won't accept and there are no grommets on the foot for my slides. I've considered sewing nylon webbing loops on the foot to accommodate the slides but a friend suggested running it loose footed.
What say you?
sww914 is offline
post #2 of 6 Old 10-31-2012
Tim R.'s Avatar
Re: Disadvantages of a Loose Footed Main?
Running that sail loose footed will work but you will not reap the benefits of a sail designed as a loose footed sail. Also, you may not be able to get that sail optimally tuned without the foot being attached.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #3 of 6 Old 10-31-2012
SchockT's Avatar
It probably won'tcost much to get a sailmaker to either convert it to loose footed or install the correct size foot rope.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #4 of 6 Old 10-31-2012
ASA and PSIA Instructor
I would definitely switch it to a loose foot. You might try it out and see how the foot looks, if it seems to set OK, just cut the rope off. If it doesn't set (or look) right, have a sailmaker work it over. I don't think the foot shelf or not will have a noticeable affect on sail performance.
sailingfool is offline
post #5 of 6 Old 10-31-2012
You can put grommets in the foot then attach slides. We would buy a main with a bolt rope and do this. Worked great and inexpensive
Gary3675 is offline
post #6 of 6 Old 10-31-2012
My last boat started out with a loose footed main. Then I put a track on. Zero advantage of having the track. My current boat has sailed with a loose footed main for 28 years. Zero disadvantage. Loose footed requires a stiffer boom.
Brent Swain is offline
Loose footed main vs attached mainsail lancelot9898 Gear & Maintenance 7 06-03-2011 08:55 AM
Sloop rigged with loose-footed main (no boom)? toastchee General Discussion (sailing related) 13 03-09-2010 08:38 PM
Boom Bags and Loose Footed Main tdw Gear & Maintenance 5 03-10-2009 10:20 PM
Loose Footed Main tager Gear & Maintenance 3 03-02-2009 11:46 PM
Loose vs Attached Footed Main / Buntline Hitch NewsReader Mass Bay Sailors 0 12-27-2006 08:15 PM
