Wasp in Mast/Sail - Page 2 - SailNet Community
 6Likes
post #11 of 22 Old 11-20-2012 Thread Starter
casey1999's Avatar
Re: Wasp in Mast/Sail
Originally Posted by MedSailor View Post
A good solid capsize or two ought to fix your problem, and you'd get a BFS out of it to boot!
I second the wasp traps and love the idea of hoisting one up to where they go in as well. As for moth balls I HATE the smell of those things and the smell does linger. Be sure you're okay with that because if you drop a couple in the mast you might end up with a boat that smells like moth balls.
Premethrin is what most bug spray is these days and they saturate baby's mosquito nets in the stuff in Africa. It's very safe for humans, is wickedly toxic to cats and I have no idea how it is for ropes, sails and canvas.
I'd try the traps and moth balls if you can stand them.
MedSailor
I'll give it a try. Mast is deck stepped so no problem there. I'll look into the premethrin.
Thanks
casey1999 is offline
post #12 of 22 Old 11-20-2012
Use chrysanthemum oil as part of a wasp-repelling spray. Hot peppers contain a compound called capsaicin, which burns wasps on contact and drives them away. Cut up half a cup of hot peppers, then pour a pint of boiling water over the peppers. After they cool, discard them and pour the water into a spray bottle. Add 4 or 5 drops of chrysanthemum oil to the water. The combination of the chrysanthemum scent and the burn of capsaicin repels wasps. Spray down areas like patios every few days with the solution to keep them wasp-free.
The oil can be purchased at aromatherapy supply stores or natural food shops. Chrysanthemum blooms contain a compound called pyrethrum, a natural insecticide effective against wasps and other flying insects. Along with the scent of the flowers, the oil has traces of pyrethrum in it.
Maybe putting the solution on a rag and putting it under the sail cover might help for a longer period. I dont know if it would damage sails if it was to come in contact.
delite is offline
post #13 of 22 Old 11-20-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
I've found that you must completely irradicate the nest. even the smallest trace left intact and the blighters will come back.
chef2sail likes this.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #14 of 22 Old 11-20-2012
Sevin in powder form kills everything with just a small puff. You can put some in a small sandwich bag with the corner clipped off and just kinda spray the stuff into the holes, or just get a cheap puffer from ebay. As the wasps touch it they bring it back to their nest and it kills everything in the nest within two-three days. Plus, it sticks around a few months to keep them away while the wasp pheromones get weaker.
smurphny and JoeLena like this.
zboss is offline
post #15 of 22 Old 11-20-2012
Needing Apehanger Helm
HDChopper's Avatar
Sevin ! dear god ...
Dishsoap & water in a pan with a handle on it will kill them all & nest.
There is no right way to do the wrong thing
HDChopper is offline
post #16 of 22 Old 11-20-2012
RichH's Avatar
Originally Posted by casey1999 View Post
I keep getting wasp that appear to be trying to nest inside my mast (enter through the internal haylard holes), and also try to nest under the mainsail cover while sitting at dock.
What is best repellant to use? If I spray with wasp spray will it damage my haylards, paint, sails, or fiberglass.
For wasps to be so common on your boat ...... and such 'mud daubers' REQUIRE the living carcasses of SPIDERS to grow their 'young' ... remove or kill any and all excess spiders you find in your area.
There are 'spider repellents' available to help keep the spider population in check: http://www.amazon.com/Star-brite-Spider-Natural-Repellent/dp/B001R1AQ5U You can also do a websearch for DIY 'spider repellents' and use them on the adjacent areas where you keep your boat.
The less/least population of spiders the less/least population of 'mud dauber' wasps. Mud daubers require a large population of spiders to feed upon and to lay their egg in.
RichH is offline
post #17 of 22 Old 11-20-2012
Best Looking MALE Mod
Cruisingdad's Avatar
Not sure why, but your post reminds me of this old thread: The Swarm
I always laugh at that thread!!!
casey1999 likes this.
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #18 of 22 Old 11-21-2012 Thread Starter
casey1999's Avatar
Wasp Update:
Yesterday go down to the boat to check on my wasp. None to be found on the boat or flying around. I had some moth balls so decide to drop about 10 in the mast through the haylard outlets. Also dropped 10 into the boom. Took a month ball and rubbed it on the sail cover and main sail. Then taped the mast openings with painters tape. As I was putting the tape on the mast, a wasp flew towards me and was going to go in the mast hole, but it seemed to get a hit from the moth balls and left- never to be seen again. Hope to sail this weekend so will see how it goes. Don't know if there is a nest on board, or if they are just preparing to make a nest, hope when I go down to the boat there is not an angry crew of wasp wainting for me on the deck.
I did look at ingredients for Raid wasp spray. It is 99% petroleum products and I called Raid- they do not reccomend using it on a boat. Also, the stuff seems pretty hazardous to marine life.
post #19 of 22 Old 11-21-2012
JimMcGee's Avatar
Don't over think it.
Mud wasps were a real problem at our marina this spring after a mild winter. They got into my AC discharge line and clogged it with what looked like cement, they got into the mast and under the sail cover into the folds of the sail. A couple of them even tried to start a nest under the hatch boards stacked on deck while we were working on the boat!
I just got a two pack of Spectracide (sp?) wasp and hornet spray, cracked a beer and watched where they were going. I waited until dusk and hosed those areas down. No more wasps.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #20 of 22 Old 11-21-2012
Old as Dirt!
svHyLyte's Avatar
We had a similar problem this past summer with paper wasps taking up residence in our mast, reaching strut, life-sling storage bag and under our sail cover between weekends. Based upon some research, I made up a mix consisting of two cups of water, a cap full of liquid dish soap and a couple of tablespoons of Oil of Mint (Oil of Pepper can also be used but I could not find any at our local markets). Mixed and placed in a spray bottle, after cleaning out the nests we could find/reach, we sprayed this into the openings on the mast we could reach and the other items listed. By the following weekend, the critters were all but gone. I have continued applications from time-to-time and the critters have not reappeared.
FWIW...
HDChopper and casey1999 like this.
svHyLyte is offline
Sail Rite Hinged Mast Sail Track Gate ROSA Gear & Maintenance 5 05-04-2013 03:44 PM
New sail or raise sail position on mast? ehroe2 Gear & Maintenance 10 06-24-2012 03:41 PM
Wasp deterrent Sublime General Discussion (sailing related) 14 04-12-2011 02:55 PM
Sail attachments to Mast Daveinet General Discussion (sailing related) 7 10-21-2010 12:47 PM
Mast Creaking under sail saurav16 Gear & Maintenance 6 08-08-2010 02:49 PM
