ethanol vs. non-ethanol gasoline - Page 3 - SailNet Community
 6Likes
post #21 of 21 Old 11-26-2012
Capt. Gary Randall's Avatar
Re: ethanol vs. non-ethanol gasoline
Ethanol does not mix very well with two cycle motor oil. It also leaves a powdery substance in the bottom of the bowl on your carburetor. Causing your motor to run in a lean condition at the mid and high-speed jet a two cycle engine when it runs lean on gas it runs lean on lubricating oil which will alternately cause some premature scoring of the cylinders and bearing failure.
Regular non ethanol gasoline is available at a lot of places in the Florida area. especially close to the waterfront.
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
Fuel Additives for Ethanol boardandplunder Atomic 4 10 08-13-2012 08:31 PM
Will Methanol Become the New Ethanol? pdqaltair Gear & Maintenance 0 03-27-2012 09:18 AM
ethanol fuel oldironnut Gear & Maintenance 8 05-07-2011 12:10 AM
ethanol in gas timangiel Gear & Maintenance 6 11-27-2006 11:53 AM
ethanol in gasoline & marine engines? eryka Gear & Maintenance 13 08-15-2006 12:15 AM
