Sailcare running up the tab? - Page 2 - SailNet Community
 6Likes
post #11 of 22 Old 11-15-2012
chucklesR's Avatar
Re: Sailcare running up the tab?
Have you ever left Jiffy Lube paying only for a 19.99 oil change?
Same deal.
chucklesR is offline
post #12 of 22 Old 11-15-2012 Thread Starter
TakeFive's Avatar
I know from talking to a previous owner (prior to the guy I bought it from) that my boat was not used at least 4 years of its life, so the sail does not have a full 13 years of use. I've hand-washed this sail twice before, and know I could make it look perfectly clean by myself. I believe it has a decent amount of life left in it. The draft is in about the right place, for cruising it appears to drive the boat OK. The stitches have no apparent UV degradation, the batten pockets are in great shape (though I prefer not to have them stitched shut ).
I had heard good things about Sailcare, and was interested in their process to re-resin the sail, which is included in the cleaning treatment. I realize that it will not restore the original shape of a new sail, but re-resining it will strengthen it enough to prevent small tears from getting larger. That's what I still plan to do.
I saw what a badly worn sail looks like when I retired my genoa, which had severe UV degradation. The mainsail is nothing like that.
I'm going to have this done, the only question is whether to spring the $88 for stitching the numbers and logos. I talked to the guy about it today, and he says that the cleaning solvents can soften the adhesive and cause the numbers and logo to de-adhere. I told him I'll think about it overnight and will call him tomorrow.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
post #13 of 22 Old 11-15-2012
chef2sail's Avatar
Dont get it done and hand stitch the numbers and letters of you see they need to be done. Thats not hard to do even without a machine.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #14 of 22 Old 11-15-2012
Their estimate should have appraise you of any likely collateral damage. They know damn well that sails have sail numbers on them, and if those are likely to come off an old sail, they should mention that up front.
I'd tell 'em to clean it like the said, and if they damage the sail numbers, they can glue them back on. Same as any car wash that damages my car, that's their problem, especially when they don't warn me.
How else did $188 become $350?
hellosailor is offline
post #15 of 22 Old 11-15-2012
JimMcGee's Avatar
Rick,
I've always used Moorhouse Sailmakers in Lumberton, NJ. Every other season I get the sails cleaned and repaired. The cleaning is $99 and the minor repairs/re-stitching usually come in around $25-$35.
Skip sold the business last year but I'm told the woman who did most of his work is still there so I'm going to give them a try.
So there are local options if you're not happy with Sailcare's work.
Jim
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #16 of 22 Old 11-15-2012
bljones's Avatar
I understand exactly where Sailcare is coming from with the add-ons.
Clean a sail and send it back with peeling numbers- customer is now unhappy.
Clean a sail and send it back with the same failing stitching as it had when it came in- customer is unhappy.
Mention to the customer AFTER he receives his sail and he calls in to express his dissatisfaction that you could have fixed the numbers and the stitching, and the customer says, "why didn't you tell me you could do that/ the sail needed that/ that could happen? I would have paid for it!"
From a customer service standpoint the vendor is in a "damned if you do, damned if you don't," situation. But at least if you tell the customer what his sail needs to come back to him in the best possible condition, prior to starting work, then the customer has the choice of opting for the $100 and understanding the possible outcomes, or opting for the work recommended.
chef2sail, msmith10 and TakeFive like this.
It's 5 o'clock somewhere:
bljones is offline
post #17 of 22 Old 11-15-2012
bigdogandy's Avatar
Dock
I had the sails on my boat cleaned and repaired at Sailcare a few months ago and I had a great experience all around....the repair work they did was good quality and about the same cost as a quote I had gotten from a local loft, and the cleaned and resined sails perform incredibly well - I think they hold their shape better now but that might just be my imagination. Once the Sailcare folks got the sails they sent me a quote that detailed out the repairs that they recommended, which were in line with what I had expected. The sails are over 10 years old and had gotten dingy and rust stained....today they look like brand new.
I have no connection to Sailcare other than being a satisfied customer, but all in all I think I got good value out of their service. Five years from now I'll look for someone to build me a new set of sails, but in the meantime I'm enjoying flying some crisp white canvas for a change!
Andy
Key Largo
S/V Everlasting Moon
1981 Endeavour 32
Be joyful though you have considered all the facts.
- Wendell Berry
bigdogandy is offline
post #18 of 22 Old 11-15-2012
Old as Dirt!
svHyLyte's Avatar
I hate to disagree vis-a-vis sail numbers, logo's et al, but at least here we often see boats sailing with unmarked sails, particularly if they are replacement sails for original equipment and the owners are not racers. Of the 40+ sail boats in our little 55 slip marina, I suspect less than half have marked sails. N'any case, re-gluing or even hand sewing isn't a big deal. I've redone ours a couple of times as the sun here (southwest Florida) can really eat up glued markings.
FWIW...
svHyLyte is offline
post #19 of 22 Old 11-15-2012
Cruiser2B's Avatar
I suggest you glue the letters and numbers if you do not have the correct tools for sewing a sail. I redid a seem on my genoa by hand and ended up with blisters. That darcon is some tough stuff.
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #20 of 22 Old 11-15-2012 Thread Starter
TakeFive's Avatar
Yes, that is exactly the situation, and I fully understand his desire to take the most conservative approach to ensure that I come away fully satisfied. The pain of an additional $88 would go away much faster than the dissatisfaction of losing a logo or a number.
He's explained that to me very clearly, and it's up to me to decide whether to take the risk and save $88. My numbers and logo are at least 95% adhered - just a little loss around the edges. If everything stays on and doesn't get torn, I can easily reglue them. The risk is if something comes off completely and gets lost or ripped.
So at this point, the most valuable advice I could get would be from someone who got the Sailcare treatment and opted against having the stitching done. How well did your numbers make it through their process?
TakeFive is offline
Sailcare - LaMauney Process...worth it? corny Gear & Maintenance 6 07-21-2009 07:00 PM
Taking a drive to Sailcare...need your sail cleaned? T37Chef General Discussion (sailing related) 16 12-12-2008 01:25 PM
SailCare Delivers sanctuarysam Gear & Maintenance 9 02-14-2008 11:59 PM
SailCare alecs123 Gear & Maintenance 14 08-24-2007 06:12 PM
Sailcare docket Gear & Maintenance 10 04-13-2004 12:07 PM
