Exhaust waterline question? - Page 3 - SailNet Community
 1Likes
post #21 of 28 Old 11-08-2012
Junior member, rest old
msmith10's Avatar
Re: Exhaust waterline question?
Stuffing box looks good, double clamps and all. If it drips when the transmission is in neutral, I'd try tightening it a tiny bit and see if that stops it.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #22 of 28 Old 11-08-2012 Thread Starter
First String
Will do. I have a very dry bilge
ltgoshen is offline
post #23 of 28 Old 11-11-2012 Thread Starter
First String
Here is a short video if it while under way. This was today in Beaufort, I was at 2000 RPM's is if it looks too wet in the shaft
ltgoshen is offline
post #24 of 28 Old 11-11-2012
chef2sail's Avatar
Definately needs tightening. It is supposed to DRIP about 7 DROPS when the shaft is spinning.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #25 of 28 Old 11-12-2012
Originally Posted by ltgoshen View Post
How do you know if your impeller stops pumping water if you cant see it spitting?
I have keel cooling and dry exhaust. Wet exhaust is a major cause of engine failure.
Brent Swain is offline
post #26 of 28 Old 11-14-2012 Thread Starter
First String
Noted. I tightened it up Sunday. Thanks for the tip
ltgoshen is offline
post #27 of 28 Old 11-14-2012
Barquito
Barquito's Avatar
Some boats squat when under power because at hull speed the stern is in the trough and the bow is climbing the bow wave. Backing off a little may ease the squatting and save fuel. OTOH, I alway feel better after a good squat.
Valiant 32
Barquito is online now
post #28 of 28 Old 11-14-2012
Senior Slacker
SlowButSteady's Avatar
I thought about switching to a dry exhaust and keel-cooler at one time. But the idea of having a hot exhaust pipe running through the engine compartment makes me a bit nervous.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Exhaust Leak Question... tkawika Diesel 8 05-31-2011 03:16 PM
Waterline paint question: How to factor in provisioning weight? chrisncate General Discussion (sailing related) 12 01-13-2011 09:22 PM
Exhaust Question SailingWebGuy Gear & Maintenance 9 12-14-2010 11:17 AM
Exhaust maintenance question Seafarer31 Gear & Maintenance 6 06-02-2008 01:13 PM
Wet exhaust question Tanzerite Gear & Maintenance 0 05-29-2007 10:17 PM
