Like Tree8Likes
  #1
Old 11-03-2012
ImASonOfaSailor's Avatar
John
ImASonOfaSailor is an unknown quantity at this point
Send a message via AIM to ImASonOfaSailor Send a message via MSN to ImASonOfaSailor Send a message via Yahoo to ImASonOfaSailor Send a message via Skype™ to ImASonOfaSailor
Winter is coming -Battery Question?
My 12v Marine battery is still in my boat, i have a solar panel to charge it, then it goes into a regulator. SO this will be my first winter with boat with a battery so Should i leave solar panel connected? or let battery do what ever it does? will the battery just die or does it stay the same?
What do you all do?
CaptainJp3
licensed OUPV/6-pack
Great Lake Erie, Marine State Park
"""Here's a toast to you on the coast and the sailors out at sea Drink your ales, hoist your sails Ride the windssssssssss and think of me,,,,,,,,,, 'cause Oh I wish I was there tonight"""
  #2
Old 11-03-2012
Maine Sail's Avatar
Re: Winter is coming -Battery Question?
If you can aim the panel at the prevailing sun angle for winter, and ensure it does not get occluded by snow, it happens, and your controller is a good quality controller with a float stage, then you'd be fine leaving it connected.
Often times when we get a storm that starts out as rain and then turns to snow the rain on the panel turns to ice and then the snow sticks to it. I have seen some panels with very steep winter angles full and loaded with snow due to this phenomenon. Usually it melts in a few days but I know more than one owner who's banks were killed despite being connected to solar due to this phenomenon. Some controllers draw more than other for "self power" and this is why disconnecting from the rest of the system, and its parasitic loads, is critical....
Some points:
#1 All system connections other than solar should be disconnected from the batteries. I find the NEG connections often easiest to disconnect. Only the controller should remain connected to the batteries.
#2 You will only be able to charge one bank of batteries unless you have a very low draw method of "combining" banks at charge voltages. If the panel becomes occluded you can drain your bank with an ACR or Echo charger, if it is occluded for long enough. If the panel is large enough it will recover the banks but if is "maintainer" size you'll likely never recover.
#3 Colder temps drastically slow the rate of self discharge and help prolong battery life. However you have LESS usable capacity in colder temps so that .3A parasitic draw effectively becomes much larger in colder temps. The batteries should be 100% charged before disconnecting them and this usually means less than 0.5% of Ah capacity in acceptance at 14.2V.
#4 I would advise a "top up" charge every six to eight weeks if you disconnect and let sit.. Usually only 4-8 hours is needed as the self discharge in colder temps is very low. This is more to get the electrolyte moving to prevent stratification. Be sure your charger can go into absorption first, and remain there for a few hours, to get the electrolyte moving..
dugout, rikhall and HDChopper like this.
______
-Maine Sail / CS-36T
  #3
Old 11-03-2012
CaptTom is on a distinguished road
Some people insist that removing batteries and putting them somewhere with a stable temperature, but NOT on concrete, is the only answer. I used to do that. Now I leave the batteries in and top them off by plugging in the charger about once a month.
If I had a solar charger, I'd leave the battery in and the charger on all winter. Just to be sure it's working, I'd check the battery with a float tester a few times.
Always be sure the battery is 100% charged before storing.
  #4
Old 11-03-2012
billyruffn's Avatar
billyruffn will become famous soon enough
I left batteries (2 banks of 350 and 450 Ahrs and a 110 Ah start battery) connected to the 100 W solar panel all last winter. I checked them every month or so and found the voltage above 13 V on every visit. When I'd turn on the battery charger the amp draw would quickly drop which is a good indication that the solar panel was keeping the batteries well charged. I might add that the boat and panels were covered w/ 7 mil white shrink wrap and the solar panel still worked fine.
  #5
Old 11-04-2012
John
well i have one battery, 1 15 watt solar panel and the boat is in my back yard so i can take snow, and Ice off if that happens. So i guess ill hook the solar up when i get a chance!
CaptainJp3
  #6
Old 11-04-2012
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Although it is a major PITA, I always remove all three HUGE batteries and take them home where I can keep them warm and charged. I don't want to have to worry about a solar panel failing and the batteries freezing. Of course it gets to -30 around here so it's probably more a concern than points south. If batteries freeze, they're ruined and expensive to replace. The other thing that is always a concern is having any potential source of ignition in an unattended boat. I am surprised that any boatyards even allow batteries to be on a boat all winter.
Flybyknight likes this.
  #7
Old 11-04-2012
pdqaltair's Avatar
pdqaltair is on a distinguished road
Originally Posted by CaptTom View Post
... but NOT on concrete, is the only answer. I used to do that....
This seems to be a hard myth to kill. Perhaps 50 years out 0f date.
From the Trogan battery site:
Storing a battery on concrete will discharge it quicker- Long ago, when battery cases were made out of natural rubber, this was true. Now, however, battery cases are made of polypropylene or other modern materials that allow a battery to be stored anywhere. A battery's rate of discharge is affected by its construction, its age, and the ambient temperature. The main issue with storing on concrete is that if the battery leaks, the concrete will be damaged.
From Optima site:
No, today's batteries use polypropylene plastic for the case material. They will not be affected. When possible, always store a battery in a cool, dry location.
DRFerron and chef2sail like this.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
  #8
Old 11-04-2012
Flybyknight is on a distinguished road
17 degrees East of South.
  #9
Old 11-04-2012
Maine Sail's Avatar
A fully charge battery will not freeze until it's colder than -70F. I was born in Alaska and my folks were there for years, in Fairbanks, and they only had flooded batteries back then. Freezing batteries was not an issue but tires that went flop, flop and cracked steering wheels were when it hit -50 - -60F.. The batteries survived just fine but had less cranking amps so many cars had bigger batteries then they shipped with.
Keep in mind that in warmer temps the rate of self discharge & the chemical reaction rate/sulfation accelerates so keeping the batteries "warm" can have less benefit to storing them in a cooler location at your house. In cold temps sulfation is virtually non-existent and this is why ours have always been stored on-board every winter. Many boat yards require batteries to be "disconnected" from the vessel, if left on-board, as they should. They allow top up charging while you are there but generally disallow batteries to be left on-charge..
If leaving them on-board they need to be 100% disconnected and charged them to full...
chef2sail likes this.
______
  #10
Old 11-04-2012
smurphny's Avatar
Absolutely right. Batteries don't freeze if kept charged. They do, however, lose charge more quickly when it's cold and I want to cover the boat and leave it all winter without having to check it on a regular basis. I don't plan on seeing the battery compartment until spring. The issue always in the back of my mind is that if there were ever a fire in the boatyard, no one could point the finger at me for a battery short being the cause. I also remove all signaling devices because if there were a fire, I would not want the guys in the FD having to deal with SOLAS flares going off.
I keep the batteries in my garage, where it is usually 40 degrees or so and occasionally put on a charge to keep them up to voltage. They are heavy sobs and I always dread disconnecting all the wires, ANL fuses, etc. and then getting them down the ladder and into the car.
You may post attachments
You may edit your posts
Battery charger for winter storage? pegasus1457 Electrical Systems 22 06-25-2010 07:41 AM
Battery life? Winter storage? saltypat Gear & Maintenance 12 12-03-2008 11:57 PM
Question about winter sailing NewsReader Mass Bay Sailors 0 10-12-2006 12:15 AM
Battery Winter Storage bjoc2314 Gear & Maintenance 9 11-14-2002 03:57 PM
Winter Battery Storage Tom Wood Gear and Maintenance Articles 0 01-16-2002 07:00 PM
SEO by vBSEO 3.6.1
