Running a portable generator at an angle of heel - Page 8 - SailNet Community
 7Likes
post #71 of 72 Old 11-13-2012
Re: Running a portable generator at an angle of heel
Originally Posted by Minnewaska View Post
Chef,
The 8amp output of the Honda is at 110v, not 12v. Roughly speaking, it would be capable of 10 times the amps at 12v. amps x volts = watts.
Essentially, your battery charger is making this switch.
To the best of my recollection, on my 1000, the 8 amp figure refers to the 12v output through an accessory plug with clips that can be attached to a battery's terminals... But that voltage is only minimally above 12v - nothing close to the 14+ volts either my alternator or battery charger will put out, and completely unfiltered/unregulated... Seems only useful for "jump-starting" a dead battery, to me - that's my primary reason for having one aboard, at any rate...
That's why I suggested in my initial post -and why others like Maine Sail have concurred - that such generators are a very inefficient means of charging batteries, without the use of a separate 110v charger... The OP appears to have lost interest in this issue, however... (grin)
chef2sail likes this.
JonEisberg is offline
post #72 of 72 Old 11-13-2012
Maine Sail's Avatar
Both the EU1000 and the EU2000 have a 12V / 8A DC output. This output is utterly useless for charging compared to using the AC side of the generator.
It is far more efficient to use the EU series generators to power an on-board battery charger, unless of course your on-board charger is 10A.......
______
-Maine Sail / CS-36T
Maine Sail is offline
Portable Generator Snboard976 Gear & Maintenance 13 02-24-2009 04:25 PM
Safe angle of heel sneuman Seamanship & Navigation 31 11-14-2008 01:05 PM
Portable Generator vs Genset dougshipl Gear & Maintenance 109 06-07-2008 01:36 PM
New Portable Generator bushrat Gear & Maintenance 22 04-01-2008 06:20 PM
Portable Generator question SVGratitude Cruising & Liveaboard Forum 35 01-04-2008 10:14 PM
