Like Tree7Likes
  #41
Old 11-08-2012
JonEisberg will become famous soon enough
Re: Running a portable generator at an angle of heel
Rather surprising no one has posed the question so far, so I'll give it a shot...
Why on earth would one want to completely spoil the exquisite pleasure of sailing a 25-footer in sufficient breeze to put her on a heel, by running one of those infernal things? (grin)
I forget, what sort of power do you have aboard your boat? Inboard, or outboard? The 1000 is actually a pretty inefficient way to charge batteries, after all...
  #42
Old 11-08-2012
Minnewaska will become famous soon enough
I agree that I would rather not have an engine running while sailing.
However, why is 1000w any less efficient way of running the 110v chargers than anything else? Has to be more efficient than my genset and any engine driven alternator.
Jeanneau 54DS
  #43
Old 11-08-2012
tommays's Avatar
My KIPOR 2600 has been working great in really BAD conditions 24/7
As we on going on are 11th day it already does not owe me a penny
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #44
Old 11-08-2012
swampcreek's Avatar
swampcreek is on a distinguished road
Originally Posted by blt2ski View Post
Peter,
Not sure if one can get a retro-fit kit, you may want to look into making the genset you do get an LP useage. You do lose some power using LP, I do not recall the amount, for discussion purposes, I am recalling around 10%, so the 2000s unit would produce around 1800w.
A LOT of folks use the 2000w with land yachts, then link together, as at around 50-60 lbs iirc are easier to move than a single 3-4K unit in the low 100 lbs range. Yeah a 1000 at 25-30 lbs is easier yet........again, it depends upon how much power you need! Not sure if the 1K unit will tie together like the 2K units will to produce ~4Kw of power. If 50-60 lbs is too much for you to lift, but you need say 1500w of power at your max useage, then 2 -1K units tied together may be an option if you can do that.
If it were me, I would really try to find an lp operated genset, as at least then, while not CO free, compared to gas, very CO free, way less threat from fumes etc. I am sure there is an additional 200-500 cost.......but worth it imho!
Marty
Here you go! Propane conversion...THE ONLY WAY TO GO with generators!! I converted my 5500W Home Depot special and it works GREAT! A 30lb. bottle seems to last forever. I converted my Dad's little Coleman 3500 anfter years of fooling around with bad gas, clogged lines etc. My sister has it now since my Dad moved into his apartment we builrt him. A Honda 2K is on our goodie list as well (Might look into that Yamaha3000) when we get it there will be NO question...I will convert it right away to propane.
A and C Kit List kits
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
  #45
Old 11-08-2012
chef2sail's Avatar
chef2sail will become famous soon enough
Swamp I think thats a great idea since we already have propane aboard.
Damn Tommays. My heart goes out to you.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
  #46
Old 11-08-2012
THEFRENCHA is on a distinguished road
Reading posts re: gasoline generators I always wonder why anyone would spend so much money for a Honda or whatever famous brand .Bought a 1kw at Harborfreight for $90.00 about 5 years ago and this thing works fine! Always start and no rust
  #47
Old 11-08-2012
bljones has a spectacular aura about bljones has a spectacular aura about
hang in there tommays!!!
It's 5 o'clock somewhere:
  #48
Old 11-08-2012
ShoalFinder is on a distinguished road
For starting a 16k BTU air conditioner with a Honda 2000, you will want to use what is called a "Soft Start" device. It's an electrical module that you wire between the generator's output and the air conditioner's input. Think of it as a valve that opens slowly to control the amount of current it allows to the air conditioner while the compressor is starting to turn.
When you start an electrical load, such as a motor, the starting current shoots up pretty high and then gradually ramps down to the full load current that the device requires to run. This is called "in-rush" current. As people above have already mentioned, the electrical name plate on your air conditioner lists how many Amps it draws. That is the current draw when it is up and running. The Amps will be a lot higher as it starts up.
What a Soft Start does is choke that startup current down and stretch it over a longer period of time, such that the inrush current is kept to a controllable level. The device will take a little longer to get up to full current, meaning the motor will turn a little slowly at first.
The ramp up time is rather quick- it's not really that noticeable. We are talking a few seconds here. But a Soft Start will keep you from tripping breakers or knocking the generator off line when you start the air conditioner.
A Soft Start is sized based on the voltage and rated current of the load device (your air conditioner) that will be connected to it.
Here's an example of a soft start: (you want a "single phase" unit)
Single Phase HVAC Compressor Soft Start
Carlo Gavazzi RSBS Series | Energy Efficient Products | Marshall Wolf Automation, Inc.
  #49
Old 11-08-2012
tommays's Avatar
We have power again as of 8:30 PM Still gotta wait in gs lines BUT even thats getting a bit better
I was merely inconvenienced while perhaps not Katrina level folks around here on the south shore have really lost EVERYTHING
Tommays
Northport NY
  #50
Old 11-08-2012
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Glad you're back on Tom. My brother has his boat over in Bayshore. He came out of it with no damage but people I know in Stony Brook STILL have no power. What a screw up for LILCO!
You may post attachments
You may edit your posts
Portable Generator Snboard976 Gear & Maintenance 13 02-24-2009 03:25 PM
Safe angle of heel sneuman Seamanship 31 11-14-2008 12:05 PM
Portable Generator vs Genset dougshipl Gear & Maintenance 109 06-07-2008 12:36 PM
New Portable Generator bushrat Gear & Maintenance 22 04-01-2008 05:20 PM
Portable Generator question SVGratitude Cruising & Liveaboard Forum 35 01-04-2008 09:14 PM
SEO by vBSEO 3.6.1
