Water Ballast - SailNet Community
post #1 of 12 Old 11-19-2012 Thread Starter
Water Ballast
Anybody know about water ballast in small boats? I'm restoring a small boat and would like to add to the little boat. Bill
billbouldin is offline
post #2 of 12 Old 11-19-2012
Tartan 27' owner
CalebD's Avatar
Re: Water Ballast
The MacGregor 26's and Hunter's 26' 'Edge' model all use water ballast.
Mmmm, how small a boat are you considering a water ballast system on?
A little more info on, or picture of your project might help.
Everybody has one:
CalebD is offline
post #3 of 12 Old 11-19-2012
Re: Water Ballast
I could be wrong on this, but boats that have water ballast were designed to have water ballast. Boats that don't have it were designed not to have it and trying to add it is probably a mistake.
Catalina 34
chuck53 is offline
post #4 of 12 Old 11-19-2012
Re: Water Ballast
Definitely need to know more about this project.. esp what boat is under consideration.
Faster is offline
post #5 of 12 Old 11-19-2012 Thread Starter
Re: Water Ballast
16' fiberglass, sloop rigged. I've cut off the cabin and all of the pop out glass fixtures, leaving the bare glass hull. I was reading an article in 'wooden boat' about a small boat
that had a water ballast. For some time the MacGregor 26 has intrigued me..the hauling weight and all. So I was wondering just how one could retrofit some kind if a system starting with the bare hull. Thanks for your interest. Bill
post #6 of 12 Old 11-20-2012
Re: Water Ballast
The most effective water ballast type uses water tanks outboard under the deck edges but that involves complex filling and transfer systems inappropriate for a 16foot daysailer.
But I think a boat needs to be designed around the concept. I'd also be a bit concerned about a loss of structural integrity with your having stripped the boat so completely...
Faster is offline
post #7 of 12 Old 11-20-2012
finding41's Avatar
Send a message via Skype™ to finding41
Re: Water Ballast
I own a Mac 26D. I doubt that it is very complex to add a water ballast to a smaller boat. (If MacGregor did it there's a reason... Fast, Cheap, Easy.)
I literally pull a plug turn a wing nut thing and wait until I can feel water with my finger in the hole. Then remove finger, close the wing nut thing and replace the plug. Then sail.
Take a look at the MacGregor stuff on line (Google images etc.) and you can find the hull plug with the ballast area just built in. (Make the shape first then glass it in.) Maybe put structure back inside the tank..)
I think its easier than it looks.
There's images and studies on line about the self righting characteristics of water ballast and solid keel boats as well as ballast placement. Makes for a great read. You will be surprised at what is the better ballast at different angles of heel....
finding41 is offline
post #8 of 12 Old 11-20-2012
Re: Water Ballast
Originally Posted by finding41 View Post
I own a Mac 26D. I doubt that it is very complex to add a water ballast to a smaller boat. ....
I was describing the water ballast systems used in ocean racers - not a simple 'flood and drain' centralized water ballast such as used by MacGregor and Hunter.
I was trying to say that adding such (ie macgregor style) water ballast to an existing design that was not intended to have it might not work so well, and that adding the more effective but much more complex outboard ballast to such a small boat was overkill...
Faster is offline
post #9 of 12 Old 11-20-2012
Re: Water Ballast
The Mac26 system does work. That being said, it is a highly inefficient way of ballasting a boat, since the water weight is added very close to the CE of the boat. It will certainly help during a knockdown, but doesn't really add that much to the sailing performance of the boat. In one design racing a lot of guys actually leave them empty, since the boat is faster with the ballast chamber empty.
A true water ballast system like you would find on a Mini6.5 or the larger Open 60's puts the water tanks as far outboard and high as possible. This provides maximum righting moment and actually helps keep the boat level when beating and power reaching. This is a radically different concept than the Mac26, and requires significant complexity in the plumbing, pumps, and manifolds to do it right.
Greg Rubin
Attorney
Stumble is offline
post #10 of 12 Old 11-20-2012 Thread Starter
Re: Water Ballast
Thanks for the insights. What I was thinking of was an inboard system placed against the center board trunk, but I can see that having it at the chine would increase the mechanical advantage in some tacks. I know it is overkill. Itís a hobby, both the design part and the building part.
The article that got me thinking about the idea was about Swallowboats in western Wales. The designer had been a Submarine designer so water ballasting was part of his background. I wonder where he put the water. I also wonder how he collects it and how it is discharged. swallowboats.com
Water Ballast Shakin97 Boat Review and Purchase Forum 7 10-25-2011 12:45 PM
Winter and a water ballast Claudia1002 General Discussion (sailing related) 9 04-12-2010 05:26 PM
Hunter 23.5 and water ballast tommitchrx Boat Review and Purchase Forum 5 07-06-2007 09:38 AM
water ballast musolmar Boat Review and Purchase Forum 8 09-26-2004 04:50 PM
Water Ballast/Manufacturer RSJ Boat Review and Purchase Forum 6 03-07-2002 05:59 PM
