Mast climbing - Page 5 - SailNet Community
 19Likes
post #41 of 62 Old 11-25-2012
Re: Mast climbing
Originally Posted by smurphny View Post
The Mast Mate set-up looks very convenient but it apparently has no secondary safety line. Going up on just one halyard would make me very uneasy. Do you tie off somewhere else as a safety.
Absolutely, I would never go up the rig without a secondary line, I'm a total chicken when it comes to going up the mast...
I use a spare jib halyard run around behind the shrouds, and a Saf-Brake fall arrester clipped to either a chest harness, or a seat harness...
JonEisberg is offline
post #42 of 62 Old 11-25-2012
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
Re: Mast climbing
..a Saf-Brake fall arrester...
Do you have a link for that? I googled it with no luck. Thanks,
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
Sumner10 is offline
post #43 of 62 Old 11-25-2012
Over Hill Sailing Club
smurphny's Avatar
Re: Mast climbing
Originally Posted by Sumner10 View Post
We bought a used (very little) Mast Mate ....
Mast Mate Home
....but haven't used it yet, but will the next time we are at the boat.
I'll pull the Mast Mate up with the main halyard but will also wear a safety harness my wife made (Sailrite) and....
.... will probably use a line from it to the main halyard, as shown above, with either a prusik knot or friction device as a safety. I can slide it up or down the halyard as I ascend or descend.
The first time up I'm putting in another block up there and will then also have a line thru it to me and to the wife below. She is the backup safety to the prusik loop I'll be using. I don't want to put her in the position of number one safety. Also once up I could unclip from that line and use it along with her to raise tools/parts up to me.
One negative to the Mast Mate on the water is that you have to drop the main out of the track to use it, but I've read of some that have had luck leaving the main in the track and not using the track but pulling the Mast Mate up next to the mast free standing and then tying it off to the mast as you go up to keep it next to the mast. It needs to be tied off below next to the mast to do this.
Also the Mast Mate we got came with a belt kind of like a lineman's belt that you can keep around the mast as you ascend and descend. It also has a tool pouch.
I have a couple permanent steps that will be placed near the top of the mast to stand on while up there and can lean back on the belt or put a simple chair on the line my wife will control.
Another negative to the Mast Mate is that if you wanted to deal with a 70 foot mast you would have to get one of the appropriate length.
I had looked at all the other options that have been mentioned in the other posts. Being close to 70, but in good shape, we felt the Mast Mate would probably be the best solution for me/us. I guess I'll know a few months from now,
Sum
I put a second bracket at the last step so I can stand on two feet at the masthead. Have always wrapped my tether around the mast for a safety but am going to experiment using an ascender attached to a taut halyard instead. In any fall, it seems a goal has got to be to keep the upper body from becoming inverted if a foot were caught in a bracket or in one of the loops in a strap ladder. I think an ascender, adjusted from waist to arm's reach above could accomplish this and be easy to just slide up/down while going step to step.
smurphny is offline
post #44 of 62 Old 11-25-2012
Re: Mast climbing
Sum
I believe I paid considerably less for this about 15 years ago... I like it better than an ascender, doesn't seem to get hung up or caught as much on the way up...
LED lighting, soundproof, Sailor's Solutions Inc.
Perhaps one of the climbers here can direct you to an equivalent for a bit less...
post #45 of 62 Old 11-26-2012
Sumner10's Avatar
Re: Mast climbing
Thanks, using that as a start I found these two other possible solutions....
Petzl Rescucender Rope Grab
...and...
Petzl Shunt Mechanical Prusik
....anyone have comments on them. They look to be used as a safety going up and down with a line next to a ladder or another line.
They aren't that much less than what you posted. For $20 difference I'd just want the one easiest to use that is meant for this situation,
Sum
Sumner10 is offline
post #46 of 62 Old 11-26-2012
Re: Mast climbing
I swear there's no rednecks in the family tree but I can't help thinking, one a them 4wd winches with a remote control unit would make for a fine way to scoot up and down the mast. With a conventional safety line rigged for "just in case". I know, it's lubberly, it's ELECTRIC, it's all sorts of wrong...but the damned things can haul a jeep around and I know I'm not a whole lot heavier than a jeep!
hellosailor is offline
post #47 of 62 Old 11-26-2012
blt2ski's Avatar
Re: Mast climbing
HS,
One of them newfangled lectric wenches might werk too! or one of them thar windlassies! just remote control with a forward and reverse!
Anyway, I usually use my 4 altho it might be 5-1 how I have it setup, with someone tailing me on a winch. This helps as my cabin top winches are only 16-1. If one has a 40+ to 1 winch, then straight pulling on the winch will get someone up.
I may also be explaining the how I keep the tail end of the line around me incorrectly also. I set this up as if I was belaying someone, also repelling, I'm the belayer along with the belayee! It does create enough friction if done correctly such that I will not slide down too much, or at least slowly. One could also figure out how to do this with a figure 8 from climbing also.
At the end of the day, do how ever, whatever is such a manner, if you go up in one piece, come down in one piece!
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #48 of 62 Old 11-26-2012
Re: Mast climbing
...and...
Sum
I've not used these, but I do use the Petzl Gri-Gri which works the same way - only as a belay device. I would highly recommend these things as a back-up device. They're bomb-proof.
jrd22 likes this.
smackdaddy is offline
post #49 of 62 Old 11-26-2012
Owned by Velcro
Ferretchaser's Avatar
Re: Mast climbing
I think I'll stick with my mast steps.
ATB
Michael
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Light travels faster than sound. That is why some people appear bright until you hear them speak!.
Ferretchaser is offline
post #50 of 62 Old 11-26-2012
Re: Mast climbing
I think you should re-consider the ATN TopClimber. I've had mine for about 11-12 years and I've always felt safe. The trick that made it easy for me was to keep the static (climbing) line next to the mast and very tight. I put my hands around the mast, then stand up. Easy. The way it's usually shown is to hold onto the line and pull yourself upright. I find that difficult. As far as decending, what's wrong with slow. With al the things on a mast that can snag you, being slow and deliberate is much safer. I usually tie a line from my harness to an existing halyard with a rolling hitch as a safety line. I just slide it up or down as I go.
I'm old, fat, and also bald, and I've made as many as 7 round trips in one day for things I forgot ( did I mention I'm 75).
The ATN is simple, safe and ready to go, no experimenting.
Marc
xymotic, davidpm and dugout like this.
gershel is offline
Mast (Climbing)- No Halyards batshaven Columbia & Coronado 9 04-27-2015 02:32 PM
Climbing the mast pkats Gear & Maintenance 31 07-02-2009 11:40 AM
Climbing the mast kmeeks Gear & Maintenance 11 01-10-2003 01:55 PM
Climbing the mast word2rapp Gear & Maintenance 3 11-15-2002 10:57 AM
Mast Climbing RichardElliott Gear & Maintenance 17 04-19-2002 04:44 AM
