Interior painting time! - Page 4 - SailNet Community
 1Likes
post #31 of 36 Old 11-24-2012 Thread Starter
Re: Interior painting time!
I don't have any pictures of the overall finished look, I took those on an actual camera, here are some cell shots during the process though.
Lots to scrape
Sanded down
Ready to prime
First layer of top-coat, looked great. I was really pleased that I'd spent the extra 140$(over and above the first 40$ for regular paint I had planned to use) Right up until...
The entire V-berth did this, it did this on the tape, on the plywood, inside lockers, everywhere :-(.
looks like I threw sand in for non skid, but it was pressure washed, dried very carefully, temperature and humidity within spec. The paint shop said that they had guys throw it on with no prep work, never mind sanding down completely, pressure washing, scrubbing, spraying with cleaner, pressure washing again and then holding humidity at a specific level before and during the whole paint process.
HDChopper likes this.
Jgbrown is offline
post #32 of 36 Old 12-08-2012 Thread Starter
Update: In between my calling the paint shop to complain about it, and me getting around to returning the paint, there was a recall issued for the exact issue I had. They replaced my paint with paint from a different batch which did a lot better. Still not perfect though.
Guess they're still working the bugs out, not sure if it was worth the extra expense over the 100% acrylic water based kitchen and bath paint at almost triple the cost... Hopefully it lasts well, I don't want to do this again, a frustrating experience after spending the extra money but it looks pretty reasonable now. It seems to have dried quite hard and is more even at least.
EDIT: Shouldn't type late at night, extra expense over not OF. If I were doing it again, or recommending it to someone else, I'd go with a 100% acrylic kitchen and bath, or an alkyd exterior with mildew resistance if you can still find it in your area. The new hybrid paints seem like they'll be good, but the consistency and reliability just aren't there yet, and it's not a fun project to re-do.
Jgbrown is offline
post #33 of 36 Old 12-08-2012
Senior Moment Member
SloopJonB's Avatar
I don't want to say "I told....." Nah, I won't say it.
SloopJonB is offline
post #34 of 36 Old 12-11-2012 Thread Starter
Umm... I followed the advice here, to do it once and use something better I went back to the paint shop to go to semi-gloss instead of my original eggshel.
They said changing the sheen that much with the same paint insignificant, if the surface hardness and scrubbing was so critical then alkyd(oil) only way to really increase it.
I was advised that the alkyd/water hybrid was essentially the same, but with alkyd solids instead of acrylic solids, giving the increase in durability, ease of cleaning and long life that was the intent of all the advice.
So I can understand why you wouldn't want to say something like that... Unless with the I told you so comes an offer to come help sand off the outcome of the advice?
It's not the fault of the advice givers that paint was defective.
The advice normally should have worked and I appreciate the time spent to give the advice. I listened, I worked even harder than I already had on surface prep, I spent several days worth of pay on doing this right, right paint, right temperature, controlled humidity and two weeks of sanding and scraping, plus a day pressure washing and scrubbing then went and bought a better paint.
Jgbrown is offline
post #35 of 36 Old 12-12-2012
SloopJonB's Avatar
Use the acrylic semi-gloss. Get one formulated for bathrooms & kitchens as they have mildewcides in them.
I think something got lost in the discussion.
post #36 of 36 Old 12-12-2012 Thread Starter
Going to semi gloss vs the same in eggshell(100% acrylic with mildewcides that I already purchased for the job) did not provide a significant durability or ease of cleaning increase per the paint shop experts.
A defective batch of paint caused the problems, ignoring your advice would have avoided the problem too:P
I chose to follow your suggestion, and took it one step further to get the best available paint, harder, better bonding and longer lasting, which was the intent of the your advice as I understood it?
So an I told you so wasn't really warranted... It would have been warranted if I used my eggshell paint, then complained about the durability and ease of cleaning.
I read carefully the advice and suggestions and increased my cost and effort a lot, leaving me couch surfing for extra weeks so far while I dealt with the paint. I appreciate the advice that was given, I may find your comment funny later, I'm just too stressed to find much humor in it right now.
Sent from my SGH-I747M using Tapatalk
Jgbrown is offline
Interior Painting chris2sails Gear & Maintenance 5 06-16-2011 01:41 PM
painting interior widget55 Gear & Maintenance 5 02-09-2010 11:48 AM
Painting Boat Interior DaveXSquid Gear & Maintenance 21 07-13-2008 10:39 PM
Cleaning interior teak prior to painting GBurton Gear & Maintenance 0 11-09-2007 12:49 PM
Painting the interior pjfsail Gear & Maintenance 2 06-06-2005 03:32 PM
