Like Tree3Likes
  #11
Old 11-15-2012
ABH3 Boyer is on a distinguished road
Re: More head room
I exclusively sail on lake Erie in nothing bigger than 3 footers so I dont really need to worry about a wave washing it overboard. The top would stay the same just be raised by 8 to 12 inches (havent decided yet). The old set up raised the top 16 inches on 4-3/8" hollow aluminum rods and I couldnt make out how they would have locked in place. I assume the old pop top wasnt ment to be used underway. As far as how it will look. It will look original to the boat. Last year I got this boat as a project boat and did a complete overhaul on it. Stripped the boat back to just the fiberglass hull. Then replaced all structural components before installing all new interior. It is significantly stronger than the original build. The attachment to the boat and the top shouldnt be a problem as there is a 3" vertical flat surface to attach to on both components. The concerns I have are about the boat getting top heavy and overall performance. Also keep in mind that I dont race. I mostly do day sailing although next summer I plan to do a weekend trip or 2 but still within 5 miles of shore on lake Erie.
  #12
Old 11-15-2012
rhr1956's Avatar
rhr1956 is on a distinguished road
Re: More head room
The best feature for head room is a tilt steering wheel. Ooops...I should have read the entire post. ;-)
ABH3 Boyer likes this.
  #13
Old 11-15-2012
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Re: More head room
What you really should do is make some line drawings of what you are planning. Then we could get into a healthy asthetics argument.
I guess, I don't really see that it would add that much weight. May be missing something.
I have a pretty tall dog house. It is a bit of a PITA to see around. However, I have standing headroom in the cabin in a 27' boat, so I shouldn't complain. John Vigor thinks it is unsightly.
Bristol 27
Cirque
  #14
Old 11-18-2012
SailingSloop is on a distinguished road
Re: More head room
My thought is to use wooden kayak construction ideas to build a strong, lightweight structure. Bending thinner plywood into a curve adds lots of strength.
  #15
Old 11-27-2012
Re: More head room
If anyone cares I did it and it turned out great. I will follow up with a few pictures next weekend. My phone dosnt take good night pictures and I leave for work in the dark and come home in the dark.
  #16
Old 11-27-2012
tschmidty is on a distinguished road
Re: More head room
Definitely like to see pics.
  #17
Old 11-27-2012
deltaten's Avatar
deltaten is on a distinguished road
Send a message via Yahoo to deltaten
Re: More head room
Ya might want to give consideration to foam core FRP construction. Much lighter than alternatives, easier to shape curves and angles and is buoyant, to boot! Large, flat areas from sheet; curves, rounded joints from lams or blocks.
HTH,
Paul
  #18
Old 11-27-2012
peterchech is on a distinguished road
Re: More head room
HTH,
Paul
Great, except foam goes for like $200 a sheet...
  #19
Old 11-27-2012
deltaten's Avatar
Re: More head room
Don;t know where you sourced yer foam but there's 2 part liquid available that will produce quite a bit of pourable for one helluva lot less than $200/sheet.
http://www.shopmaninc.com/foam.html
In 2#, 3#, 4# and 8#/cu.ft. densities available for varying degrees of structural use . The 4# is recommended for boat decks and moderate loads while the 8# is useful for structural infill. Ya could buy enuff 2# to cast a block large enuff to damm'd near sculpt a boat for $200
I've used box-store urethane sheet for slab work. Never saw any that exceeded $22/sheet unless it was very much thicker than 1". I've molded over common construction foam; both pourable and sheet .
It works better to have a mold to build in; but outer lams are entirely possible; given that you need to undersize and work out to finished dimensions. Look fwd to lotsa fill and fairing
Might be my solution to rotten cored decks! Section out and remove rot. Clean and fill/inject. Pop section back on and clamp. Bingo! new foam core deck!
HTH
  #20
Old 11-28-2012
Re: More head room
I got home early enough to snap a few quick pictures. The exterior is complete with the exception of adding a large piece of lexon to the back hatch.
More head room-cheektowaga-20121127-00329.jpg   More head room-cheektowaga-20121127-00330.jpg   More head room-cheektowaga-20121127-00331.jpg   More head room-cheektowaga-20121127-00332.jpg   More head room-cheektowaga-20121127-00333.jpg
You may post attachments
You may edit your posts
Good Centre Cockpit with 6"5' Head Room meridiansahoy Boat Review and Purchase Forum 18 09-04-2012 04:24 AM
best Boat with Head Room gregc Boat Review and Purchase Forum 13 05-26-2011 10:07 PM
Hunter 22 Swing Keel head room scgilligan Hunter 1 03-16-2011 12:19 AM
Nauticat 33 - head room JoyLC Boat Review and Purchase Forum 0 06-03-2009 12:15 PM
How much room...? FrankLanger Seamanship 32 11-27-2007 03:16 PM
SEO by vBSEO 3.6.1
