Running a portable generator at an angle of heel - Page 4 - SailNet Community
 7Likes
post #31 of 72 Old 11-08-2012
Re: Running a portable generator at an angle of heel
"and it doesnt affect instruments or the "
Proving what? Only that you can abuse electronics for a very long time without noticing any damage. However, they will take damage. Old studies (1970's) from the USAF indicate that discrete electronics, when properly chosen and used in properly engineered circuits, have a life expectancy of 100 years. ICs can last a thousand years, at which point the circuits in them electroplate themselves out of contact. And we pretty much all throw spikes and surges at all of our electronics regularly, and they keep on running.
But in the long run? It is still "dirty" power, and may be shortening the life or impacting the performance. From the laymen's point of view, that's impossible to tell. I trust the folks who make it, and the techs that have torn into it, when they tell me "this stuff is bad for your electronics". Of course I'm one of those curmudgeons who really doesn't WANT a new cell phone or TV or whatever every two years anyhow, I just want to dance with the one that brung me.
hellosailor is offline
post #32 of 72 Old 11-08-2012
A bit of a hijack,
A couple of years back, I was in OshKosh at the Airventure fly-in. (largest fly-in general aviation show in the world, I believe. 10,000 planes fly in and hundreds of thousands of visitors)
The guy tied down next to us runs a hose from his wing fuel sump to the gas tank on his Honda generator and the thing runs 24/7 for a week. Yes, it was a bit scary.
Jeanneau 54DS
Minnewaska is offline
post #33 of 72 Old 11-08-2012
Originally Posted by peterchech View Post
Cool site BL, interesting too that the dimensions of the 2000w unit are only about an inch larger on all sides, less of a difference than I would have thought. However 46 pounds, plus the weight of 4 gallons of gas, makes it quite a bit heavier...
Peter, I believe the fuel measurement is in liters not gallons so that would be alot less fuel to add to the overall weight.
waterwks4me is offline
post #34 of 72 Old 11-08-2012
chef2sail's Avatar
hellosailor,
Since I am running the gen to the shorepower...which goes then to the AC side of my boat and the ac outlets/ breakers. One of the breakers allows mew to operate a mastervolt 3 step charger which then charges the batteries.
All my electronics and refrigeration are on the d/c side. running from the batteries. How can there be an effect? I can understamd a spike from the gen to anything I have plugged into the ac side, but how does it get through to the dc side?
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #35 of 72 Old 11-08-2012
bljones's Avatar
My thinking behind two 1000 watt gennies is improved 12 volt output when linked over a 2k genny, redundancy and running flexibility- you only run what you need when you need it. Most times you'll only need to run a sub 1000 watt load, so why haul out a bigger, higher consumption generator than you need? as far as storage, build a couple of shelves into the usually underutilized cockpit lockers and stack 'em. It also gives one the ability to loan a generator if necessary.
It's 5 o'clock somewhere:
bljones is offline
post #36 of 72 Old 11-08-2012
Tanley's Avatar
We just went through the same decision process as you in preparation for Sandy. Bought it for the house but figured we can use it on the boat too.
Went with the 2000. Side by side there's hardly a difference in footprint or noise between the 2. The 2000 is easily carried around with one hand (think of a really small carry on suit case). It's so portable that I find it more convenient to use around the house than running extension cords for outside projects. Already brought it to the yard to work on the boat too.
Keep in mind that the initial current draw on your home fridge's compressor may make the 1000 choke. Got ours locally for $900. Good luck with your decision.
Tanley is offline
post #37 of 72 Old 11-08-2012
you people that are using either the 1000 or 2000 to run your onboard battery charger should take a look at the output of your charger It is probably pretty low since the input voltage on the AC side is only 65 volts. As i said in an earlier post the honda generators split the voltage between the neutral and hot leads and a mod is required to make things right. Its a simlpe matter of bonding the ground and neutral wire.
mitchbrown is offline
post #38 of 72 Old 11-08-2012 Thread Starter
My main concern with the 2000 besides weight is regarding fuel consumption. I'm guessing it uses double the fuel (100 cc motor vs 48 cc), yet only provides ~60% more power (1600 watts versus 900). Fuel was pretty scarce those days after Sandy...
peterchech is offline
post #39 of 72 Old 11-08-2012
Peter,
Both the 1 and 2 kw have an Econ mode that slows down the engine when they are lightly loaded. When running the same loads on them they pretty much burn the same amount of fuel. As I remember it was around 5 gallons in 24 hours with the one, and close enough with the two that I couldn't tell the difference.
Greg
Stumble is online now
post #40 of 72 Old 11-08-2012 Thread Starter
Thanks for the firsthand experience Tanley! So maybe it's not as much a PITA as I had thought then, though it's a big difference between reaching into a lazarette and simply going into your garage...
Portable Generator Snboard976 Gear & Maintenance 13 02-24-2009 03:25 PM
Safe angle of heel sneuman Seamanship & Navigation 31 11-14-2008 12:05 PM
Portable Generator vs Genset dougshipl Gear & Maintenance 109 06-07-2008 12:36 PM
New Portable Generator bushrat Gear & Maintenance 22 04-01-2008 05:20 PM
Portable Generator question SVGratitude Cruising & Liveaboard Forum 35 01-04-2008 09:14 PM
