Winter is coming -Battery Question? - Page 2 - SailNet Community
 8Likes
post #11 of 15 Old 11-04-2012
chef2sail's Avatar
Re: Winter is coming -Battery Question?
I also remove all signaling devices because if there were a fire, I would not want the guys in the FD having to deal with SOLAS flares going off.smurphy
Good idea about the flares. Never thought about that.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #12 of 15 Old 11-04-2012
pdqaltair's Avatar
Originally Posted by smurphny View Post
They are heavy sobs and I always dread disconnecting all the wires, ANL fuses, etc. and then getting them down the ladder and into the car.
It occurs to most that the risk of injury or damage lugging a battery bank in and out is greater than the risk of a system where all breakers and switches are open.
And for most, visiting the boat a few times in the off season is just good sense anyway.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
pdqaltair is offline
post #13 of 15 Old 11-11-2012
hopefully this is related enough not to be off topic. I'm buying new batteries for my solar-charged house bank. I'm told that one should test the batteries at the store to make sure you're not being sold old stock or otherwise batteries that are otherwise less than optimum. but how do you test 'em? just with a hydrometer?
thanks
sapo is offline
post #14 of 15 Old 11-11-2012
Maine Sail's Avatar
thanks
You can just measure the open circuit voltage with a volt meter. There is no real benefit to measuring the SG on new batteries because the cells are still new and un-cycled...
They should be above 12.6V or darn close to it. Try to buy batteries with matching date codes and the freshest date codes on the shelf. For example if there are four group 31 batteries and you need two, and the date codes look like this:
J12
C12
E12
J12
You want the two J12 date coded batteries. they theoretically should match better and have been produced at or about the same time. Often times the letter is the month with Jan being "A" and the year being "12"... This may not be the same for all batteries so ask your supplier how to interpret the date codes and choose the freshest batteries..
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 15 Old 11-12-2012
I leave my fully charged batteries in the boat all winter here in Canada and never had a problem. I do make sure to remove the cable connections from the battery posts. I'm on my 7'th year with these flooded Kirkland dual purpose batteries and note that in the Spring launch, they spin the engine as fully charged.
olgeezer is offline
Battery charger for winter storage? pegasus1457 Electrical Systems 22 06-25-2010 07:41 AM
Battery life? Winter storage? saltypat Gear & Maintenance 12 12-03-2008 11:57 PM
Question about winter sailing NewsReader Mass Bay Sailors 0 10-12-2006 12:15 AM
Battery Winter Storage bjoc2314 Gear & Maintenance 9 11-14-2002 03:57 PM
Winter Battery Storage Tom Wood Gear and Maintenance Articles 0 01-16-2002 07:00 PM
