sailcloth: laminated or woven? - Page 3 - SailNet Community
post #21 of 22 Old 11-09-2012
overbored's Avatar
Re: sailcloth: laminated or woven?
Can you define folded. and how does that relate to a Kevlar sail. the ones I have that contain Kevlar are holding up well. the laminating film is what breaks down an then the Kevlar looses it support. as for the carbon sails they don't last long at all. I do have several yards of carbon rags stored in the garage.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #22 of 22 Old 11-09-2012
RichH's Avatar
As I remember from long ago the ASTM test method dictates a cyclical 90 degree bend with zero applied tension ... as the standard. If you assume other bend angles, you'll have to set up your fold-fatigue testing machine to the typical fold that you desire.
All the flexural fold fatigue testing 'relates' to the standard ASTM method, just like all physical testing to determine material properties; if you need to evaluate outside of those parameters ... set up your own testing machine, etc. to your actual or assumed conditions.
Guesses and assumptions dont count.
RichH is offline
Looking for used or old sailcloth lizziebird Gear & Maintenance 3 11-08-2009 09:12 AM
sailcloth moerdw1 Gear & Maintenance 0 05-22-2009 11:43 AM
Used Sailcloth? jVHoe Gear & Maintenance 3 01-27-2009 01:30 AM
Where to get seconds of sailcloth Finallybuyingaboat Gear & Maintenance 9 10-22-2008 08:41 PM
Sailcloth alecs123 Gear & Maintenance 1 08-13-2007 06:12 PM
